04 Double Cab rear frame rust.
Discussion in '1st Gen Tundras (2000-2006)' started by COBound, Jul 11, 2023.
  1. Jul 11, 2023 at 2:35 PM
    COBound
    COBound [OP] New Member
    Hey guys, I recently acquired an 04 Double Cab and when I initially inspected the frame I missed some rust that is of concern. Looking through the forums the rust I have isn't nearly as bad as some examples. I'm wondering how I should proceed given the rust I have in this seam near the rear tire wells. The seam looks like it is separating but there are no holes in the frame and as far as I can tell the metal isn't thin enough to poke a hole through YET.
  2. Jul 11, 2023 at 2:47 PM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    That doesn’t look very severe to me. I would clean up with wire brush then coat with Cosmoline or surface shield.
  3. Jul 11, 2023 at 2:55 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  4. Jul 11, 2023 at 3:18 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That is the frame stiffener.Very common for it to delaminate like that. One side of my truck is like that. I used POR 15 to cover it. Another member ripped his out and made new ones.
    Have you dropped the spare tire and checked that crossmember yet?
    shifty` and Jack McCarthy like this.
  5. Jul 11, 2023 at 3:34 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    Good idea. I have some surface rust in my truck's nether regions as well and the spare gave me some grief. You'll want to spend some time under that spare tire area after you drop it, lubricating the hoist/spooling mechanism/winch thingy. Lots of recommendations, everything from white lithium to silicone spray to dry lubricant to etc. etc. I think the idea is just to get something in/on/around that thing once you initially bust 'er loose. I blasted all my bolts back in that area too with penetrating/rust prevention/stuff while I was up under there. Now the spare raises and lowers easily.
