05 grill help
Discussion in '1st Gen Tundras (2000-2006)' started by 2bak, Dec 24, 2020.
  1. Dec 24, 2020 at 7:35 PM
    2bak
    2bak [OP] Thanks
    M
    Bellingham WA
    2018 CM
    Anyone have a good source/part number to replace this billet set up to factory? Truck is limited. Thanks.
  2. Dec 24, 2020 at 8:48 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    If I'm not mistaken, I think you needed to cut up the old grill in places to allow for mounting the type that you have. I could be wrong and I'm sure someone here will no more than me . . . but I kind of remember thinking to myself, "That sucks you can't just unbolt the stock griil and replace it with that one". Same with the lower area I think. Again, I could be wrong but I think that's what turned me away from getting one of those. It's probably do-able . . . just more involved to sorta 're-engineer' it. Keep us posted & good luck. PS Why don't you like it? Looks?... or ???? I've always thoughts those looked cool.
  3. Dec 24, 2020 at 9:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @HBTundra is spot on. You'll need a whole new grille, and then you'll probably need a new bumper cover since they cut out the plastic web to add the billlet insert.
  4. Dec 24, 2020 at 9:08 PM
    2bak
    2bak [OP] Thanks
    M
    Bellingham WA
    2018 CM
    Thanks for the insight, hoping that’s not the case! But if it is sounds like a good project. I just like the factory look better. Never been into that billet look.
  5. Dec 24, 2020 at 9:10 PM
    2bak
    2bak [OP] Thanks
    M
    Bellingham WA
    2018 CM
    Got it thank you. Any idea of all the parts needed specifically?
  6. Dec 24, 2020 at 9:12 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you want the stock look you'll just need to order up one for a double cab. 04-06 will do, access cab are different and won't fit. Paint will get pricey unfortunately
  7. Dec 25, 2020 at 5:03 AM
    Professional Hand Model
    Hand Protectors
    You could sell your old one a recoup some $. Take care in removal.
  8. Dec 25, 2020 at 6:13 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    You might not need a bumper if the lower billet is bolted or tie-rapped in place. Check it to see if the honeycomb is still intact...
  9. Dec 30, 2020 at 7:15 AM
    ZFORCE
    ZFORCE New Member
    2003 Green Tundra Access Cab 2wd
    eBay grills for your 05 start at $45 shipped, and it looks like you can get more than that for your old one.
