05 Tundra 4wd problem
Discussion in '1st Gen Tundras (2000-2006)' started by dm76, Nov 30, 2022.
  1. Nov 30, 2022 at 9:20 AM
    dm76
    dm76 [OP] New Member
    2005 toyota tundra
    Hello all,
    As the title states I have a 2005 Tundra and have been encountering issues with the 4wd system. At first, the 4hi 4lo lights were flashing rapidly when I tried to engage the 4wd. From what I found online that meant that something is preventing the actuator from engaging. I cleaned the electronic connectors to the actuator and that did not fix the problem. I then pulled the plastic cover off the actuator and cleaned the gears, the problem still remained. I then pulled off the entire actuator and noticed the metal contacts were corroded so I bought a new actuator and installed it.
    Now only the 4lo light blinks and the 4wd still wont engage. I checked the 4wd fuse and it is intact. I am now unsure if it could possibly be an electric connection or a problem with the front differential actuator.
    Has anyone ever encountered this problem or a similar one? or does anyone have any other ideas of things I can check that could be causing this problem?
    Thanks
  2. Nov 30, 2022 at 10:38 AM
    4WD isn't my forte. @Tundra2 didn't you have something weird with the fork position or whatever when you were dealing with your actuator, and that lent to some weird ass results?
  3. Nov 30, 2022 at 10:51 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I would verify the front driveshaft for the 4wd is spinning when you engage 4wd high and that you can take it out of 4wd high. If that works, it's in all likelyhood your front diff actuator giving you problems.
    4wd low as I recall should only engage after 4wd high is engaged and the truck is in neutral and at a standstill. Don't quote me on that, check the driver's manual to confirm. I haven't used 4wd low in years.
  4. Dec 28, 2024 at 5:46 PM
    BigMerc
    BigMerc New Member
    Alex
    2005 Silver Tundra 4x4
    were you able to find a solution to this problem? I am going through the same thing you posted and i can’t find a solution, Thank you.
  5. Dec 28, 2024 at 6:30 PM
    BroHon
    BroHon Everything's clock is ticking
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
