1/4 inch wheel spacer
Discussion in '3rd Gen Tundras (2022+)' started by johnnyconway, Aug 8, 2022.
  1. Aug 8, 2022 at 8:50 AM
    johnnyconway
    johnnyconway [OP] New Member
    2022 Sr5 Tundra
    Trd pro grill-ARE cap
    Does anyone know if there is enough thread to fit 1/4 inch wheel spacer behind the stock wheels? I’ve searched the forum and haven’t seen that question answered. Just want enough room to fit the trd center caps in there on the front wheels(just need a little space to clear the bearing dust cap).
    Troyboy84 and Yaboy like this.
  2. Aug 9, 2022 at 7:40 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    No, too small. There would be no way to attach a wheel spacer that thin, not enough room for the lugs to attach the spacer, the bolts to attach the spacers are thicker, they would stick out and not allow the wheel to be installed. 1 to 1.25in thick will be the smallest wheel spacers.
    johnnyconway[OP] likes this.
  3. Aug 9, 2022 at 9:35 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Are you talking a true wheeler spacer or a wheel shim?
    People have been running 1/8" shims (see the Westcott vids for 35"s and 37"s). I would imagine there's an additional 1/8" of tolerance to fit a 1/4" shim in there.
    nasher75 likes this.
  4. Aug 9, 2022 at 10:09 AM
    johnnyconway
    2022 Sr5 Tundra
    just a shim. Thanks for the info!
    KroppDuster[QUOTED] likes this.
  5. Aug 9, 2022 at 1:30 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I’m thinking of adding this to my +18 offset wheels, not a full spacer with a second set of nuts just a shim.
  6. Aug 9, 2022 at 3:36 PM
    johnnyconway
    2022 Sr5 Tundra
    Yep. Something like this is what I want
    Yaboy[QUOTED] likes this.
  7. Sep 12, 2022 at 5:46 PM
    Geodude82
    Geodude82 New Member
    I'm thinking of doing the same, how'd it turn out for you?
