1 part of back window shattered by just simply hitting a pot hole on the road
Discussion in 'New Member Introductions' started by Amandadonelle, Mar 10, 2020.
  1. Mar 10, 2020 at 1:26 PM
    Amandadonelle
    Amandadonelle [OP] New Member
    Mandy
    2013 Toyota Tundra crew cab SR5
    Hit a pot hole on the way to doing my grocery ,anyways back window shattered just like that just by simply hitting a little pot hole and driving down a bumpy road ?? Called the dealer and they said that anything to do with glass they don’t cover but then again i know a few person that it allready happend and there dealer covered it under warrenty!! I think my dealer is a bit hard to deal with when it comes to anything warrenty even after buying a 2500$ extended warrenty ! I understand if it would accidently but just by driving down a paved road a window should not shatter !!
  2. Mar 10, 2020 at 1:35 PM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO. Must of been one hell of a pot hole!
    Are you trying to see if this has happened to anyone on here?
    Are you venting?
    These usually dont go well. I would drop another post to introduce yourself.
    Moon Puppy, P-Factor and GNTundra like this.
  3. Mar 10, 2020 at 1:41 PM
    GNTundra
    Gino
    2013 White
    :D
  4. Mar 10, 2020 at 1:42 PM
    GNTundra
    Gino
    2013 White
    Welcome aboard!
    Id try another dealership.
    MS22, joonbug, Inquiringone and 2 others like this.
  5. Mar 10, 2020 at 1:59 PM
    Welcome from NY.
    Sorry to hear this happened.
  6. Mar 10, 2020 at 2:01 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Have seen happen on various trucks & SUVs. Guessing it is in some kind of bind. Different windows as well.
    Amandadonelle[OP] likes this.
  7. Mar 10, 2020 at 2:22 PM
    AZBoatHauler
    So.Arizona
    Welcome to the forum. Sorry about the bad luck. Is that a headache rack installed? My guess is that would be a contributing factor.
    Pudge, Hbjeff and KTM Hauler like this.
  8. Mar 10, 2020 at 2:44 PM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    welcome, might want to check a local junkyard for a crewcab Tundra and see if you can pry a left rear window out of a junkyard Tundra (that is if there are any in there between all the Fords, Chevy's, and Dodges :bananadance:)
  9. Mar 10, 2020 at 2:49 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    You don't need it anyway, the headrest was covering most of it anyway - Duct Tape will solve this problem.
  10. Mar 10, 2020 at 2:51 PM
    Welcome from Ohio. Sorry to hear that happened.
  11. Mar 10, 2020 at 2:59 PM
    Amandadonelle
    Mandy
    There is a back rack but it has been put on the truck since day one , so that is not the probleme. Any who got it replaced .. unfortunetly you cant buy just the one piece of window had to replace the whole window 550$ later its fixed
  12. Mar 10, 2020 at 3:47 PM
    AZBoatHauler
    So.Arizona
    I assume the window has been in the truck since day 1 as well. I would verify all your hardware is tight. Even if everything is tight, bed flex is real. My forensic reconstructive mind begs to know... did you hit the pothole on your driver's side?
  13. Mar 10, 2020 at 5:34 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Hell, mine shattered just shutting the driver's door. Hey there from Virginia! :mudding:
    NewImprovedRon likes this.
  14. Mar 10, 2020 at 5:41 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Looks like a 3 piece window. Im suprised you had to buy a whole rear window and not just that section.
  15. Mar 11, 2020 at 5:43 AM
    Welcome from TEXAS
  16. Mar 12, 2020 at 6:42 AM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Dang man if that happen to ur back window hope it didn’t jack up the front end any. Also how about the insurance company? They might fix it for free
  17. Mar 12, 2020 at 6:51 AM
    Trooper2
    JR
    A few years back a co-worker had a Tahoe (2005ish), he thought it was possessed. Rear passenger window shattered two different times while parked! We could only surmise that TX summer heat & dark gray color built up pressure and found weak link.
    Vandalism dismissed, no glass pieces inside, only on the outside.
  18. Mar 12, 2020 at 9:23 AM
    Trooper2
    JR
    Pull up to one of those windshield chip/star fixer that insurance covers and tell them to get busy! LOL :rofl:
  19. Mar 12, 2020 at 9:28 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe it had a small crack already.
