12 volt solutions remote start help!
Discussion in '2.5 Gen Tundras (2014-2021)' started by gparr48, Oct 29, 2019.
  1. Oct 29, 2019 at 3:57 PM
    gparr48
    gparr48 [OP] New Member
    Grant
    2014 White Tundra XSP-X
    7 inch BDS Lift Fox Shocks 37 inch Mickey Thompson 20 inch Fuel Wheels
    I’m trying to install the 12 volt solutions remote start system on my truck. I’ve got everything plugged up, but having issues programming the module. LED 1 is supposed to turn green but stays red. Not sure if anyone has any knowledge on this system and can help. Thanks!
  2. Oct 29, 2019 at 4:06 PM
    mannydc
    mannydc New Member
    I ran into the same issue with my 2017 Toyota Prius. I called them on the number provided in the package and we ran through a few scenarios and eventually it was determined that the module I had was defective. They sent me a whole new remote start system and will be hooking it up this weekend. Hopefully it works this time.
    gparr48[OP] likes this.
  3. Oct 29, 2019 at 6:33 PM
    gparr48
    Grant
    Okay I got in touch with 12 volt solutions and they have update their harness, so now you have to by pass a connector and that did the trick. Thanks!
  4. Dec 25, 2019 at 4:27 PM
    mortiz21
    mortiz21 New Member
    Marissa
    2015 Tundra CrewMax Limited Attitude Black
    275/60/20 Nitto Ridge Grapplers on Fuel Mavericks 5100 Bilsteins in the front EAG Raptor Grill Insert
    what connector did you bypass? my truck will not start even after taking the entire kit back out. No blown fuses and the battery is fine. My truck won't even turn on at all
  5. Dec 25, 2019 at 5:28 PM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    Double check bcm connector and the connector under steering wheel. One may have backed out if it was clipped in all the way, if they both are clipped in double check no pins got bent.
  6. Oct 19, 2020 at 11:43 PM
    Picantesauce
    Picantesauce New Member
    Did u ever figure out what the issue was?. I'm having the exact same issue with my truck right now. I tried to remove everything and the truck won't start. Car beeps when I put the key in, but it won't crank and none of the acc. stuff comes on. Any tips? I checked the connectors and they all appear good. Very weird.
  7. Oct 20, 2020 at 6:42 AM
    manhster
    manhster New Member
    Richmond, VA
    '17 Black CM 4x4 Ltd TRD OR
    Just ordered this, hopefully I don't have this issue.
  8. Oct 20, 2020 at 3:18 PM
    Picantesauce
    Turns out while removing the unit, I actually blew 2 fuses under the hood. 30amp and 50amp. After replacing those everything went back to normal. Just make sure you remove the ground from the battery prior to doing any electrical work. Even though this is all plug and play. Better safe than sorry. I got lazy
  9. Dec 14, 2020 at 12:34 PM
    woodrib
    woodrib New Member
    Brock
    2015 Tundra CM Limited
    275/65/20 Toyo M/T 2.5" level kit Retrax OneMx bed cover LED replacements LED lights in bed
    @Picantesauce Could you point me to the fuses you had to replace?! I am stranded...any help is greatly appreciated. Thanks!
