12 Volt Solutions Remote Start
Discussion in 'General Tundra Discussion' started by hunter35745, Nov 11, 2018.
  1. Nov 11, 2018 at 4:51 PM
    hunter35745
    hunter35745 [OP] New Member
    Keith
    Midlothian, Va
    2018 Tundra Platinum Super White
    Ionic 5" stainless tube steps, Weathertech vent visors front and rear,Weathertec all weather mats, Shorty antenna, TRD cold air intake,oil cap,radiator cap ,rear sway bar and dual exhaust,console safe, color match mirror caps,gloss black color match door handles, Tinted D&P front windows, Line X Premium spray in bed liner, TRD front swaybar
    has anyone with a 2018 tundra installed one of these, if so can you give me your opinion, and let me know if you have a H or G key. Thank you
    Thegr8punkin likes this.
  2. Nov 11, 2018 at 5:39 PM
    WZ KTM
    WZ KTM New Member
    2018 MGM DC TRD Off-road
    I’ve got one on my 18 with the H key. Works great. Just have to remember to pre set your heater settings when you leave your truck for the night. 12 volt has a really good YouTube video for the install, very easy.
    mountainpete likes this.
  3. Nov 11, 2018 at 5:54 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I installed one last weekend. 2018 H key. Very, very easy and a well made harness. I didn’t need to drop the airbag.
    My only dislikes compared to the fancy OEM one in my wife’s Honda Pilot:
    1. As @WZ KTM mentioned, preset your heater. Same for your seat heater.
    2. If you have auto headlights turned on it will activate on start. Not a big deal.
    3. Range is limited to the keyless entry which is, in my opinion, poor. I will likely upgrade to the phone module as I do not want to carry a remote.
    Overall, good purchase and happy so far.
    WZ KTM likes this.
  4. Nov 11, 2018 at 6:16 PM
    goffredo
    goffredo Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    This looks very nice. I've also got a 2018, and being a bit of a keychain minimalist, I've been looking for a remote start solution that works with the factory key.
    Can someone who has this installed confirm a few things?
    1) Hitting the "Lock" button on the factory key 3 times to remote-start the truck ... does this lock the doors as well, if they were in an initial unlocked state?
    2) To drive away, you get in the running vehicle, put the key in, turn to ON position, and drive off. At no point do you have to shut the engine off and immediately re-start it (like the bullshit factory-installed remote start kit)
    3) If you leave the defrost, heat, and ass warmers on the night before, they will come back on when you remote-start the truck. I.e., the whole point for getting this kit.
    Thanks!
  5. Nov 11, 2018 at 6:28 PM
    mountainpete
    Yes. It locks normally. It listens for three lock presses in sequence and then starts the truck.
    Unlock, get in, turn key to on, press brake and drive away. You do not have to restart the truck. At no point do you need to restart it unless you touch the brake before turning the key to on.
    With an SR5, yes except for the rear defroster as they are all hard “on” switches. Can’t speak for the auto climate control in higher trim levels.
  6. Nov 11, 2018 at 6:44 PM
    goffredo
    Thanks for your confirmations! This sounds great. I've got the Limited trim package, and my heater is not a discrete lever / switch thing, but rather fancy dials and buttons, so I'm still a bit leery as to whether it will come on or not. I will get off my lazy ass tomorrow morning and do a quick test with the actual key, shouldn't be too hard to confirm.
  7. Nov 11, 2018 at 6:46 PM
    mountainpete
    From what I have experienced, if it remembers it with the actual key, it should be the same with the remote starter.
  8. Nov 14, 2018 at 10:20 AM
    goffredo
    Update: On my 2018 Limited, when I turn the truck off, and then on again, the climate control system remembers the settings for:
    - Ass warmers
    - State of the following: Temperature setting, Sync, A/C, Auto, Windshield Defogger
    It does not remember the setting for the side mirror defogger button. Which is kind of annoying, because if I'm using a remote start on my car in the winter, it would be really nice to melt the ice off the side mirrors. But at least my ass warmer will be all toasty.
  9. Nov 14, 2018 at 3:48 PM
    hunter35745
    Keith
    Midlothian, Va
    I purchased mine today, I talked to my dealer and and as long as it is 100 percent plug and play, no wire splices, it will not void any part of the warranty, so I called and talked with 12volt solutions and confirmed, no splicing with the new kits, 100 percent plug and play. For those that have done the install, do I need any special tools to remove the panels, and do they go back in place easy.
  10. Nov 14, 2018 at 4:24 PM
    Sakic10
    Sakic10 New Member
    Jordan
    2018 Tundra SR5 CrewMax
    I've decided I am ordering this and the phone module. Waiting until Friday to see if they go on sale at all, either way pulling the trigger then.
  11. Nov 14, 2018 at 4:57 PM
    TheBeast The Beach
    cool kit ! I might get one for my 2012.
  12. Nov 14, 2018 at 5:26 PM
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    Whats the link for this remote starter,im interested in getting it and did any of u with factory alarm had to splice any wires ? Or is it still plug and play .Thanks
  13. Nov 14, 2018 at 6:00 PM
    pmcgeorge1964
    pmcgeorge1964 New Member
    Paul
    2018 Tundra TRD Quicksand
  14. Nov 14, 2018 at 8:51 PM
    viha22
    viha22 MAGA
    WA
    Thanks
  15. Nov 14, 2018 at 10:23 PM
    mountainpete
    You don’t NEED any special tools but a trim removal kit is helpful to prevent scratching. There are lots of kits available on Amazon for less than $10.
  16. Nov 14, 2018 at 10:35 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    In no way do I need one of these...but I really want one!
    viha22 likes this.
  17. Nov 21, 2018 at 4:32 PM
    hunter35745
    Keith
    Midlothian, Va
    Installed mine last Sunday, works great and easy install.
  18. Nov 21, 2018 at 4:51 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    This write up is dead on. I put one on my 2019 CM 1794 a couple of weeks back. Love it. I have the h-key.
    It took a little over an hour to install. Removing and replacing the panels took most of that time.
    I’ll probably end up adding the $199 Wi-Fi module to extend the range.
    No special tools are needed. I used a large screwdriver with a rag wrapped around it to pry of the necessary panels to prevent scratches.
    The 12 Volt Solutions online video is great. I had a couple of questions before installing. They responded to my emails within minutes, even after hours.
    The only very minor glitch is that, when you remote start, the auto steering wheel and seat adjustment doesn’t work when you put the key in. No biggie for me, I just hit the profile adjust button on the door.
    SWIPE likes this.
  19. Nov 21, 2018 at 6:13 PM
    Kevin1741
    Kevin1741 New Member
    I installed one on my 17 highlander...easy enough to do but like others have said the range is limited to the factory fob range which is horrible imo. I will probably add the phone option as well.
    Fishman57 likes this.
  20. Nov 21, 2018 at 6:43 PM
    eswartz
    eswartz New Member
    Does 12volt solutions have any discounts or black Friday specials that anyone knows about?
  21. Nov 21, 2018 at 7:53 PM
    Fishman57
    Wayne
    Bucks County, PA
    Don't see anything on their site yet.
    https://www.12volt.solutions/
    eswartz[QUOTED] likes this.
  22. Nov 21, 2018 at 8:09 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    Randy posted this earlier on Facebook 76736504-FCA2-413E-8C2A-DADECEEF42D6.jpg
    eswartz, Fishman57 and KnuckleHD like this.
  23. Jan 17, 2019 at 9:11 AM
    bluecrab
    bluecrab New Member
    2017 Tundra Limited CrewMax TRD Black
    Thanks for all the feedback on the remote starter, I'm going to buy one for my 2017 Tundra Limited. :thumbsup:
  24. May 23, 2019 at 10:08 PM
    Mike Ha
    Mike Ha New Member
    I just installed mine today. SR5 with H key, everything work as advertised. But usually when i turn off the engine and hit the lock button the headlight will turn off right the way. Since installed remote started, somehow headlight still on after i turn off engine and hit the lock. Is it normal ? Did everyone experiments same thing or i just setup it wrong? Thank you for input!
  25. May 24, 2019 at 3:25 AM
    bluecrab
    bluecrab New Member
    On mine, if headlights set to auto and headlights are on, the headlights will stay on for a short period of time after first lock press. Headlights will turn off immediately upon second press.
    I believe this is called a "courtesy wait time" feature. Headlights stay on long enough to help you see to get inside your house.
  26. May 24, 2019 at 4:01 AM
    Fishman57
    Wayne
    Bucks County, PA
    Same for me.
  27. May 24, 2019 at 9:40 AM
    Mike Ha
    Mike Ha New Member
    Thank you for your reply. That make sense now. I thought I program it wrong or something because before installed remote start, headlight go off immediately after hit lock button.
  28. Dec 26, 2019 at 8:07 AM
    tharr1968
    tharr1968 New Member
    Tom
    Just installed in my 2017 SR5. Installation was straight forward. Removing the panel under the glove compartment was somewhat difficult. I lost my patience and broke one of the clips. Module programming presented a slight challenge. Follow the programming instructions EXACTLY as written. Be sure to plug in connectors coming from the BCM harness first BEFORE the large black connector from the main harness.
