18x9 0 offset?
Discussion in 'Wheels & Tires' started by 545moose, May 14, 2023.
  1. May 14, 2023 at 7:51 PM
    545moose
    545moose [OP] New Member
    Jon
    23’ Offroad
    23’ OffRoad and found some wheels that are seemingly too good to pass on, but skeptical on the zero offset. Planning to go with 3” plus lift with UCAs etc., but not sure if they’ll fit. Using the guides online they would fit 35x12.5 but I would be cautious and consider 295/305s first or 315; but don’t want to go less than 70 on the sidewalls. TIA
  2. May 14, 2023 at 7:55 PM
    ArticTundra
    ArticTundra New Member
    Cold
  3. May 14, 2023 at 8:09 PM
    545moose
    Jon
    23’ Offroad
    17s or 18s?
  4. May 14, 2023 at 9:40 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I run Goodyear duratracs . 285 75r18 they come in at 60 pounds and my wheels were 27 . zero offset wheels are nice cause they line up with my side steps
    emerson likes this.
  5. May 15, 2023 at 9:38 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Some RC Sport Flares would cover up that poke and keep the mud off the side panels :)
    Durtywrench likes this.
  6. May 15, 2023 at 9:43 AM
    Durtywrench
    Lou
    23 Tundra platinum
    None
    In time Because I like the painted flares I already have on the platinum ;)
  7. May 15, 2023 at 12:59 PM
    Nalwor
    Nalwor New Member
    2023 Tundra 1794 TRD OR
    18x9 0mm offset Icons wrapped in 35x12.50 Ridge Grapplers. 3" TRD lift. They fit just fine.
  8. Nov 16, 2023 at 12:12 PM
    13tundra!
    13tundra! New Member
    2013 Red Tundra Platinum
    Any body have these on a 2nd gen?
  9. Nov 16, 2023 at 7:53 PM
    Durtywrench
    Lou
    23 Tundra platinum
    None
    Any rubbing ?
  10. Nov 16, 2023 at 11:00 PM
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    9" wide wheels need to be around +20 to +25 offset if you don't want any rubbing issues.
    8.5" wide wheels you can get away with a +12 to +15 offset.
    I had a set of 20X9 0-offset ICON wheels and 37" tires with a 3.5" ICON suspension lift and high clearance Lil B's Hybrid front bumper and the tires would still rub. I now run a 17X8.5 +25 offset and never had any rubbing issues since replacing the wheels.
    Siblue likes this.
  11. Mar 29, 2024 at 8:52 AM
    LunarRckplati
    LunarRckplati New Member
    Tundra hybrid Platinum
    TRD 3 inch on 35's looking for TRD pro wheels!!
    I have the trd 3 inch lift and +18 offset wheels my tire is only 11.8 wide and 35 tall. I run my sway bar full lock to the right with the sway bar drop down bracket. Curious how the 0 offset 12.5 does? Does it rub on the sway bar or anywhere else in the fender?
  12. Aug 13, 2024 at 4:55 PM
    BayAreaTruckin
    BayAreaTruckin New Member
    San Francisco, CA
    What were you rubbing on? Did you body mount chop & pin the fender liner?
  13. Aug 13, 2024 at 5:31 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My tires are only 34 inches in diameter and they rub on my fender liner and modified mudflaps. I still have to take the heat gun to push them back. I have a 1.75" lift in the front as well.
    My wheels are 8.5" wide and +15 offset.
  14. Jan 18, 2025 at 6:30 AM
    emerson
    emerson New Member
    2022 TRD PRO
    Stock
    Looks awesome! What brand are the side steps?
  15. Jan 18, 2025 at 9:21 AM
    0 offset? I ran 18X9 0 offset with 285/70/18's on my 2013 with Bushwacker flares. I run the same on my 2020 with 295/70/18's.
    My 2013
    My 2020
