1st gen cold air intake
Discussion in '1st Gen Tundras (2000-2006)' started by TBinky, Jul 15, 2021.
  1. Jul 15, 2021 at 7:01 AM
    TBinky
    TBinky [OP] Wassup weirdos
    2000 black tundra
    Hi, I was wondering if any of you have put a cold air intake on your truck
    And if so do you like it?
    Did you notice a difference?
    Why are the ones I have looked at so expensive?
    And what have yall used?
    Thanks
  2. Jul 15, 2021 at 7:08 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The factory intake is the best one, believe it or not.
    I have the K&N with the black tube and cone filter. Does give a slight bump in mpg on highways, other than that it just makes cool sounds. I haven't used it in years, I went back to stock.
    I also have the airaid tube kit that connects to the factory airbox. Worthless. Makes a bit of noise and thats it.
    Volant makes a true cold air intake but its no better than the factory air box. The surface of the filter is small so there is no real gain. All it does is opens a hole in the airbox where hot air from you enhmgine can get in. You can do that to your stock box for free.
  3. Jul 15, 2021 at 7:16 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  4. Jul 15, 2021 at 7:18 AM
    TBinky
    2000 black tundra
    K thx
    Tundra2 likes this.
  5. Jul 15, 2021 at 3:11 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Tundra2 and Darkness like this.
  6. Jul 15, 2021 at 7:21 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    There is no denying that the mighty 4.7 sounds viscious with a CAI (let's call it HAI) but not at all worth the price.
    onesojourner and Tundra2 like this.
  7. Jul 16, 2021 at 8:40 PM
    toyoboyo
    toyoboyo New Member
    I have a Volant intake.. Hot air intake. It sounds cool, but it's extremely annoying while towing or on long highway drive that involves passing, hills/mountains. It will drone your ear out.
    Wish I had a stock intake. Lost mine.
    Darkness likes this.
  8. Jul 16, 2021 at 8:48 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    19477304_10155340959795275_1135715141473_b19e6d8a93b3fc0dac0fe51c078fa17e040d2252.jpg
    haters gonna hate. But, noticable difference. i didnt rebuild it after the header install. And ive got a couple templates made for the tundra, but ive gotta pull the airbox before i can finish.
  9. Jul 16, 2021 at 8:58 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    CAI are a waste of money, spend your money on something that will truly benefit your Tundra.
    tunyota and TILLY like this.
  10. Jul 16, 2021 at 9:00 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    :eek::eek::eek:
    FrenchToasty likes this.
  11. Jul 16, 2021 at 9:02 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I'm still trying to hunt down an air-aid intake tube for an 05-06 tundra. BUT that seems to be a pipe dream.
  12. Jul 16, 2021 at 9:12 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    You should just reroute all of your a/c vents into that to make it the coldest air intake. Then we can call you Mr Cool Ice.
    HBTundra, des2mtn, N84434 and 2 others like this.
  13. Jul 16, 2021 at 9:56 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    When i was running the aluminum tube i could wrap an ice pack around it, and the iat sensor. Really helped make the hill climbs around taos fun. Not srt4 fun, but more fun than a jeep is supposed to have on pavement.
  14. Jul 17, 2021 at 2:02 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Dudes doubled down since those pics
    onesojourner and Darkness like this.
  15. Jul 18, 2021 at 1:48 PM
    jberkut4
    jberkut4 Shake and Bake
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    I got one of those cheap vector Amazon cold air intakes on my truck, no complaints. Already have an exhaust on the truck so it did make it a little louder, pretty sure it increased gas mileage as well.
  16. Jul 18, 2021 at 1:54 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    The real cai is a snorkel
  17. Jul 18, 2021 at 2:29 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    AFE Pro S dry filter
    + airbox mod for 00-04
    Or
    + TRD air accelerator mod for 05-06
  18. Jul 18, 2021 at 5:43 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Here's the mod on my 05-06.
  19. Jul 19, 2021 at 9:28 PM
    Toy Undra
    Toy Undra New Member
    2001 Tundra SR5 4.7
    Hey There!
    I just installed a Specter CAI on my Tundra. As far as noticeable changes there are none to power. However you get the cool CAI sound when you WOT.
    The factory intake is great and I’m still holding on to mine. However I wanted the noise, I have money to drop, and it makes the engine bay look 1000 times better.
    I picked my CAI up through AutoZone pretty cheap. Whatever way you go just remember it’s your truck and do/build what you like.
  20. Jul 19, 2021 at 9:32 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Thats a very impressive engine bay.
    CascadeSkyline likes this.
  21. Jul 19, 2021 at 9:56 PM
    empty_lord
    05 rollover special
    Do tell me more about the 05-06 mod
  22. Jul 19, 2021 at 10:11 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    That’s a hot air intake, u lose HP with that one
  23. Jul 19, 2021 at 11:06 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
  24. Jul 19, 2021 at 11:13 PM
    empty_lord
    05 rollover special
  25. Jul 19, 2021 at 11:49 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    Greetings,@TBinky
    Thanks for posting. I am in agreeance with @FirstGenVol. I am of the opinion to keep these types of components stock and/or as close to OEM for the sake of reliability and drivability. I have previously installed intakes and K&N filters on my other vehicles and from those experiences I have now learned to resist the urge to fall for all the marketing wank this day and age. Do your truck a favor and stick with a Denso 143-3045 Air Filter. It will thank you by not burning unnecessary holes in your pockets and reduce the potential for problems into the future.
