1st Gen Double Cardan Joint Issue
Discussion in '1st Gen Tundras (2000-2006)' started by Deverett5, Nov 12, 2020.
  1. Nov 12, 2020 at 3:16 PM
    Deverett5
    Deverett5 [OP] New Member
    Dakota
    Hey guys I recently had a bad U joint and while replacing it I decided to replace them all on my 01 Tundra 4x4. I took the driveshaft to a shop to have them press out the old joints and I was going to press the new ones in myself. When I got the driveshaft back I noticed that there were NO Needle Bearings in the ball portion of the double cardan joint. When I asked the guy he said that there was nothing in there and that nothin had fallen out. From all the research I was able to do I was unable to find an example of a Tundra double cardan joint just other makes and models such as dodge and ford but also some other Toyotas which all had needle bearings. Did they ever make a truck without needle bearings in them? What are the main concerns if it is assembled without those bearing in there? Did the guy lie to me about them ever being in there?
    If anyone has pictures of their double cardan joint apart or a 1sy gen tundra joint in general I would greatly appreciate it for something I could show the guy.
  2. Nov 12, 2020 at 3:27 PM
    Professional Hand Model
    Hand Protectors
    The ball (is all) from what I’ve read. Its a special joint from my understanding.
    You having fun doing this or wish you had let the shop do it?
    FrenchToasty likes this.
  3. Nov 12, 2020 at 3:33 PM
    Deverett5
    Dakota
    So you think it's just the ball without any needle bearings? Yes I know it's a special kind of joint. I have not assembled it yet because of my worry that there were no needle bearings in the ball when I had gotten it back. I don't mind pressing the u joints in just want to make sure its correct with those bearings.
  4. Nov 12, 2020 at 3:54 PM
    Hand Protectors
    I’ve never done one before so can’t vouch. I did speak with a Heavy Service Shop (big trucks) that specializes in drive shafts. Guy said there is a special bearing in that spot with a ball. Thats all I know from 2 years ago when curious about this job. My double cardan shaft is still original with no problems. I grease it on the regular.
    On the front 4x4 drive shaft I made special grease tip for fitting those particular zerks by grinding/shaving some off the side of the tip.
  5. Nov 12, 2020 at 3:55 PM
    Hand Protectors
    Post up pics man! We can learn from you.
    MS22 and FrenchToasty like this.
  6. Nov 12, 2020 at 4:08 PM
    Deverett5
    Dakota
    This is the joint.
    MS22 and Professional Hand Model like this.
  7. Nov 12, 2020 at 4:14 PM
    Hand Protectors
    Good pics. Never seen that angle. If there were needle bearings, then where would they go?
  8. Nov 12, 2020 at 4:17 PM
    Deverett5
    Dakota
    they would go on the inside of the ball like this one
  9. Nov 12, 2020 at 4:38 PM
    Hand Protectors
    Looks like needles in there.
  10. Nov 12, 2020 at 5:14 PM
    Deverett5
    Dakota
    Yup, which is why I think the guy I brought it to is just lying to me about no needle bearing being in there.
  11. Nov 12, 2020 at 5:16 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    bmf4069 and Deverett5[OP] like this.
  12. Nov 13, 2020 at 4:46 AM
    Hand Protectors
    Only way to know is buy a new one and check it out.
    Was your Drive Shaft working properly before removing?
  13. Nov 14, 2020 at 3:23 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I haven't had mine apart so don't have any first hand experience. But since you're installing all new joints throughout the shaft, wouldn't it make sense to replace this one too?
    Tundra2 likes this.
  14. Nov 14, 2020 at 6:18 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    My drive shaft shop (a Spicer dealer) told me that there were no parts available for the double cardan joint. He also told me mine was OK, and so I left it alone.
