1st Gen Sequoia Front Suspension Swap
Discussion in 'General Sequoia Discussion' started by Dogman5687, Nov 14, 2024.
  1. Nov 14, 2024 at 12:16 PM
    Dogman5687
    Dogman5687 [OP] New Member
    2007 Seqouia SR5 2WD
    Hey all,
    I did a few keyword searches here and couldn’t find an answer to my question, so if anyone has anymore info I would appreciate it.
    In short: can you swap the suspension components from a 2nd gen or higher into a 1st gen to take advantage of the improved LBJ design?
    I’m due to replace LBJs, control arms, and struts anyways, so if I can make an upgrade without too much hassle or an exorbitant I would probably go in that direction.
  2. Nov 14, 2024 at 12:42 PM
    2000 Limited TRD AC 4X4 Thunder Grey 277k miles. *SOLD* 2019 Limited TRD CM 4x4
    Nope. Not at all the same frame setup. Now, anything is possible if you believe in yourself and try hard. And have a cutoff wheel and welder.
    Sirfive likes this.
  3. Nov 14, 2024 at 1:31 PM
    Dogman5687
    Thanks, that’s what I figured since I don’t see anything on the forum.
