1st Gen Toyota Tundra Double Cab 2005 Driveshaft Question
Discussion in '1st Gen Builds (2000-2006)' started by Axor01, Oct 18, 2024.
  1. Oct 18, 2024 at 9:05 AM
    Axor01
    Axor01 [OP] New Member
    Hi there,
    I need to replace the driveshaft. Recently I purchased Dorman part #:986-130 driveshaft. I thought I'm buying the whole shaft already assembled, however, I received the shaft that is split in two parts. I'm not sure if I like this set up. I'm attaching the pictures. Is this kind of shaft any good?
    Thank you, ALL!
