1StGen headlight and fog light LED conversion!
Discussion in '1st Gen Tundras (2000-2006)' started by rwds13m, Sep 19, 2019.
  1. Sep 19, 2019 at 4:50 PM
    rwds13m
    rwds13m [OP] New Member
    Tundra
    2006 Tundra Crew Cab Sr5
    I purchased brand new headlights for my 2006. While I was at it I decided to get some hEad light LED 9003’s and some fog light 9006’s. I had a feeling something would start to act up due to the much lower resistances but I didn’t want to order the solution until I verified. Verified! Turn on headlights and they work. Turn on fog lights and they don’t turn on but does activate my high beams. All in all, I ordered some inline resistors to put some load on the system. Hopeful just the headlight ones will do. Wish me luck ✌️ 30045841-8BB6-440F-B243-D58BD2C4FA20.jpgFresh 67A18298-64BA-4E89-8E70-504FC61B64CB.jpg Installed (sorry truck has been sitting and a bit dirty )
  2. Sep 19, 2019 at 5:06 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Yep. I had the same issue with my Beamtech LEDs. I emailed Beamtech & they sent me the resistors for free. Check with your vendor.
  3. Sep 19, 2019 at 5:53 PM
    rwds13m
    Tundra
    That’s incredible customer service. I already ordered the resistors and my LEDs although heavily researched were purchased from eBay (doubt they would do anything for me). I will definitely keep “Beamtech” in mind for any future LED purchases. Thanks for that info
  4. Sep 21, 2019 at 11:22 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Can you guys with LEDs post wall output shots? I tried LED bulbs in my pops', now mine, 06 DC before retrofitting and the light pattern was atrocious. That was several years ago. I wonder if the newer bulbs are any better.
  5. Sep 22, 2019 at 8:00 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    What the ostrich said sounds reasonable. We need some output shots!
    :worthless:
    bmf4069 likes this.
  6. Sep 22, 2019 at 9:21 AM
    artsr2002
    'Yonder
    Just for the love of all that is holy don't post shots of the blinding lights themselves. Like duh we know what the lights look like and that they will be bright as hell but what does their output look like. Park perpendicular to a flat wall about 25 feet away and show us what the light output looks like from the drivers point of view. I've had to say this on so many forums for different vehicles over the years because folks will post headlight pictures instead of output shots. Lol.
    Trailscape, Volt92, Pudge and 2 others like this.
  7. Sep 22, 2019 at 12:56 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I'll see what I can do tonight
    TX-TRD1stGEN likes this.
  8. Sep 22, 2019 at 4:05 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Posting my projector HID for reference. The bar has been set my friends :hattip:
    Pudge, tacoguybill, 00TundraZ and 4 others like this.
  9. Sep 22, 2019 at 4:57 PM
    KarmaKannon
    Utah
    Some junk
    If that's the bar then we should judge factory Bilstein struts against my front end.
  10. Sep 22, 2019 at 7:23 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Idk if that means mine are good or bad :drevil:
    KarmaKannon[QUOTED] likes this.
  11. Sep 22, 2019 at 7:54 PM
    KarmaKannon
    Utah
    Some junk
    It means changing a bulb is a lot easier than doing retrofits. Kinda like changing a strut is easier than rebuilding a whole front suspension.
    Darkness[QUOTED] likes this.
  12. Sep 23, 2019 at 2:09 PM
    rwds13m
    Tundra
    Sorry guys. I wasn’t trying to show the quality of HID s just yet. I want to get them working properly if not what’s the point? With that said the H4 resistors that I purchased were useless. With the resistors plugged in line from trucks harness to bulb harness they bulbs would not light up. Removed them again which brought me back to the same issue I had initially. May be the resistors I purchase ? Any ideas?
  13. Sep 23, 2019 at 2:34 PM
    rwds13m
    Tundra
    As soon as I get them functioning properly I’ll take a pic for you guys. Still working on getting my fogs to work with the LEDs.
  14. Sep 23, 2019 at 3:00 PM
    rwds13m
    Tundra
    I found these on eBay. The reviews actually mentions these properly working when others didn’t on a 2003 Sequia. I’m hoping this is my easy fix. I may remove the LEDS if these don’t fix my issue.
  15. Sep 23, 2019 at 4:20 PM
    KarmaKannon
    Utah
    Some junk
    The plug in resistors that beamtech sent me fixed my issue with my fogs not working. Maybe that's worth a try?
  16. Sep 23, 2019 at 6:42 PM
    rwds13m
    Tundra
    Is there a part number or anything on it? Maybe a link to the one you have specifically? I’ll wait for the one I ordered to arrive so that I can test it. If it doesn’t work I may give the beamtech one a shot before going back to factory lights.
  17. Sep 23, 2019 at 8:17 PM
    KarmaKannon
    Utah
    Some junk
    I don't have a link because I just purchased the beamtech led conversion off Amazon and when the fogs acted up I contacted beamtech and they sent me the resistors for no extras charge.
    Darkness and tacoguybill like this.
  18. Sep 26, 2019 at 11:30 AM
    rwds13m
    Tundra
    Success! The second set of resistors worked great. Everything functions as it should now . Very excited about this. These don’t really have a name brand but if you search “h4 resistor” it should come up. Should look just like what’s pictured. I WILL BE TAKING PICTURES OF LIGHTING AT NIGHT FROM DRIVER SEAT ✌️
  19. Sep 26, 2019 at 12:18 PM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Are you happy with the beamtech's? Do you feel like they were worth it with factory housings?
  20. Sep 26, 2019 at 12:37 PM
    KarmaKannon
    Utah
    Some junk
    For the price and difficulty I'm extremely happy. It's not like driving my wife's MB with steering headlights and automatic brights, but it is a big improvement over the factory style bulbs I had. For under $50 it improves my vision a lot and doesn't seem to piss anybody off or blind the cars in front of my any more than any truck does just from having the headlights at head level in the car.
    00TundraZ[QUOTED] likes this.
  21. Sep 26, 2019 at 12:39 PM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Perfect answer. I don't expect to have headlights that beat MB or the new LED offerings everyone has now, just an improvement over stock is nice.
    Thanks for the reply, I really appreciate it!
  22. Sep 26, 2019 at 12:40 PM
    KarmaKannon
    Utah
    Some junk
    Exactly. I was realistic with my goals and subsequently very satisfied.
  23. Sep 26, 2019 at 1:31 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Like the new headlights and will look into LED/Fog Light. Would love to change out my 2004 even tho I just recently finished making them almost like new with 3M kit.
    Where did you get these new head lights. ?
  24. Sep 26, 2019 at 2:19 PM
    SoCalPaul
    Paul
    Beamtech in OEM buckets
  25. Sep 26, 2019 at 5:34 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    That's just about the height of a cars back window! :eek:
    Bright!! :sorry:
    Darkness likes this.
  26. Sep 26, 2019 at 8:13 PM
    SoCalPaul
    Paul
    Just below. I stood out about 30 yards and they are fine, low glare.
  27. Sep 27, 2019 at 5:35 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The more I look at this I think that the Beamtech's are a lot better than the ones I installed last week. I'll be removing mine tonight and trying the Katana's. I'll post pictures of both.
    I like the fact that yours are fanless.
    speedtre, KarmaKannon and Darkness like this.
  28. Sep 27, 2019 at 6:24 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looks pretty good
  29. Oct 5, 2019 at 2:31 PM
    Professional Hand Model
    Hand Protectors
    Blue tape on the door (lower pieces) is the the level height of the SAE little circle for aiming on the lens assy.
    Truck is backed away from the garage door about 23ft. with LOW BEAMS and Fogs Lights in ON position.
    Katanas LED headlights and Perfect Fit Fogs. Akkon lens assys. No resistors needed. 2002 Tundra.
    Check my build page for more pics. I’ve done mucho light research and actual experimentation.
    https://www.tundras.com/threads/the...vestment-‘build’-a-chronological-story.46816/
    Very happy with this set up. Not perfect, but way better than it ever was when new (and better than many cars on the road).
    Akkons $155
    Katanas $50
    Perfect Fits $129? (Fanless). My favorite light source are the fogs as the 2002 OEM assy put out a 220° surrounding light.
  30. Oct 5, 2019 at 2:39 PM
    Hand Protectors
    BTW, there is a new Fog Bulb on the market that has 4 color options. No need for colored lenses! Someone buy these and test them out. Good reviews.
    tacoguybill, Darkness and Pinay like this.
