2 10s in a sub box behind crewmax back seat
Discussion in 'Audio & Video' started by learnem, Jun 17, 2019.
  1. Jun 17, 2019 at 7:03 AM
    learnem
    learnem [OP] New Member
    Bakersfield, Ca
    16 Tundra crewmax
    3 in lift, 2in wheel spacers. Tinted all the way around Stock platinum wheels and tires
    Has anyone in this forum been successful in being able to put a sealed speakerbox that holds 2 10in woofers that aren't shallow mount behind the rear seat in a 14-18 crewmax?
    Pinay likes this.
  2. Jun 17, 2019 at 7:06 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I did.
    I had it installed so not sure what they put in
    You can contact Infinite Audio in Macedon NY to see what they use.
    315-986-1111
    Iknow they were 2 10" JL Audio
  3. Jun 17, 2019 at 7:11 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Yup. Fox Acoustics make a box for us and I have it installed on my ‘15...with two 10” Kicker subs
    Edit: Kickers are shallow subs but they are powerful!!
    TundraMaxMan and McMason like this.
  4. Jun 17, 2019 at 7:16 AM
    Jmmtjoy
    Jmmtjoy Livin the dream
    Bristow, Virginia
    2016 Crewmax SR5 Super White
    Probably the 10TW3 JL Subs. Which are shallow mount subs.
  5. Jun 17, 2019 at 7:17 AM
    Jmmtjoy
    Bristow, Virginia
    It would be tough to get a full depth sub behind those seats. I don't know if its worth it really with the shallow subs available.
  6. Jun 17, 2019 at 8:24 AM
    Cfincke
    San Antonio
    2 JL 10w1 subs. Box and subs came from James at tech12volts
  7. Jun 17, 2019 at 8:31 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Pretty easy to put two shallow subs behind there.
    I've got the jl stealthbox and it sounds great.
  8. Jun 17, 2019 at 1:51 PM
    mr_clark
    mr_clark New Member
    2018 Black Tundra Limited
    Exactly what I got. Absolutely love it. Not over the top bass.
  9. Aug 1, 2019 at 12:04 PM
    learnem
    Bakersfield, Ca
    16 Tundra crewmax
    So i found a seller on ebay that sells mobile audio equipment, including speaker boxes.
    I went with full size 10" rockford fosgates, due to the 4.5 in mounting depth of the box. The RF woofers measured 4.3 in in depth. There is still 1.5 - 2 in left behind the seat, from what i can tell. Each woofer has more than the required airspace to run them.
    When I began this quest, i initially purchased 2 amps, both US Acoustic products. A 1500w @ 1 ohm mono amp called Mike, and a 4 channel amp that runs 175 watts per channel, called Barbara Ann.
    After being in my buddies shop for 2 days, he called me to tell me that the four channel amp isn't compatible due to me having a Platinum, which has its own amp and subwoofer (shitty tiny sub imo), but the high end is fabulous.
    So, I'm running the high end with the 440 watt amp that came in the platinum, with the mike running the lows.
    Mind you since i was 17, i have always had systems with multiple amps in all my vehicles, and by far, the setup i am running currently is by far the best and cleanest i have had.
    Non platinum owners, i recommend running an amp dedicated to highs and mids, and a mono amp of at least 1000 watts to bass. You will not be disappointed with this setup,unless you run shitty power and shitty components.
    BrownBomberTT likes this.
  10. Aug 1, 2019 at 12:08 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Yes.
    Two 10" MBQuart shallow subs in a Q bomb box.
    20SilverTundra likes this.
  11. Aug 1, 2019 at 12:14 PM
    learnem
    Bakersfield, Ca
    16 Tundra crewmax
    AVLeaderz_com is the seller on EBAY
  12. Aug 1, 2019 at 12:16 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I had an Alpine type R T in my last car. It sounded great and was a shallow mount sub that would be perfect in the Tundra.
  13. Aug 1, 2019 at 1:08 PM
    hypa
    hypa New Member
    I have a pair of 12" behind my seat, so a pair of tens shouldn't be much harder to do.
    I'm running the ********* 12" box. I also have an enclosure for a pair of tens, but haven't swapped them out yet.
    Bottom line, yes you can fit a pair of 10" back there.
  14. Oct 17, 2024 at 5:58 PM
    JeffsTundraFTW
    JeffsTundraFTW New Member
