20” Fuel Wheels w/Ridge Grapplers
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Arminius, Jan 29, 2022.
Thread Status:
Not open for further replies.
  1. Jan 29, 2022 at 2:01 PM
    Arminius
    Arminius [OP] New Member
    2019 Tundra Crewmax Limited OffRoad
    2.5 Kings OEM, no adjusters, ICON RXT Leaf Pack - Option 1, Fuel wheels, 285/60/20 Nitto Ridge Grapplers E load rating Light Truck, TRD duel exhaust, TRC cold air intake, TRD Pro grill
    SOLD
    $1,500 Thousand Oaks California
    Price lowered by $400. 1-31-2022
    Set of 4 Fuel 20x9 wheels SKU: 2950126924 with mounted Nitto Ridge Grapplers 285/65/R20 E. Black lug nuts included. Tire Pressure Monitors NOT included.
    WHEELS:
    Fuel D-704 Siege 1PC Gloss Black with Machine Faced & Double Dark Tint. 20x9 +20 Offset 5x150, 110.2mm Hub.
    Excellent condition, no curb burn or damage. Couple of small nicks I tried to capture in the pictures. Hard to see unless you are close up. Can be easily touched up with matching paint.
    TIRES:
    Nitto Ridge Grapplers. 285/65/R20 E load rated with 13/32” (16.4mm) tread depth remaining. Approximately 13,000 miles, all on road. Never used off road. No punctures, plugs, tire repairs, or fixaflat ever.
    Tires were on my 2019 Tundra Limited with a leveling kit, and the front mud flaps removed and had no rubbing or clearance issues.
  2. Jan 29, 2022 at 3:05 PM
    rattmobbins
    rattmobbins New Member
    2021 Platinum 4x4
    Pics on the truck? Where you located? Include TPMS?
  3. Jan 29, 2022 at 3:45 PM
    Arminius
    I’m in Thousand Oaks. TPMS not included.
  4. Jan 30, 2022 at 1:12 PM
    Balrz
    Balrz New Member
    Ryu
    New 2020 Tundra crewmax off-road premium
    What lift do you have?
  5. Jan 30, 2022 at 2:17 PM
    Arminius
    It was just a 1.5 inch lift in the front to level it out.
  6. Jan 30, 2022 at 7:09 PM
    Balrz
    Balrz New Member
    Ryu
    what did you use to level it?
    I’m contemplating using some Blistein 5100’s to level it out.Did you get any rubbing with that size tires?
  7. Jan 30, 2022 at 7:43 PM
    Arminius
    I first had the Falcon Teraflex sport shocks on it. That what was on it in the picture. I now have the TRD Pro Fox shocks and the Westscott kit.
  8. Jan 30, 2022 at 7:44 PM
    Balrz
    Balrz New Member
    Ryu
    So what’s your lift size now?
  9. Jan 30, 2022 at 8:16 PM
    Arminius
    The rear is +1” and the front is between 2-3” over stock. To make these tires fit you really only need about a 1” lift in the front and removal of the front mud flaps. These Nittos are pretty quite for an all terrain tire. I ran them at 35 PSI but you can go higher if you need to because they are E rated E.
  10. Jan 31, 2022 at 2:30 PM
    Arminius
    BUMP for $700 price drop. I guess wheels depreciate more than I realized.
  11. Feb 6, 2022 at 2:18 PM
    Arminius
Thread Status:
