20" TSS Rims on a 2010 Crewmax, Tire Size?
Discussion in 'Wheels & Tires' started by SpinFish1, Feb 9, 2022.
  1. Feb 9, 2022 at 9:55 AM
    SpinFish1
    SpinFish1 [OP] New Member
    2010 Tundra Crewmax TRD
    Morimoto XB LED Headlights
    Hey, I have a question maybe you can help?
    I have a 2010 Crewmax TRD with front adjusting Bilstein 5100's so the frontend has been raised approx. 1.5". The back is stock height. (The 5100's have reduced some rake and it sits "slightly" more level).
    I'm planning to remove the 18" stock wheels and put on the Toyota TSS 20" wheels. I want to go with a larger tire, I've seen some with stock size, 275/55/20.
    *My question, Will a 285/60/20 be too big? Tire calculator says its 33.5" tall.
    Thanks!
  2. Feb 9, 2022 at 12:46 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Should be fine. I run 33.4 tall tires (18inch wheels) on my stock 2016, no issues or rubbing of any kind.
    Black Wolf likes this.
  3. Feb 9, 2022 at 2:24 PM
    SpinFish1
    Thank you, I'm just trying to get confirmation before I start ordering tires.
