20in wheels offset
Discussion in 'Wheels & Tires' started by HornetOne3, Mar 15, 2017.
  1. Mar 15, 2017 at 10:59 AM
    HornetOne3
    HornetOne3 [OP] New Member
    Columbus ,Ohio
    2016 Barcelona red Crewmax SR5
    Hi everyone ,
    I'm about to upgrade my wheels and tires and I would like to have someone with their 20in wheels post the pictures with the offset . I'm looking at the Anthem matte black A722 20x9 -12 offset with Nitto
    Ridge Grapller 295 60r 20 tires
    Would like to have a look at your pictures with the offset of -12 and/or +18 so I can get some ideas how far they'll stick out .
    Please also list how much lift amount and trimming you've done to your truck in order to clear any rubbing
    Thank you very much in advance !
  2. Mar 15, 2017 at 11:01 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  3. Mar 15, 2017 at 11:10 AM
    HornetOne3
    Columbus ,Ohio
    Thank you sir. I'm really appreciated !
    joonbug likes this.
  4. Mar 15, 2017 at 11:17 AM
    HornetOne3
    Columbus ,Ohio
    May I also ask . If I intended to do the lift more than 3 1/2in will I have to replaced the UCA as well for alignment purposes or is it not necessary ?
    Thanks again !
  5. Mar 15, 2017 at 11:19 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It is highly suggested if you want the alignment in spec.
    NewImprovedRon likes this.
  6. Mar 15, 2017 at 11:32 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Just chiming in on "if" you'll need to replace your UCA's above 3" = yes. I have been advised by several shops that if I go 3" or above I'll need new UCA's. You could not do the UCA's and you're alignment will be all out of wack and you'll burn through a new set of tires every couple of months.
    I'm in the process of doing a 3-½" in the front and 1" in the rear with new UCA's and rear shocks so I've asked everyone from every shop in town and on this forum the same question.
  7. Mar 15, 2017 at 12:39 PM
    HornetOne3
    Columbus ,Ohio
    Thank you so much for your inputs gentlemen . This is a great site to learn and share info .
    Best regards
  8. Mar 15, 2017 at 3:30 PM
    Vg1979
    Vg1979 New Member
    Victor
    2015 tundra crewmax 4x4
    Leveled and wheels
    My truck was leveled at the dealership. The tires are 305/55 r20. The rims are onyx RO95but I'm not sure of the back spacing.IMG_20170312_211910_586.jpgScreenshot_2017-03-15-17-29-08.jpg
  9. Mar 15, 2017 at 4:22 PM
    chphilo
    chphilo Tundra addict
    Western PA
    My wheels are 18x9 with 18 mm offset with 295/70/18. Lateral position should be the same as 20 inch wheels with the same offset.
  10. Mar 15, 2017 at 4:22 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    Here are my 20's. They are 37x12.50x20,offset is+20. They don't stick out that far.
  11. Mar 16, 2017 at 12:31 PM
    Tommy B
    Tommy B New Member
    Hey Vg1979 are you saying all you did was level the front of your truck and you put 305-55-20 under it? Any cutting or bending? Does it rub? I'm trying to go 295-60-20 so any info you can provide is appreciated.
  12. Mar 16, 2017 at 12:34 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    here's my 20x9 +18 mounted on 295/60/20
    TNTundra16 and (deleted member) like this.
  13. Mar 16, 2017 at 3:44 PM
    Tommy B
    Tommy B New Member
    Man that looks good. That for the pics. Did you lift, level, or have to cut anything?
  14. Mar 16, 2017 at 5:01 PM
    HornetOne3
    Columbus ,Ohio
    What kind of lift do you have and is there any trimming involved at all ...
    Thank you !
  15. Mar 16, 2017 at 5:02 PM
    HornetOne3
    Columbus ,Ohio
    Love that MGM look and those wheels too ...
  16. Mar 16, 2017 at 5:05 PM
    HornetOne3
    Columbus ,Ohio
    Thank you CHPHILO !
  17. Mar 16, 2017 at 5:23 PM
    Vg1979
    Vg1979 New Member
    Victor
    Leveled and wheels
    It's came from the dealer that way. It appears to be only leveled. There has been no cutting from what I can see. It does rub a little in reverse when the wheels are turned all the way. I just make sure and not turn them all the way
  18. Mar 16, 2017 at 7:13 PM
    Tommy B
    Tommy B New Member
    Nice appreciate the reply. I'm gonna go 295-60-20 and cross my fingers.
  19. Mar 16, 2017 at 7:28 PM
    Vg1979
    Vg1979 New Member
    Victor
    Leveled and wheels
    I'm sure you will be fine. Good luck and send some pics!!!
  20. Mar 16, 2017 at 7:30 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    3"/1.5". Yes, I removed the mud flaps, pushed the liner forward, and heated it with a heat gun to push it in further. But, +18s on these tires clear the cab mount without having to do a CMC
  21. Mar 16, 2017 at 7:32 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    295/60/20 is a common size for 20s with at least 2.5" lift
    According to Cooper's site, my STT Pros are 34.3"
  22. Mar 16, 2017 at 7:50 PM
    Tommy B
    Tommy B New Member
    Ordered it March 1st so still have about 4-6 Wks. I'll post as soon as I get it.
  23. Mar 16, 2017 at 9:43 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    My 20x9 +20 with Toyo ATII's 295/60
    Very happy with this set up, but wish I might have gone with +1 since I'm thinking about installing fender flares.
    SuperSilverTundra likes this.
  24. Mar 17, 2017 at 10:33 PM
    Tommy B
    Tommy B New Member
    Nice rig
    r4z0r51o likes this.
  25. Mar 17, 2017 at 10:46 PM
    HornetOne3
    Columbus ,Ohio
    Your Silver Sky looks really good with that set of wheels . It' always been my favorite color but some how I've ended up with a Barcelona red .
    r4z0r51o[QUOTED] likes this.
  26. Mar 25, 2017 at 11:12 AM
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    Bilsteins 6112 top setting, 0.5" Coach builder shims, 5160 rear shock with 3" Coachbuilder shackle kit. RB20 Step bars, Forged TRD Pro wheels, Back flip cover, Kennwood 10" Head unit, 2JL 10" Subs, Alpine 6 channel Amp.
    20x9 +25 offset XD Grenades. 305/55/20 cooper SST Max Just picked them up and I love them.IMG_6986.jpgIMG_6981.jpg
    Jsena, sawzalot and NewImprovedRon like this.
  27. Mar 25, 2017 at 3:05 PM
    ChadGrissom
    ChadGrissom New Member
    2012 Texas Edition Crewmax
    Bilstein 5100 front (Level) and back, K&N Ram Air Intake, Flowmaster Cat back dual, Toyo 295/65R20 on XD Misfit 20X9
    I'm running Toyo OC 295/65R20 on 20x9 XD Misfits with a 0 offset, even with the fender flares they still stick out about 3/4", with out the fender flares about 1.25"
  28. Mar 25, 2017 at 4:58 PM
    Tommy B
    Tommy B New Member
    Do you have lift? If so what size?
  29. Mar 26, 2017 at 11:07 AM
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    I like these fender flares. What kind are they? They don't look as aggressive.
  30. Mar 26, 2017 at 2:15 PM
    ChadGrissom
    I couldn't tell you bro, they came with the Texas Edition and I left them on
