21 TRD Pro TPWS sensor reset
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by a_double, Jul 31, 2023.
  1. Jul 31, 2023 at 10:23 PM
    a_double
    a_double [OP] New Member
    Does anybody have an issue with using the TPWS reset function on their factory installed sensors?
    I have the discreet (look like a regular rubber valve stem) sensors, they triggered the warning the day I bought the truck, on the drive home. I returned to the service department to have them programmed using the tech tool (forget the name). Since then, I've added aftermarket wheels with Toyota sensors (but not the rubber valve stem types). The dash mounted reset button worked on these.
    Now, I have my original wheels on and the dash mounted reset function doesn't work. I'm probably at square 1 and need to get them programmed at the service department but that's not acceptable to me since there's a dash function for this.
    Has anybody experienced similar TPWS reset issues? If so, what's the resolution? Thanks in advance.
  2. Jul 31, 2023 at 11:05 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Turn vehicle to "on" and not actually start it. Wait until TPMS light finishes flashing, takes a few minutes. Switch screens to tire pressure screen. Hit TPMS reset button until message changes "calibrating". Turn truck on, idle or drive until TPMS system is reset and PSIs show up (can turn "off" then actually start and it's fine). If this doesn't work then sensors may not be compatible/out of battery but highly unlikely in this scenario as they are the original sensors.
    a_double[OP] likes this.
  3. Aug 1, 2023 at 10:23 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Do your original factory wheels have the original TPMS sensors or did you get a new set of sensors for those wheels?
  4. Aug 1, 2023 at 10:52 AM
    a_double
    Original sensors in the original wheels.
