21' Tundra Wired Carplay Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by TG504, Jun 7, 2023.
  1. Jun 7, 2023 at 7:44 AM
    TG504
    TG504 [OP] New Member
    Louisiana
    2021 White Tundra TSS
    I'm having issues when plugged in via usb and keeping a connection with apple carplay. As a software engineer ive tried all routes with the software in the infotainment system including trying to update the firmware and the gracenote database, and my iphone is up to date. It connects at first, plays music, and then loses the connection, then gains it back again, then loses it, and gains it back again. At some points carplay is on the screen but isnt playing the music from the car but is from my phone- Weird. Ive went through all the settings, forgot the phone on the infotainment system and forgot carplay on the phone end, restarted the infotainment numerous times, and its not the cord either... Stumped..
    Thinking maybe it could be the actual usb port? Idk.. Hoping there is some fix out there i'm not aware of. I know toyota dealers aren't the answer lol. Any/all help is appreciated. Thanks in advance!
  2. Jun 7, 2023 at 7:57 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Mine is weird sometimes, too. It will just not recognize that the phone is plugged in. It doesn't happen all the time, but still I'd love to figure out a way to make it never happen again. A quick reset of the infotainment system (hold down the volume/power button until it restarts) fixes it for me.
    V3N0M and TG504[OP] like this.
  3. Jun 7, 2023 at 8:15 AM
    TG504
    Louisiana
    Yea I tried two new OEM apple usb to lightning cables (1-1m and 1-3m).. Lightning port is clear, and usb port is clear of debris. Im thinking this is more than likely a toyota software issue and that apples latest ios releases are ahead of the firmware in the infotainment system.
    ryanwgregg and Terndrerrr like this.
  4. Jun 7, 2023 at 8:17 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Ditch that garbage stock head unit and get yourself a Kenwood Excelon with wireless CarPlay. Works flawlessly and sounds amazing.
    V3N0M likes this.
  5. Jun 7, 2023 at 8:22 AM
    TG504
    Louisiana
    That may be my next move. @gizardlizard how does it look in the dash? Any pics?
  6. Jun 7, 2023 at 8:27 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    I can shoot you some pics tonight when I get home from work. It was worth every penny.
  7. Jun 7, 2023 at 8:28 AM
    TG504
    Louisiana
    Thanks!
  8. Jun 7, 2023 at 8:58 AM
    grussell
    grussell New Member
    Garry
    Florissant, CO
    2021 Tundra SR5w/ Leather
    I had this problem with Android Auto. I was using an aftermarket cable. Switched to a Samsung cable and problem was solved.
  9. Jun 7, 2023 at 4:20 PM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    bradleypc-12 and TG504[OP] like this.
  10. Jun 7, 2023 at 4:22 PM
    JediMedic86
    JediMedic86 New Member
    Cole
    2021 Cavalry Blue Tundra SR5
    Rough Country rear bumper, AJT interior products, TufSkinz interior products, BakFlip bed cover, BedRug full bed liner, Rough Country 2” strut leveling kit with rear N3 shocks.
    My ‘21 has been doing the exact same thing. I was wondering if it’s an iOS issue after the most recent update. Prior to that update I never had issues.
    TG504[QUOTED][OP] and ryanwgregg like this.
  11. Jun 7, 2023 at 4:32 PM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    My 21 was rock solid before the 1st update. It has randomly dropped Android auto connection quite a few times since. Some days I reboot the head unit and that helps. Other days it will do it a few times and stop. Somedays keeps connected all day without issue.
    TG504[OP] likes this.
  12. Jun 7, 2023 at 7:43 PM
    grussell
    grussell New Member
    Garry
    Florissant, CO
    When was the last update?
  13. Jun 8, 2023 at 12:59 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I know you really weren't asking about a wireless option... However, a couple of other forum members recommend the Ottocast wireless adapter to me when I was complaining about connectivity issues. My issues were a little different than yours; I was having issues w/car play not re-engaging after turning the truck off or unplugging the phone to do something then re-connecting it. Also, I was having problems w/being able to scroll through playlist songs and other similar problems.
    Anyhow, I went w/the following adapter which just stays plugged in constantly, and I haven't had any issues since. I've been very happy w/it, and it may be worth looking into if you're not wanting to replace the entire head unit (which I believe is the source of most of our woes)...
    OTTOCAST Wireless CarPlay Adapter for iPhone - 2022 Upgrade Wired to Wireless Apple Carplay Dongle - 5GHz WiFi, Low Latency, Plug & Play, Online Update
    *** just note that there are 2 versions of this adapter. The link should give you the correct one, but be sure you're getting the U2-Air (not the A2-Air).
  14. Jun 8, 2023 at 2:39 PM
    SwitchThrottle
    TG504[OP] and Tripleconpanna like this.
  15. Aug 3, 2023 at 3:19 PM
    TG504
    Louisiana
    Update: Finally got around to updating the firmware. You have to re-format the usb drive from exfat to msdos fat (fat32) if you are downloading the software via mac.. exfat will not work on 2-2.5 gen tunnies. After the update- no issues. Thank the lord. Hope this helps someone else having the same issue!
  16. Aug 15, 2023 at 6:49 PM
    bradleypc-12
    bradleypc-12 New Member
    2020 Grey Tundra TRD off-road pkg.
    I started having connection issues after updating to version 1383. I’ll try the reboot and see what happens.
  17. Aug 15, 2023 at 9:47 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    I didn’t have connection issues - at least not that I know of.
    After updating my phone to iOS 16.5 I lost all physical controls while using CarPlay - none of the steering wheel controls or the head unit volume knob would work. It made CarPlay completely unusable. All controls worked fine when using any other audio source.
    I tried several different Apple cables, as well as 2 other phones. Made sure the head unit was updated with the latest firmware. Spent hours on the phone with both Apple and Toyota, with no one taking responsibility or offering a solution. Apple especially put in the effort to try to resolve it, but ultimately said it was Toyota’s problem.
    Ultimately I replaced the head unit with a new Kenwood and couldn’t be happier, although I haven’t spent much time in the truck due to a back injury that keeps me from doing much of anything.
  18. Aug 16, 2023 at 4:40 AM
    SwitchThrottle
    Mine has been pretty solid since the update to 1383. No random disconnects. I'm on a Note S20 if that helps.
  19. Aug 16, 2023 at 6:52 PM
    bradleypc-12
    I use an iPhone 12.
  20. Sep 7, 2023 at 5:12 PM
    Terndrerrr
    Music City
    6UR-FE
    Mine has started disconnecting and reconnecting back and forth. The link for the new firmware is here:
    https://www.toyota.com/firmware-updates/download
    Thanks for this. I’m going to reformat my usb drive for this.
  21. Sep 7, 2023 at 6:22 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Kenwood has issues too. You still have the random head unit powering off, or wireless playing but it turns your phone speakers on instead of truck’s speakers.
  22. Sep 8, 2023 at 4:03 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    I have yet to have one single issue with my Kenwood. Been working flawlessly for over a year.
    fyrfytr26 likes this.
  23. Sep 8, 2023 at 4:20 AM
    fyrfytr26
    Eastern PA
    2021 DC SR
    Kenwood put out a firmware update that corrected those issues.
    The aftermarket seems to be much more proactive about making sure their stuff works right and squashing any bugs that come up.
    Toyota was less than helpful when I had problems with CarPlay after the iOS 16.5 update. Their rationale was that it worked fine until Apple pushed an update. So I simply replaced my head unit with a Kenwood.
  24. Sep 10, 2023 at 2:09 PM
    Terndrerrr
    Music City
    6UR-FE
    Update:
    I installed the software update (version 1383), and I am still having wired connectivity issues with my iPhone 12, even when using an Apple lightning cable. My phone is on the latest iOS version.
    It seems like the entire head unit reboots randomly. It seems like it is turning off and back on very quickly (it does this a lot faster than when I hold the power button down to hard restart it). The phone never loses connection and shows that it is charging the entire time.
    :confused:
  25. Nov 20, 2023 at 11:02 AM
    TG504
    Louisiana
    Wanted to come back and update the group on this ongoing apple carplay issue.. After updating the firmware, the problem persisted. I updated my iphone to ios 17 and all problems with carplay are gone. One week now, and haven't lost connection at all. Haven't had a single issue. It turns out it wasn't Toyota after all, it was apple the entire time. Hope this helps everyone. Cheers.
    Henry1jg likes this.
  26. Nov 20, 2023 at 11:04 AM
    TG504
    Louisiana
    With that being said I would still update the firmware if you haven't, just in case that was part of the issue.
  27. Nov 29, 2023 at 11:33 AM
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    Appreciate this thread as I was having issues with my '21 Tundra and carplay. FWIW - Toyota is listing version 1162 as most current with the DA30 model ID. Don't know if that means 1383 still has issues. The upshot is I think I want a newer head unit. :)
  28. Nov 29, 2023 at 11:36 AM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    i agree, I have a kenwood 7in with wired CarPlay and in the process of getting pioneer 9in with wireless CarPlay. No issues
