22’ TRD PRO mods? Let’s see
Discussion in '3rd Gen Tundras (2022+)' started by TobyKai, Jul 30, 2022.
  1. Mar 17, 2023 at 6:32 AM
    #331
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    Put the Bed Rug in last night.
    B8B231A1-6852-4249-BC72-522908CAC36A.jpg 705E9BD4-9FBF-444E-BE8C-D7A33403B800.jpg D5C80DEA-4B93-4106-A71B-D75BDCEF5B2A.jpg 19E5E7C8-D0DA-41C0-BE09-AE5F55A75FFD.jpg
  2. Mar 18, 2023 at 9:16 AM
    #332
    dooky
    dooky 2023 Tundra TRD Pro
    Los Angeles
    2023 Tundra TRD Pro
    Agency 6
  3. Mar 18, 2023 at 11:42 AM
    #333
    LS1Steve
    LS1Steve New Member
    What components did you use to mount those traction boards to the rail?
    Ltaco17[QUOTED] likes this.
  4. Mar 22, 2023 at 2:26 PM
    #334
    4wd TRD PRO
    4wd TRD PRO New Member
    Agreed
  5. Mar 23, 2023 at 3:44 AM
    #335
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    Rago Fabrication Toyota bed rail mounts along with maxxtrax mounts.
  6. Mar 25, 2023 at 6:35 AM
    #336
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    JB4...this thing is awesome...only running map 2 so far but man, you feel the difference for sure when that boost kicks in
    JB4 with Bluetooth Option...Install/1st Drive Impression...2022 Toyota Tundra TRD Pro
    https://youtu.be/2bL2clQpodE
  7. Mar 28, 2023 at 8:52 PM
    #337
    4wd TRD PRO
    Ok, I watched the video, it was good! Thanks. The pedal commander totally gets ride of the delay between when the pedal hits the floor and the actually decides to go when you stomp on it?
    2020Platinum[QUOTED] likes this.
  8. Mar 28, 2023 at 10:38 PM
    #338
    trailhunters
    trailhunters New Member
    Anyone do a light switch panel install like a Switchpros? Looking for wiring ideas and which fuse blocks to get.
  9. Mar 28, 2023 at 10:44 PM
    #339
    Gotink
    Gotink New Member
    BC
    2023 tundra pro
    2023 tundra pro,custom bed rack, treeline tent,retrax pro baja designs lights.
    The whole point of Switch-Pros is you don’t need anything else. Mount the control box by the battery,switch panel where you see fit,and go to town on wiring the accessories. Once you have used one you won’t use anything else.
  10. Mar 29, 2023 at 10:36 AM
    #340
    trailhunters
    I've had one before on my Tacoma where I used a Powertay to hold a Blueseas fuse block. Had the Powertray and fuse block in the engine bay so connecting the lights were really easy - all routed in the engine bay with a single cable going to the cabin for Switchpros.
    With the HV, the battery is in the rear with limited space so the setup is different.
  11. Mar 29, 2023 at 12:48 PM
    #341
    Gotink
    Gotink New Member
    BC
    2023 tundra pro
    Doing all that kinda defeats the reason to use Switch-Pros..the whole reason is it avoids using all the extra fuses and wiring.
  12. Apr 1, 2023 at 6:17 PM
    #342
    2020Platinum
    Patrick
    Northeast PA
    Not a switch pro, but similar idea...installed on my Pro (battery under rear seat)...works perfectly
    Rough Country Switch Panel Install/Overview...2022 Toyota Tundra TRD Pro Hybrid
    https://youtu.be/PQXdY29M320
  13. Apr 2, 2023 at 1:10 AM
    #343
    trailhunters
    Thank you for this. This is what I was looking for. Now just curious what other companies are offering a kit like this.
  14. Apr 2, 2023 at 6:11 AM
    #344
    2020Platinum
    Patrick
    Northeast PA
    No prob!...I like the RC one I have, but I'm about to swap to a 12 gang switch panel from Mictuning...it has options to change back lighting color and brightness (RC doesn't)...there's a few companies out there that offer these, switch pros are awesome and offer a couple additional features but I couldn't justify the cost...they're ridiculously expensive, but to each their own!...let me know if I can help with anything!
  15. Apr 2, 2023 at 9:23 AM
    #345
    trailhunters
    How do you feel about the Auxbeam AR800?
    It comes with the extended harness but is a little pricier. $50 off on top right now as well with their sale.
    https://auxbeam.com/products/ar-800-multifunction-rgb-switch-panel-system-qp008526-1
  16. Apr 3, 2023 at 9:17 AM
    #346
    2020Platinum
    Patrick
    Northeast PA
  17. Apr 4, 2023 at 1:05 AM
    #347
    Front_Range_Pro
    Front_Range_Pro EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    Been seeing this on Toyotas social media and website.
    Anyone with the cockpit red interior have the red center console pieces?
    My console is all black. Just curious if someone had pics.
  18. Apr 4, 2023 at 5:51 AM
    #348
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    these pictures are from the prototype, they never ended up doing the red center console, thank god. I have the red interior and the console is black, the red console only exists in these Toyota promo pictures
  19. Apr 4, 2023 at 6:30 AM
    #349
    Front_Range_Pro
    Vail, Colorado
    I got that. I wasn’t sure if it made it to production because I saw a canadian one where just the rear cup holder portion was red.
  20. Apr 4, 2023 at 9:57 AM
    #350
    kilocharlie106
    TRD Pro in LR
    I saw that @2020Platinum put airbags, and looked good. But has anyone changed out the rear springs for slight lift and less sag? I loaded only 40 bags of mulch before the truck sagged bad. Wayy too soft of spring to hold anywhere near 1400 pounds
    2020Platinum likes this.
  21. Apr 5, 2023 at 1:35 PM
    #351
    LS1Steve
    LS1Steve New Member
    Color matched all of the digi-camo! :crapstorm: Sorry but I LOVE it so much better now
    ytank1, Hecteasy and white_pro21 like this.
  22. Apr 5, 2023 at 1:42 PM
    #352
    Gotink
    Gotink New Member
    BC
    2023 tundra pro
    Looks killer ,prep work must of been a bitch ..
  23. Apr 5, 2023 at 1:50 PM
    #353
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    looks like a TRD Faux, imo.
  24. Apr 5, 2023 at 2:58 PM
    #354
    Front_Range_Pro
    Vail, Colorado
    Would love to see a stealth PPF MGM if anyone ever gets one done up. :cool:
  25. Apr 5, 2023 at 3:01 PM
    #355
    LS1Steve
    LS1Steve New Member
    no prep, they are new professional painted OEM fenders (from other trims). It would not be easy to sand down the texture of the Pro flares, they are a soft material. If someone else does it successfully, I'll try myself!
    Gotink[QUOTED] likes this.
  26. Apr 5, 2023 at 3:03 PM
    #356
    LS1Steve
    LS1Steve New Member
    So I look like every other Tundra Pro wannabe with a heritage grill? LOL
    Bought a Pro for the MTS, locker, shocks - IDGAF about anyone's cosmetic approval :cheers:
    GoFast157 likes this.
  27. Apr 5, 2023 at 4:44 PM
    #357
    kilocharlie106
    TRD Pro in LR
    Your truck.
    But I would’ve sourced the trail hunter non textured fender flares to keep width and lights
  28. Apr 5, 2023 at 5:34 PM
    #358
    Logey22
    Logey22 New Member
    2023 Tundra TRD Pro - Solar Octane
    I am currently working on getting my Switch Pros sp9100 installed. I originally was going to mount it next to the battery under the rear seat, and extend the harness to under the hood. However, I decided to install additional remote battery terminals under the hood. Im in the middle of creating a "powertray" of sorts, which will have a terminal bar and bus bars mounted on it. I decided against an additional fuse block due to the simplicity of the accessories being installed.
    The reason I chose to install terminals under the hood is because I needed to power the winch going in, and thought it was the simplest way to power it. 20230322_192802.jpg IMG_20230322_190113_01.jpg
    erdub54 and 4mm like this.
  29. Apr 5, 2023 at 7:10 PM
    #359
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    ^^Clean install, very nice work.
  30. Apr 6, 2023 at 12:08 PM
    #360
    LS1Steve
    LS1Steve New Member
    What type of accessory battery do us hybrids have? Is it enough to support the winch? My understanding is that the hybrid battery is used to start the truck, so implies a lesser amperage battery for accessory. I'd love to do what you did!
