275/70 18
Discussion in 'Wheels & Tires' started by Kemosabi, Mar 2, 2021.
  1. Mar 2, 2021 at 11:10 AM
    Kemosabi
    Kemosabi [OP] New Member
    2016 Limited TRD Off Road
    Hello All,
    I'm sorry if this question has already been answered, I just bought a 2016 Limited with the TRD Off Road package. It came with some nice PRO Comp wheels with 265/70 18 tires. (That I want to sell soon). I ran across some of the new model TRD wheels and want to put them on. I was reading that people have been putting 275/70 18's on stock wheels and stock suspension with no problems. Can anyone on here with this setup tell me if they have towed any thing heavy like a camper and or had any problems?
  2. Mar 2, 2021 at 11:22 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  3. Mar 2, 2021 at 11:35 AM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    I have the 17 TRD PRO and am able to run 285/75/r18, unsure about the differences between the offroad. Hope this somewhat helps. There's a forum about what sizes you can fit. I'll try to find it for you
  4. Mar 2, 2021 at 11:36 AM
    YotaBro
    Calvin
    FL
  5. Mar 2, 2021 at 11:59 AM
    Kemosabi
    YotaBro,
    Have you towed anything Heavy with that wheel and tire setup? I'm planning a cross country camping trip this summer and would hate to find out that it rubs when I go to pick up the camper I'm renting?
  6. Mar 2, 2021 at 12:22 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I run 275/70-18s, stock OR rims and suspension. I do tow, no problems at all running 275/70s. The only consideration- moving to 275/70-18 means you will be moving from the stock standard load tires to E load. The E load tires do ride stiffer. But they also corner better and tow better. Here are a couple pics of this size on the truck
    AZBoatHauler, Sean492 and Oey12 like this.
  7. Mar 2, 2021 at 12:29 PM
    YotaBro
    Calvin
    FL
    Nah, just put them on less than a week ago. Probs wouldn't be the best with such a large tire.
  8. Mar 2, 2021 at 12:32 PM
    Kemosabi
    It looks like you have the front mud flaps on also, Some people said that they had to remove those with the 275/70 18's. Thanks for the info.
  9. Mar 2, 2021 at 12:45 PM
    Kemosabi
    Can you post a picture of the 285/75-18's on your PRO?
  10. Mar 2, 2021 at 12:46 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    684F8E80-E8C9-465F-A612-2394F0A02610.jpg 95AEE769-61DF-499F-A4B9-E0D0D8E51E5E.jpg Max towing on 275/70/r18. Stock everything. No issues. Just make sure you run proper inflation. Load range E I pump them up to 60 front and 65 rear
    Kemosabi[OP] likes this.
  11. Mar 2, 2021 at 6:12 PM
    YotaBro
    Calvin
    FL
    RJVA and Kemosabi[QUOTED][OP] like this.
  12. Mar 2, 2021 at 6:59 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Here is a pic of my 2020 TRD Pro all stock with 275-70-18 bfg ko2 tires.
    Savmikey47, YotaBro and Kemosabi[OP] like this.
  13. Mar 2, 2021 at 7:01 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I had 275/70/18s in Nitto RG LTs. I tow. No issues no rub. I just lifted and sized up but get an E and you can tow with no issues. I have 285/75/18s now, they are OD 35”. Won’t fit stock rims or suspension. You will want +18-25 offset and a lift.
  14. Mar 2, 2021 at 9:07 PM
    rustytoys
    rustytoys New Member
  15. Mar 4, 2021 at 2:20 PM
    Kemosabi
    A question that I forgot to ask. Does anyone know if the 275/70-18 wheel will fit in same spare tire location?
  16. Mar 4, 2021 at 2:49 PM
    frichco228
    yes it does
