295’s on Limited 20” wheels?
Discussion in '2.5 Gen Tundras (2014-2021)' started by SeminoleATL, Aug 8, 2020.
  1. Aug 8, 2020 at 6:30 PM
    SeminoleATL
    SeminoleATL [OP] New Member
    2014 Limited CM Blue
    Stock... for now
    Well, put on 2.5/1 leveling kit last week. Ended up actually at 3” in front based on fender/ hub measurements.
    Decided to go with 295/60r20 Ridge Grapplers. When the tire shop put the first one on, they did a test fit and reported that the sidewall was only about 1/8” clearance from the UCA. We decided that it was a little close for comfort and I got some 1.25” Spidertrax on the way. Had planned to add them at some point anyway, so not a totally big issue.
    But now I’m wondering... There are plenty of trucks on here running 295 tires on stock wheels. What was the issue on mine? Are the limited wheels even less offset than other stock wheels?
    Two things I’ve wondered after the fact...
    1) The truck had not be aligned yet after the lift. We were going to do it with the new shoes on. Could this have made the difference?
    2) I don’t know if the truck was on the ground or in the air for the pic. Would this have made a difference,
    Would these two together made and even bigger difference?
    currently with the 275/60r20 that were on the truck, there is about a finger width between sidewall and UCA.
    Any thoughts?
  2. Aug 8, 2020 at 7:07 PM
    cquilichini
    cquilichini New Member
    I run 295/55R20 Ridge Grapplers on my Limited wheels, no spacer. Perfectly, no rubbing at full lock.
    https://www.tundras.com/threads/has-anyone-got-295-55-20-on-stock-wheels.39948/page-2#post-1042332
    here you can find some info, and the pics of my truck, the Black SR with Blacked out Limited rims.
    I have stock suspension and I highly recommend aligning the truck after, the difference is night and day. Also consider pressurizing the tires at least at 39psi, otherwise it makes a huge difference in gas milage.
  3. Aug 9, 2020 at 4:09 AM
    SeminoleATL
    Stock... for now
    So it sounds like the issue is that the camber is off a bit from lifting and that is causing the clearance issue. Should have had the alignment done before mounting tires and probably would’ve been ok. Either way, the spacers will help and make it look better. Just meant adding a few days before seeing the finished product. Waiting sucks sometimes.
  4. Aug 9, 2020 at 2:32 PM
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    4" Pro Comp Lift 35x12.50x20 Toyo RT's 20x9 +20 Fuel Mavericks Rough Country soft tri-fold bed cover LED headlight and Fogs with LEDs throughout the cab as well
    2016 Limited with 295/70/18 Nitto Ridge Grapplers 2.5 leveling kit. NO WHEEL SPACERS
    No rub. Only trimmed the skid plate
    PermaFrostTRD and TRDblvd like this.
  5. Aug 9, 2020 at 2:40 PM
    19greysport
    19greysport New Member
    2019 crewmax sport
    I’m running 295/65r20 toyo mts on the sport wheels. Same thing. And had to run spacers to fit the control arms. Love the look no rubbing. But trimmed the skid plate and adjusted the front inner fender. Running Ome suspension with the hd coils cuz I plow.
  6. Aug 9, 2020 at 2:49 PM
    SeminoleATL
    Stock... for now
    that looks great. So you have what, 3” of lift in the front?
  7. Aug 9, 2020 at 3:00 PM
    PermaFrostTRD
    Northern NY
    How stiff is the ride without the blade on the front? I’m about to go 295/70 18s on my truck with either the OMEs or 6112 or toytec aluma’s. Probably only at 2”.
  8. Aug 9, 2020 at 4:14 PM
    19greysport
    2019 crewmax sport
    Yeah around 3” of lift. And did couch builder shackles in the rear.
  9. Aug 9, 2020 at 4:15 PM
    19greysport
    2019 crewmax sport
    Rides great better them ready lift 3-2 I had on my old tundra. Ome is good stuff.
    PermaFrostTRD[QUOTED] likes this.
  10. Aug 13, 2020 at 4:13 AM
    SeminoleATL
    Stock... for now
    Finished!
    Took adding 1.25” spacers. I think one alignment was done it would have been ok, but happy with the end result.
  11. Dec 4, 2020 at 8:57 AM
    SmokedMesquite4x4
    SmokedMesquite4x4 New Member
    Taylor
    2018 1794 CrewMax 4x4
    Did you use any CB shims on this setup? I'm fixing to do the 6112/5160 lift and plan to run the same size tires.
  12. Dec 4, 2020 at 9:08 AM
    cquilichini
    Looks great. Can you take a picture of the truck from a front angle so I can see the effect of the spacers. Thanks
    Redpill likes this.
