2gr fe engine oil on spark plug threads related to p0301 and p0353?
Discussion in '2nd Gen Tundras (2007-2013)' started by paulmars, Jun 9, 2021.
  1. Jun 9, 2021 at 11:47 AM
    paulmars
    paulmars [OP] New Member
    ok, this is not about a Tundra. Its about a 2gr fe engine which comes in some Tundras. My wife's avalon has the 2gr fe engine. Since it comes in some Tundras, maybe someone can help me here.
    2007 avalon LE, 189k miles.
    Don't know maintenance history. Has not been to dealer service since 2010.
    Got it three months ago (gift from wife's family to her) and it's been fine around town for us. West central florida. It was shipped here from Delaware. That is where it was bought new and her family used it.
    I did much routine maintenance on it in those three months. It was making loud clicking noise, which this engine is known for, but once I changed the engine oil and ran it for awhile it quieted down. I think oil was too thick. Both engine and trans-axle oils had been recently changed, but since I did not know what was used, I changed them again. Both were over full when we got the car.
    I also fully bleed the brakes. The peddle was very hard and pushed down very slowly while bleeding both rears. After bleeding all, the peddle still feels mushy. Ive literally fully bleed brakes maybe 15 times in my life and Ive never experienced either of those.
    Front three spark plugs looked fine, except they were 0.040". I left them there. I didn't check the rear 3.
    We set out to go to ohio and after 90 minutes it started to shake intermittently for a few seconds at a time and after a while engine and VSC and stability lights came on. Sometimes the engine light flashed. Decided to turn around and go home. On entire trip home I never felt the shake, but it might have still been doing it just less so.
    A few days later went to two different auto parts stores and used their code reader and at 1st store he said "its mis firing on cyl 4....and 6...and 1 and 2....and 5...and #3. It's misfiring on all cyl." I never asked him for the codes. Then I drove directly to other store and he said p0353 and p0300. Then he mentioned the OCV.
    A few days later I drove to another auto parts store and they gave me printout: p0301, secondary DTC p0300, p0301, p0302, p0303, p0304, p0305, p0306, p0353, and c1201. printout listed suggested fixes: replace ignition coils, reset ECM (for c1201).
    The shake was always very mild and at 1st I thought it was suspension/alignment. We got two new (used tires) installed a few days before the trip. Yes I checked the bolt torque when we got home, then again before we left. Im convinced that it was never misfiring on more then one cyl at a time. It happened at different highway speeds between 60 and 75. That's as slow and as fast as I traveled, so Im not saying it would not happen above or below those speeds.
    I removed the WW motor and tray and intake manifold. I planned (and still do) to replace all 3 rear COPs. However, I don't expect to find the problem thru testing in drvway since it was intermittent, but still I wanted to check some other things. COPs for rear cyl 1 and 3 the electrical plug tabs broke off when pressed with my thumb. All three were plugged in tight. # 3 and # 5 cyl rear spark plugs the threads are glossy, like they had oil on them. #1 was wet with oil. See pics attached. Notice for cyl #1 the oil is not on the lower threads and it's stained in the middle. These were also set to 0.040" and I decided that I should gap them all to the proper spec 0.043. I gaped and replaced them. Over night I decided to swap the rear plugs with the front (and gap those too), so if she codes Ill see if it moved to front bank. When removing cyl # 1, I see it's much more wet with oil and the oil goes all the way down to the gasket. How'd it get worse over night? I didnt drive the car. So, maybe the spark plug hole was full of oil. yuck. But the plug ceramic was not oily. hmmm
    Since then ive read what looks like toyota docs online saying don't adjust the plugs.
    p0301 is cyl #1.
    The rear middle plug (p0353) was not torqued, it was just hand tight, but seated. The rear driver side plug (#5) was not even seated. These two plug electrodes look exactly the same as the front plugs that were all tight. The only plug that's electrode looks different is cyl #1, the one with wet threads.
    Plugs are ngk Dilfr6d11.
    gas cap don't feel very tight, so Im going to get OEM replacement.
    It looks like I should remove the valve cover and spark plug tubes and replace the thread sealant. That's a job i don't know if I'm up to.
    Several things Ive read say one code might cause many or all of these other codes and that p035x should be fixed first, before looking into p030x codes. But that means putting her all back together to see if she still has this intermittent issue. Then taking her apart again...
    I checked voltage between COP wire harness contact # 1 and # 4, between #1 and ground, and ohms between # 4 and gnd. All fine.
    I cant find info on what to check on the injector's wire harness contacts without running the engine. I saw wire diagram showing that one of the contacts is common on all 6 plugs, Id like to test that, but dont know which contact it is. Each injector measures 13.2 ohms.
    All vacuum hoses look fine.
    Saw no physical issues with wire harness. I removed and cleaned the battery to chassis and chassis to engine and chassis to trans grounds.
    images:
    rear
    cyl#1 plug https://imgur.com/a/KuT0NIJ
    cyl plugs #3 and #5 https://imgur.com/a/kX7Pw6T
    front
    https://imgur.com/a/mSKxIyA
    Note about the images. some sites pull in the images and omit some and mess up my descriptions, so you need to actually go to those links.
    Thoughts?
  2. Jun 9, 2021 at 9:20 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I would throw new spark plugs in and torque them to specs (15ft lbs?). Replace your coil packs since you mentioned you were anyway, put back together. Drive. See what happens. I usually put a dab of oil on my spark plug threads when I install them... (may account for your threads if them being loose doesn’t) probably will get shamed for that but I’ve never had a problem... but that’s because I never used a torque wrench until some recent work I did and learned that 15ft lbs felt like a little more than my hand as a torque wrench told me was enough.
  3. Jun 9, 2021 at 9:30 PM
    paulmars
    Unfortunately when i linked to my 6 pics it brought in only 3. Ull need to click on each of those 3 pictures to see the other pics. One of the more important pics is inside that 1st pic, so click on it. Then read the discriptions
  4. Jun 9, 2021 at 9:32 PM
    paulmars
    All 3 rear plug threads wet with oil, one very wet. All3 front are dry.
  5. Jun 9, 2021 at 9:53 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Yes, I looked at all the pics. I wouldn’t be concerned about the oil on the spark plug threads yet. I would replace them and torque to specs. Was there any oil in the spark plug well? If so, probably need valve cover/tube gaskets. If not, put new plugs in and see if oil returns to the threads. Of course, you can always do a compression test while you are at it.
    Also could be the tube orings? (not seals).
  6. Jun 9, 2021 at 10:33 PM
    paulmars
    Maybe. Its 2-3 hour job getting to those rear plugs and COPs.
  7. Jul 12, 2021 at 8:18 AM
    Billy Bob Tundra
    Billy Bob Tundra New Member
    I didn't have time to read all your post but I'll bet your mushy brake pedal is because of the rubber brake lines.........Purchase STAINLESS STEEL brake lines and your problem will be solved. I know it did on my Tundra and several others who replaced the brake lines because of mushy brake pedal.......one guy had over $4000 of work done to his brakes by his dealer to only still have a mushy brake pedal until HE changed out the brake lines............lucky all that work was done on warranty except what he finally did to correct the problem.
  8. Jul 12, 2021 at 9:12 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    90% of the time the original coil packs are to blame on these. Toyota redesigned them around 2010 to fix the issue, replace the coils and go from there.
    DO NOT use aftermarket. We’ve had aftermarket coils fail and kill the whole car because of the IGF signal like being improperly manufactured. DENSO off rock auto is the only acceptable aftermarket for these cars
    sticking oil control valve is also a possibility or at worst, the TSB was never done for the exhaust cams to be replaced with an updated phaser
    As for the pedal, check the slide pins on the rear Calipers, the commonly seize up and will cause a low pedal. On rare occasions the front too.
    -2006 Avalon owner, love this car
    pickeledpigsfeet likes this.
  9. Jul 14, 2021 at 5:55 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    it may be too late but something to consider for next time.
    First stop going to autopart stores and buy a OBD2 blue tooth adapter from Amazon (it will save you money from driving from store to store). They start at like 10 bucks.
    Next, clear codes or pull battery ground and let sit for a few hours (i typically cycle the headlights on/off with ground off which should clear any stored energy in the truck).
    next start truck and run into it shows the check engine light. Pull code then google search it for your car. Repeat process and see if it code returns to same cylinder. If code moves then you probably have a source issues instead of an end product issue.
    Do not gap Iridium tipped plugs. If you did then pull them and replace as you have damaged them and this might be your issues.
    As for the Brakes:
    I agree with
    this made a difference on my brakes. As did the stainless line upgrade.
    As for the shake that's a separate issue.
    You'll need to move the tires around, possibly check the flatness of the joint between the wheel and the hub (to ensure its flat) and used tires are always a gamble (most people don't upgrade tires because they were happy with the old tires (balance, feel, vibrations, etc?) I know that tires are expensive and i get it.
    Finally,
    Oil on the top of spark plugs will not cause mis-fires. Its not ideal and may require pulling valve covers etc. But I won't do that until you sort the other issues as this nuisance isn't your issue (i won't think) others may be smarter about this then me.
    Report back.
    coil pack replacement is pricey but makes sense to me if the code follows a cylinder.
