2H or 4H
Discussion in '2.5 Gen Tundras (2014-2021)' started by jr1016, Aug 4, 2020.
  1. Aug 4, 2020 at 11:21 AM
    jr1016
    jr1016 [OP] New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Which do you guys prefer when driving the truck on non off road. Street and freeway only.
  2. Aug 4, 2020 at 11:26 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    you should only be using 4wd when you need to and on loose material (dirt roads/snow).
  3. Aug 4, 2020 at 11:26 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    only 2H unless in a winter storm. 4H will do damage if conditions are not suitable for 4H
  4. Aug 4, 2020 at 11:54 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Is it Friday?
  5. Aug 4, 2020 at 1:19 PM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    4 LO in Tow/Haul mode
  6. Aug 4, 2020 at 2:40 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    that works best for burnouts and stop light launches
  7. Aug 4, 2020 at 3:08 PM
    AZBoatHauler
    So.Arizona
    They call that u-turn mode because it offers the highest level of turning capability - but only on hard dry surfaces..
  8. Aug 4, 2020 at 3:32 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I prefer the 4-Super Low mode with all 3 differentials locked and the FOTMFF device engaged. Guaranteed to completely fuck something up in short order.
    AlaskanAssassin and Jaypown like this.
  9. Aug 4, 2020 at 4:39 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    2H unless it's icy or I actually remembered to do my monthly 4wd test.
    sf319 likes this.
  10. Aug 4, 2020 at 7:27 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Damn, I shot coffee out of my nose, laughing, when I read that.
    AZ_Tundra1 and Jaypown like this.
  11. Aug 4, 2020 at 7:30 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    in case you hadn't already noticed, some of us can get quite rowdy from time to time, including myself.
    in all seriousness, i would absolutely NOT operate in 4 hi or 4 lo on DRY concrete.
  12. Aug 4, 2020 at 7:34 PM
    jr1016
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    lol, I noticed. I'm new to the truck (4x4) world so wanted to make sure I'm using it properly. Although 4L on doing donuts doesn't sound too bad.
    Cpl_Punishment likes this.
  13. Aug 4, 2020 at 7:38 PM
    shackleford rusty
    TEXAS!
    :burnrubber::burnrubber::burnrubber:
    welcome from south texas! :cheers:
  14. Aug 5, 2020 at 4:28 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Did you not get a OWNER'S MANUAL with your brand new truck?:confused:o_O:smack::D
    Hurricane and GODZILLA like this.
  15. Aug 5, 2020 at 4:46 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Don't use 4H unless you actually need it. As @CMB said, read through your owners manual on how and when to use 4H and 4L. Using it incorrectly can potentially (most likely) cause some expensive damage. It's not a fun learning curve to figure out.
    Alex38 and jr1016[QUOTED][OP] like this.
  16. Aug 6, 2020 at 8:13 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Anyone remember putting an old truck in 4L on the street and try a hard turn? Bucked like horse!
    sf319 likes this.
  17. Aug 6, 2020 at 8:17 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Heck, a Sierra I was driving at work did that in 4 Auto!
  18. Aug 7, 2020 at 1:20 AM
    CMB
    CMB New Member
    Cecil County MD.
    I had a friend at work who bought a new Wrangler. Salesrep didn't take an extra minute with her and of course she didn't bother looking at the Owner's Manual. Told us until her Brother straightened her out, she thought 4-H was for "High Snow" and 4-L was for "Low Snow":D
    Cpl_Punishment and Black Wolf like this.
  19. Aug 7, 2020 at 2:21 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    that’s some funny shit right there !!
    Black Wolf likes this.
  20. Aug 7, 2020 at 2:29 AM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    Here is the deal....
    When you turn a truck or car the front tires travel a distance that is different from the back tires. In fact, the inside tire on the front or back travel a distance that is different from the outside tire. Basically, every tire travels a slightly different distance. The tundra only has open differentials in the front and rear so the inside/outside thing doesn't matter but the front and back does matter. If the transfer box is locked (4H or 4L) then something has to give between the front tires and rear tires when you turn. That something is the traction between one of the front/rear tires and the road. The thing that is forcing the tires to give is the chain in the transfer box.
    The chain holds the front/rear drive shafts together forcing the one tire to break traction. On pavement in turns you can really feel that tension build until a tire skips. On loose material you don't even notice. If you drive in 4H on pavement long enough, it will stretch your transfer box chain to the point it can skip teeth. This was a real problem for the early full time 4x4 trucks on the 70's.
    Obviously, the chain isn't the only thing in tension or can break when you drive in 4H or 4L on pavement. U-joints, bushings, bearings, ... all feel the tension and shock loads. This is why the owners manual tells you not to do this. You can see the chain in the following diagram.
    jr1016[OP], Black Wolf and Boerseun like this.
  21. Aug 7, 2020 at 4:07 AM
    That's my preferred.......
  22. Aug 7, 2020 at 4:09 AM
    WTF? Heh...heh. Everyone knows is Hi mud or Lo mud.....
  23. Aug 7, 2020 at 5:33 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    When towing the trailer with a big water tank on it at the farm, my grandfather would always tell me to shift into "bull low" - 4Lo and 1st gear on the automatic transmission - on his 1985 Ram 150 until we got up out of the muddy area around the well after filling it up.
  24. Aug 7, 2020 at 5:37 AM
    Kuul…..
  25. Aug 7, 2020 at 5:50 AM
  26. Aug 7, 2020 at 7:02 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
