3.4L twin-turbo V6 engine
Discussion in '3rd Gen Tundras (2022+)' started by Ravioli97, Sep 29, 2024.
  1. Sep 29, 2024 at 6:03 AM
    Ravioli97
    Ravioli97 [OP] New Member
    James
    Calgary, Alberta, Canada
    New guy here, I did a search and it came up with “Nothing Found”. I am looking at a 2024 with the 3.5L twin-turbo V6 engine and am wondering if anyone has any issues with this motor? I am aware of previous issues but Toyota is claiming that those have been resolved.
  2. Sep 29, 2024 at 6:15 AM
  3. Sep 29, 2024 at 6:34 AM
    iScramble
    iScramble New Member
    2023 Tundra SR5
    Welcome! Check out the Tundra 3rd forums. There’s a lot of decent information on there about the new engines.
  4. Sep 29, 2024 at 6:36 AM
    Ravioli97
    James
    Thanks, I will do that
  5. Sep 29, 2024 at 8:09 AM
    2mchfun
    Welcome from OKC! Plenty have had engine failures from turbo to mostly crank bearing failures. There's also body trim problems and such.
  6. Sep 29, 2024 at 8:25 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
  7. Sep 29, 2024 at 8:27 AM
    It’s a 3.4 guys
  8. Sep 29, 2024 at 8:33 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Bingo - at least learn what ya' got under that beasty hood.
  9. Sep 29, 2024 at 2:06 PM
    Ravioli97
    James
  10. Sep 29, 2024 at 2:16 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
  11. Sep 29, 2024 at 2:19 PM
    Ravioli97
    James
  12. Sep 29, 2024 at 2:37 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Toyota calls it a 3.5 for marketing purposes. It’s 3,445cc’s. Technically this rounds down to 3.4L. There are no 2024s recalled YET, same for the hybrids. There has been failures of the same type from at least some early 24s and the hybrids.
  13. Sep 29, 2024 at 2:43 PM
    Hella Krusty
    Hella Krusty New Member
    If you dont like condescending remarks....you have come to the wrong place for info
    jt13077, Leo's first, teab and 5 others like this.
  14. Sep 29, 2024 at 3:02 PM
    Ravioli97
    James
    Silver17 thanks for the informative response, much appreciated.
    2mchfun and Silver17 like this.
  15. Sep 29, 2024 at 4:39 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Toyota Corp does not call it a 3.5L, they got their hand slapped for that very early on in 2022 for rounding Up. The note you are showing is the Dealer's Lying Remarks.
    teab, Hella Krusty and Black Wolf like this.
  16. Sep 29, 2024 at 5:01 PM
    Silver17
    Eastern PA
    I didn’t show any note. And good, as they should.
  17. Sep 29, 2024 at 5:08 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I would get a 2025. We hope they have it resolved. I have had no problems and it’s a been a great engine thus far, but it could potentially go at any time. Most of us haven’t had issues, but it’s there. If they do have it resolved, then it will be a really fine machine. It has plenty of power and torque, and the transmission is excellent.
    Tundrastruck91 and j-utah like this.
  18. Sep 29, 2024 at 6:23 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    They wanna be on par with Ford…
    teab and ZappBrannigan like this.
  19. Sep 30, 2024 at 7:13 AM
    iforceAZ
    iforceAZ New Member
    Please just lock and close this thread
    ZappBrannigan, Leo's first and teab like this.
  20. Sep 30, 2024 at 9:11 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Highly suggest you delete your account now then (same as @Hella Krusty said)...
    Leo's first likes this.
  21. Sep 30, 2024 at 9:18 AM
    Maybe everyone could be nicer instead of telling a member that they must endure condescending remarks to be on here.
  22. Sep 30, 2024 at 9:41 AM
    mass-hole
    mass-hole New Member
    The hybrids will never be recalled because its a safety recall, which doesnt apply to the hybrids. The hybrids are built to run electric only and therefore retain powersteering and braking assist even if the engine is not running.
    If you have a hybrid, they are just letting the factory warranty deal with any engine failures and will replace the motors when/if they fail instead of doing a forced replacement.
  23. Sep 30, 2024 at 9:46 AM
    teab
    Ty
    Denver
    I didn't see anything condescending for the OP to make that statement. People said hey yeah that's a known issue that is well documented and someone pointed out actually its a 3.4 liter from someone else's post. Like literally read above what was posted before the OP made that remark, I actually thought people were being pretty nice and if that is what the OP considered condescending then I wholeheartedly was making the suggestion to delete the account because when it does get to the typical snotty-ness the OP is going to have a hard time.
  24. Sep 30, 2024 at 9:55 AM
    Silver17
    Eastern PA
    I guess that’s all well and good so long as they do a good will replacement when it blows at 60,001 miles and beyond since they know they have an engine problem.
  25. Sep 30, 2024 at 10:09 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    In the first year (covered by the recall) there were a lot less Hybrids available to purchase. I think I was told that they were 12 to 18 months wait. So if there are failures of the Hybrids there will be only a small percentage compared to the gassers.
    The challenge will be if a hybrid engine fails, what will Toyota do? A short block or a long block replacement?
    Like that old saying goes: "If a tree falls in the forest, will Toyota replace your engine"?
