3" level and 295/70r18’s- too squatty or nah?
Discussion in '2nd Gen Tundras (2007-2013)' started by jaybo, Dec 14, 2023.
  1. Dec 14, 2023 at 8:46 AM
    jaybo
    jaybo [OP] New Member
    South Carolina
    2008 White Tundra Limited Crewmax 4x4 5.7l
    Coming soon
    My mechanic put the leveling kit on with both spacers without asking me. So it’s a 3" level (instead of the 2.5" level that I wanted).
    Does it look too squatty or just right? With the 34.3" tires I think it’s not terrible. No rubbing at all either if y’all were wondering.
    Debating on putting 1" blocks in the back since it’s a cheap and easy fix.IMG_2233.jpgIMG_2236.jpg
    D4x4TRD and Rakso like this.
  2. Dec 14, 2023 at 10:16 AM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    It looks pristine :101010:
    jaybo[QUOTED][OP] likes this.
  3. Dec 14, 2023 at 10:23 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Im not a fan of reverse rake. Just lift the rear. Block will work, but not ideal. If you tow/haul check out RAS (active suspension). Lifts about an inch and helps with squat when hauling and towing, works as they advertise.
    Jeff_1974 likes this.
  4. Dec 14, 2023 at 10:37 AM
    jaybo
    South Carolina
    Coming soon
    Good to know! Suspension probably be worth it!
    The front is just 1/2” taller than the front after measuring. But I do like truly leveled better.
  5. Dec 14, 2023 at 12:24 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I had 3" in the front and 1.5" in the back for a perfect level truck (2018 CM).
    Coincidentally I also asked the installers to do the 2.5" in the front and 1" in the back, and when I picked it up, I saw that they had installed the shims also for the total 3"/1.5".
  6. Dec 14, 2023 at 12:58 PM
    coveyrise12
    coveyrise12 New Member
    2012 Tundra Crew Max
    Nice truck. I'd personally bring the back up. Especially if you tow/haul.
    Do you have any pictures of how close your 295s are to your upper control arms? I have a 2012 with 295s and it came with wheel spacers. I'm hoping to take them off but it looks like I may rub.
  7. Dec 14, 2023 at 2:37 PM
    jaybo
    South Carolina
    Coming soon
    Lol I don’t feel so bad now. Glad it has happened to someone else!
    That set up looks good on that truck!
    Boerseun[QUOTED] likes this.
  8. Dec 14, 2023 at 2:40 PM
    jaybo
    South Carolina
    Coming soon
    Thanks, I don’t haul that often- probably less than 10 times a year I’ll pull a small camper, a trailer for materials or a machine rental.
    I can get pictures tomorrow and post them
  9. Dec 15, 2023 at 6:11 AM
    jaybo
    South Carolina
    Coming soon
    Upper control arm is close- can’t fit my finger in between there, but doesn’t touch the tire.
    Another thing that makes me nervous is that little arm that attaches to the sway bar, but two mechanics said it’s fine. ‍♂️
    I will also say that the ride really isn’t noticeably different than before. Only thing is a new hum that goes in and out. I heard it when the old basic tires were on it too.
    I’ve always liked the look of a leveled truck with oversized tires, but it makes me nervous . I like everything solid as a rock and worry free. Would be funny if I go back to stock after a few months. IMG_2247.jpg IMG_2248.jpg
  10. Dec 15, 2023 at 6:56 AM
    2000 Limited TRD AC 4X4 Thunder Grey 272k miles. 2019 Limited TRD CM 4x4 - SOLD
    Your truck is an 08, so good chance your rear leaf springs are getting tired and have less arch in them than they use too. Could do new HD leafs instead of block. Get some load carrying back and raise the rear at the same time. They run $500 or so a pair though, so not as cheap as the blocks.
    jaybo[OP] likes this.
  11. Dec 15, 2023 at 7:19 AM
    As mentioned, bring the rear up. Did he not know that the front spacers are not a 1 to 1 lift ratio?
  12. Dec 15, 2023 at 7:34 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I second, eh or third, do the rear. Yes, that UCA is real close to that tire. It wouldn't hurt to run a 1' hub centric spacer. I am.:anonymous:
  13. Dec 15, 2023 at 7:41 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I vote too squatty. Ill bet the front would look better with less lift
  14. Dec 15, 2023 at 8:00 AM
    jaybo
    South Carolina
    Coming soon
    That does exactly like it sounds like it does? Pushes the wheel and tire out 1". Easy to put on right?
  15. Dec 15, 2023 at 8:01 AM
    jaybo
    South Carolina
    Coming soon
    That’s very true!
  16. Dec 15, 2023 at 8:05 AM
    Yes. I have them on my 2019 and my 2000. Easy to put on, may introduce rubbing at the inner fender liner in the front and rear of the fender well as they increase the scrub radius of the tire. I'm running stock tire size currently with no lift and have no rubbing. But your larger tires may rub with them.
  17. Dec 15, 2023 at 8:43 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    THESE are what I'm running and have been for 8 years.
    KNABORES and jaybo[QUOTED][OP] like this.
  18. Dec 15, 2023 at 9:37 AM
    Obviously he can’t run those, but ones with the correct bolt pattern for his truck
