33x12.5 18 wheel offset help
Discussion in 'Wheels & Tires' started by a_double, Aug 26, 2020.
  1. Aug 26, 2020 at 3:53 PM
    a_double
    a_double [OP] New Member
    Hi,
    I'm interested in running 33x12.5 on a 18x9 +25 with a lift that doesn't make the wheel/tires look too small.
    It seems like this isn't a popular choice but I like the look of 33x12.5.
    I've seen 33x12.5 setups that retained the mudflap. What offset would allow me to retain all parts in wheel well? Would 18x9 +25 allow that with 33x12.5?
    Thanks much!
  2. Aug 26, 2020 at 6:10 PM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Im running that exact rim size with 35's and 3/2 lift, but no plastic parts.
    I think you will be fine with 33's and leaving the plastic in place.
    a_double[OP] likes this.
  3. Aug 26, 2020 at 11:21 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    33x12.5 on 18's w/+25 offset will work with absolutely zero clearance issues. Enjoy!
    a_double[QUOTED][OP] likes this.
  4. Aug 31, 2020 at 9:22 AM
    a_double
    Thanks for the replies.
    What about 33x12.5 18 on a 18x9.5 +20? Or even +0?
    What parts need to be removed and/or trimmed on 33's?
    Thanks in advance.
  5. Sep 1, 2020 at 3:01 AM
    preacher35
    Hmmm. I think with a 0 offset, you're going to have some rubbing on the front fender wells; not sure about rubbing on the body mount at the back of the fender wells but that too is a possibility. For a +20 offset, I do not think you will have any rubbing.
  6. Sep 1, 2020 at 4:20 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    I use to run 295/60 (34”x11.75”) on +20 offset wheels while leveled 3/1. I had to remove the front mud flaps and massage the liner towards the bumper with heat to make clearance. I wouldn’t chance going to +0 unless you want to protrude outside the fender which still might happen with +20’s and 12.5” tires.
  7. Sep 1, 2020 at 8:22 AM
    a_double
    Thanks preacher35 and r4z0r51o.
    +0 is likely out of the question due to how much it protrudes from side body plane. I want a slight protrusion and +20 should get me there. I just would rather not remove anything from fender well.
    Thanks again for helping me make an informed decision.
    r4z0r51o likes this.
  8. Sep 1, 2020 at 9:51 AM
    r4z0r51o
    Dave
    Some say that a picture is worth a thousand words so here's a picture from nearly 4 yrs ago of my 295/60's on +20 offset wheels. Your desired tires size of 33x12.5 should be about 3/4" wider. Divided that by 2 and you
    get 3/8" of an inch more tire sticking out than this photo.
    Good luck, hope this helps out.
  9. Sep 1, 2020 at 10:15 AM
    a_double
    Thanks much! Your setup looks good and I dig the Silver Tundras. I'll check out your build thread too.
    r4z0r51o[QUOTED] likes this.
  10. Sep 1, 2020 at 11:22 AM
    r4z0r51o
    Dave
    Your welcome! I'm always willing to try and help others learn from my mistakes.
    My build looks quite a bit different now, but hopefully still tastefully done.
  11. Mar 21, 2025 at 9:13 PM
    Ksilva130
    Ksilva130 New Member
    2022 Tundra SR5 Off Road
    I’ve been looking at the Black Rhino Chambers 18x9.5 +12 offset on Toyo 265/70R18, what are the chances of this running? Thanks in advance!
