35’s on stock 20” TRD rims
Discussion in 'Wheels & Tires' started by aklopez013, Mar 1, 2024.
  1. Mar 1, 2024 at 3:01 PM
    aklopez013
    aklopez013 [OP] New Member
    Andrew
    2024 Magnetic Grey Metallic SR5
    Went to discount to put them on and they’re saying it’s gonna rub. Ordered a 1/4 spacer gets here tomorrow. Anyone have any input on this? Tires are 12.50 wide
  2. Mar 1, 2024 at 3:45 PM
    2024TundraTRDsport
    2024TundraTRDsport New Member
    Mushroom
    2024 Tundra TRD Sport 4X4
    I may have the same rims and will post a photo. I hope to do this but after I do a leveling kit and a 2”-3” lift in hopes it won’t rub. IMG_0475.jpg
  3. Mar 1, 2024 at 3:46 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I've got 35x11.5 and mine barely fit. 12.5 will definitely rub.
  4. Mar 1, 2024 at 4:46 PM
    aklopez013
    Andrew
    So if I throw that 1/4 spacer it should be cleared right? Also have a Westcott coming soon
  5. Mar 1, 2024 at 6:32 PM
    lapoolboy
    lapoolboy New Member
    Westcott has several videos on trucks with 3/1 lift and 35x12.50 on stock 20" wheels with no issue.
  6. Mar 1, 2024 at 7:36 PM
    Breathing Borla
    Northern Illinois
    Westcott and load e, no mpg or ride quality complaint posts allowed
    PGW85706 and b6graham like this.
  7. Mar 1, 2024 at 7:55 PM
    aklopez013
    Andrew
    Should’ve clarified. I’m wanting to do this before the lift is put on. 1/4 shims get here tomorrow and gonna get the 35’s on. Keep y’all updated!
  8. Mar 2, 2024 at 8:13 PM
    aklopez013
    Andrew
    Stock 20” trd rims on 35x12.5 fit. 1/4 from tire to UCA
  9. Mar 2, 2024 at 9:41 PM
    23tundra75002
    23tundra75002 New Member
    Dallas
    2023 Tundra Platinum in celestial silver
    What makes the 35s fit on the stock 20’s is the huge positive offset from the stock trd or platinum/1794 rims. Any spacer is actually going to make the rubbing, if any, worst as all it does is it pushes the wheels out.
    What people uses the spacers on is the trd 3inch lift with 35s on stock 20’s as the tires rubs on the sway bar.
    If you search the forum there have been people successfully put 35/12.5/20s on with no issues.
  10. Mar 2, 2024 at 11:33 PM
    lapoolboy
    Is this with the 1/4" spacers installed?
  11. Mar 3, 2024 at 3:01 AM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    There are literally a hundred videos about this on YouTube
    And I wouldn’t listen to some high schooler that works at discount tire
  12. Mar 3, 2024 at 9:05 AM
    aklopez013
    Andrew
    I didn’t put the shim on and it’s clearing the UCA. Still waiting on the westcott kit to come in.
  13. Mar 3, 2024 at 9:06 AM
    aklopez013
    Andrew
    I’ll post pics in a bit.
  14. Mar 3, 2024 at 9:10 AM
    lapoolboy
    I have the 3" lift with TRD 20" wheels. I've pretty much decided on the new Falken Wildpeak R/T in 35x11.5x20. Mostly because they are one of the only 35" that wasn't load E rated. Discount Tire has to order them in so I can't test-fit them first....I *think* they will fit fine with no rub based on my research. It seems most guys are switching out wheels also so it makes it hard to determine what tires fit with stock wheels. Interested to see your pics.
  15. Mar 3, 2024 at 11:49 AM
    aklopez013
    Andrew
    Few pics
  16. Mar 3, 2024 at 12:26 PM
    lapoolboy
    Looks fantastic! Got a full side shot?
  17. Mar 3, 2024 at 4:03 PM
    aklopez013
    Andrew
    Can’t wait for the lift to come in so it’ll look 10X better
  18. Mar 3, 2024 at 4:25 PM
    lapoolboy
    I see there are no mudflaps....rubbed them I assume? And did you have to pin back the fender liner also?
  19. Mar 3, 2024 at 4:28 PM
    aklopez013
    Andrew
    For some reason they had no mudflaps, not sure if the 24’s they decided to not include them on the SR5’s. I removed those brackets behind the liner and pinned it back and no rubbing anywhere.
  20. Apr 9, 2024 at 2:51 AM
    TomMarkz
    TomMarkz New Member
    24 Tundra TRD Pro
    Will changing the stock tires to bigger ones void warranty? I just got ‘24 TRD Pro.
