35" Nitto Mud Grapplers on stock limited wheels?
Discussion in 'Wheels & Tires' started by Joseg, Mar 5, 2021.
  1. Mar 5, 2021 at 9:37 AM
    Joseg
    Joseg [OP] New Member
    Has anyone fit 35” nitto mud grapplers on the stock limited wheels if so what is the lift needed to make this set up work
  2. Mar 5, 2021 at 11:03 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I think that most of us here (if not all), do not even know what the hell a 4th gen limited Tundra even looks like, let alone how 35" Nitto Mud Grapplers will fit on the wheels... which, btw, we do not have any idea what the exact size of the OEM wheels will be yet either. Do you know something that we do not?
    Saltyhero13, Oey12 and TRDFerguson like this.
  3. Mar 5, 2021 at 11:23 AM
    Joseg
    3rd gen tundra I put the wrong info
  4. Mar 5, 2021 at 12:32 PM
  5. Mar 5, 2021 at 1:00 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I think you would be to close to the UCA. That’s my guess but idk what offset they are.
    Joseg[OP] likes this.
  6. Mar 5, 2021 at 1:10 PM
    Joseg
    On the link that Jim sent it says Width: 8", Offset: +60mm, Backspacing: 6.85", Hub BoreDiameter= 110mm
  7. Mar 5, 2021 at 1:13 PM
    Joseg
    Do you think spacers would fix the running issue ?
  8. Mar 5, 2021 at 1:21 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Don't do spacers to fit 35's on a stock rim. Just please... for the sake of all of us tundra owners, don't make us look bad lol
  9. Mar 5, 2021 at 1:25 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    NO!
    Joseg[QUOTED][OP] likes this.
  10. Mar 5, 2021 at 1:44 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    You may need new wheels and lift :spending:
  11. Mar 5, 2021 at 3:59 PM
    Joseg
    Lmao ok no spacers then
  12. Mar 5, 2021 at 4:03 PM
    Joseg
  13. Mar 5, 2021 at 4:06 PM
    Funnyguy713
    Houston TX
    My 35s were rubbing with 6" lift, until I got Toytec bumper shims.
  14. Mar 5, 2021 at 4:13 PM
    Joseg
  15. Mar 5, 2021 at 5:44 PM
    Funnyguy713
    Houston TX
    Its a Pro Comp 6" but looking to replace the front top hats with coilovers. Just can't decide between the Pro Comp or the Rough Country Vertex
  16. Mar 5, 2021 at 6:29 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Probably not much help because mine is a 2nd gen, but I have 35" Trail Grapplers which are mt s also. They work fine, but they are not on stock rims. No rubbing, or any other problems, though the 7" lift probably helps.
