35" tires on 20" wheels or 35" tires on 18" wheels???
Discussion in 'Wheels & Tires' started by Henry2019, Mar 17, 2022.
  1. Mar 17, 2022 at 6:01 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    I'm curious to hear what the pros and cons of what each setup comes with? As well as what you folks prefer to run? Please do not attack each other as this is an open friendly discussion..
  2. Mar 17, 2022 at 6:10 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    20” wheels for show.
    17-18” wheels for off road go.
    Y0TA PR0, des2mtn, alb1k and 5 others like this.
  3. Mar 17, 2022 at 6:13 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Responses will be as follows:
    People that have 18" = you have more sidewall and rubber for off-roading, especially when aired down. More tire size options, lighter weight.
    People that have 20" = They look awesome, no difference in ride or off-road capabilities. Plenty of tire sizes, weight doesn't really matter.
    Haha :bananadance::boink::crapstorm:
    But in all seriousness coming from a guy that's had both. It really is personal preference, I truly believe that 90% of Tundra owners don't off-road seriously enough to reap the true benefits of arguing the sidewall debate. Also believe that the weight difference effects MPGs so minimally that it doesn't matter and if it does matter then maybe you shouldn't be driving a Tundra
    Slimdusty, Jpd0144, TravisJr and 4 others like this.
  4. Mar 17, 2022 at 6:21 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    Shouldn't 35" tires for 20 inch wheels be lighter than 35" tires for 18 inch wheels since its less rubber material?
  5. Mar 17, 2022 at 6:25 PM
    Jpd0144
    Jpd0144 New Member
    Jeff
    Louisiana
    21 CM Sport 4x4
    The whole air down deal is regional IMO.
    Here in the south if you hit a rut wrong and your aired down you knock your bead off unless using bead lockers. The swamp mud doesn’t require air down but more so height and width (High center). To each their own (Or region). Not everyone crawls rocks in the US.
    For as ride comfort … it’s overrated again IMO. Cornering/handling and ride comfort are subjective agin by load rating, tire type, and PSI more so than 18 vs 20.
    :crapstorm::crapstorm::crapstorm::crapstorm::crapstorm:
    TravisJr, Henry2019[OP] and Medic343 like this.
  6. Mar 17, 2022 at 6:25 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    I was specifically talking about the weight of the wheels. But for your question, most tires in 35 inch sizes are load range E and 55+ pounds each so the what does it really matter.
    Henry2019[QUOTED][OP] likes this.
  7. Mar 17, 2022 at 6:50 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    My E-rated 33" tires are sixty-six pounds.
    Wheel weight? I'm sure the 20" weight more.
  8. Mar 17, 2022 at 6:51 PM
    r1-superstar
    DB
    UTAH
    It's a matter of preference really, perhaps also looks and availability of the product.
  9. Mar 17, 2022 at 6:52 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    I said most...
    Also said the 20s would weigh more...
    Read my original post
    Henry2019[OP] likes this.
  10. Mar 17, 2022 at 7:14 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
  11. Mar 17, 2022 at 7:19 PM
    Jpd0144
    Jpd0144 New Member
    Jeff
    Louisiana
    21 CM Sport 4x4
    And the ones that are smack dab in the middle 90% of the trucks life/primary use…
  12. Mar 17, 2022 at 7:22 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Im on a 17" with a 32.5 going to a 34. I am in the 18" wheel camp for you, on or off road. Unless you never go offroad.
  13. Mar 17, 2022 at 7:30 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    The more side wall acts more like a cushion while off roading having a smaller diameter rim will also keep your rims further away from obstacles and things that might damage them. it all comes down to personal preference and what build your going for I'm currently on 33x12.50R20s and I'm on that dilemma my self weather or not to get 35's for my 20's or get 18's and 35's.
    Jpd0144 likes this.
  14. Mar 17, 2022 at 7:41 PM
    NueveTundra
    Planet Earth
    I'll be honest If I had the money, I'd switch to 18's or 17's. But I do use my low profile tires in different terrains just fine. But also my build has changed 5 times and the 20's are result from the 1st when I was going OEM Bull Dog look.
  15. Mar 17, 2022 at 7:44 PM
    alb1k
    Left Coast
    It's good
    The 20's look like a lot of wheel to me on that truck.
  16. Mar 17, 2022 at 8:29 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    I’m not going to argue one way or another. It’s what you like and what you are happy with. For me it’s 17” and 35’s. I did attach a picture for reference while I was making the switch from 20’s to 17’s
    CA309CA8-B488-4B37-9C4E-04A789DFD006.jpg 37D064D1-6AB7-47ED-9B48-14E41A9EBF15.jpg
    Henry2019[OP] and Jpd0144 like this.
  17. Mar 17, 2022 at 8:31 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    Grouser likes this.
  18. Mar 18, 2022 at 7:53 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    IMO 20's and 35's are best looking combo for these truck. Perfect balance of wheel and rubber I think. Here is my truck with 20's and 34's. I think I'll move up to 35's when these need to be replaced.
  19. Mar 18, 2022 at 7:55 AM
    mountainpete
    ^ Truth
    Medic343[QUOTED] and Jpd0144 like this.
  20. Mar 20, 2022 at 10:50 AM
    Okierunner
    Okierunner New Member
    2020 TRD Offroad Crewmax
    Icon UCA Bilstein 6112/5100 Method 17s Ridge Grappler 35x12.50 Trd Dual exhaust
    I can’t comprehend a 20” wheel on a 4x4, but it’s obviously very popular. Now if you’re running 40s or 42s then maybe. I’m a 17” wheel guy. I could do an 18 but I think most of the available 18” offsets look wimpier than a 0 offset 17. Gimme a wide offset and a meaty sidewall all day long.
    NueveTundra and 20GR8 Super like this.
