35x11.50R20LT on Stock Rims and Leveling Kit
Discussion in 'Wheels & Tires' started by davidbii, Sep 11, 2020.
  1. Sep 11, 2020 at 2:45 PM
    davidbii
    davidbii [OP] New Member
    David
    I tried search for this setup and couldn't find anything...is anybody running similar specs and have a rub-free experience? I see that a 34" fits ok, but not sure if a full 35" would fit...thanks!
  2. Sep 11, 2020 at 3:02 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Plenty of info on this site, suggest you start here https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/.
    And a level kit could be many things- couple inch spacer, lifted coils, full front suspension with UCA.....what are you considering?
    Regardless, you will be doing some trimming of plastics, maybe remove mud flaps, maybe body mount chop. Also post your specific tire you are considering. They can range in height and width based on the manufacturer, even if the side is stamped 35x
    Medic343 likes this.
  3. Sep 11, 2020 at 3:12 PM
    timsp8
    NY
    I’d say you need at least 3” to run a 35. And with stock rims you will probably rub the uca. Most go to an aftermarket wheel with at least +25 mm offset.
    Medic343 and HulkSmurf14 like this.
  4. Sep 11, 2020 at 3:27 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I'm running 35x11.50r20 Nitto Ridge Grapplers on a 3 inch. No cutting, no trimming, no CMC, etc. I only have a slight rub at full lock in reverse sometimes. Not using stock rims though....
    Aught16TSS likes this.
  5. Mar 22, 2021 at 3:51 PM
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
    Medic what offset are you running on your wheels. I’m about to do a 3.5” lift and plan to run 35x11.50 ridge graps on my stock tss rims (+50). I have 1.25” spacers in case I need them. If it doesn’t rub on stock wheels I’m going to sell the spacers
  6. Mar 22, 2021 at 7:51 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    I got the wheels a little over 3 years ago so I don't remember 100% but I'm pretty sure they are +35. Looking up the wheels I have on, their website say they offer them in +35 and +10, but I'm sure I chose the +35 to stay as close to the stock look as possible.
    Aught16TSS[QUOTED] likes this.
  7. Mar 23, 2021 at 6:53 AM
    Aught16TSS
    J
    Tuckasee
    Awesome! Thanks for the info. Just found out my lift is on backorder. I’ll post some pics when I finally get it put on.
