35x12.50x20-- No rub
Discussion in 'Wheels & Tires' started by Heeler13, Aug 20, 2018.
  1. Aug 20, 2018 at 12:00 PM
    Heeler13
    Heeler13 [OP] 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    Just thought i'd share for people looking to do a similar setup.
    -20x9 XD Hoss (+30 offset)
    -35x12.50x20 RBP m/t
    -LRO 3/1 kit w/ Bilstein 5100 rear shocks
    Zero rubbing anywhere. Removed front tiny flap and front mudflap, but prob could've left the mudflap.20180820_144806_HDR.jpg 20180820_142220_HDR.jpg
    ncomeau35, TRDblvd, Dgjman and 14 others like this.
  2. Aug 20, 2018 at 12:15 PM
    Mr. Rogers
    Mr. Rogers New Member
    Forsyth, Ga.
    2017 MGM Tundra TRD 4x4 SR5
    Toytec/Eibach 3"coilovers, JBA uca's, 1" rear blocks with bilstein 5100's, Nitto RG's 295/70/18
    looks great!
    Heeler13[OP] likes this.
  3. Aug 20, 2018 at 3:16 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    I LOVE IT!!!!!!!!!!!!! Might be what I do to mine. Thinking the same kit and keeping my 20" wheels and just getting tires. Was thinking 275/65-20's.
  4. Aug 20, 2018 at 3:21 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    Just got my 35's delivered today! I'm doin g a +20 offset though, so good to hear! Got a side shot to show how far out the tires are sticking out?
    jewsNbrews likes this.
  5. Aug 20, 2018 at 4:08 PM
    Heeler13
    Heeler13 [OP] 21MGM
    Eastern NC
    2021 Sr5 XP
    Heres side shot.
  6. Aug 20, 2018 at 4:10 PM
    Heeler13
    Heeler13 [OP] 21MGM
    Eastern NC
    2021 Sr5 XP
    I love it so far. TuFerLife u may have to trim a lil with the +20 offset, but these trucks look great imo w/ anywhere from +18 to +30
  7. Aug 20, 2018 at 4:12 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    Man, that’s pretty! I hope +20 doesn’t put me in no man’s land. I was trying to do no flares. But if I do flares, I think i’d have to do 0 offset to get them to poke enough so the flares don’t swallow it up.
    Ugh, decisions!!!!
    Yours is set up nice though!
  8. Aug 20, 2018 at 4:14 PM
    Heeler13
    Heeler13 [OP] 21MGM
    Eastern NC
    2021 Sr5 XP
    +20 should be fine without flares. I had 295/70/18 on my last Tundra with +18 offset and it looked really good.
  9. Sep 6, 2018 at 10:39 AM
    TuFerLife
    Taylor
    Chattanooga, TN
    4BE5DE5C-875F-495F-94D0-AB9D1C9AB59A_zps_916fc6b976b4667d2fdf4303a2a7f47e1a2493f2.jpg
    Here’s my install. Doesn’t look like I’m going to have to chop the body mount, but I’m definitely going to have to bend/cut the front liner... hoping a heat gun and bending can fix because I don’t want to start hacking a new truck.
  10. Sep 6, 2018 at 10:41 AM
    Heeler13
    Heeler13 [OP] 21MGM
    Eastern NC
    2021 Sr5 XP
    Lookin good. I actually had to end up bending in the front fender liner myself. Noticed after a couple days driving it was rubbing a tiny bit. Just heated it up and pushed it forward a inch or 2
    Dgjman and jewsNbrews like this.
  11. Sep 6, 2018 at 11:26 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Nice! Do you think a +40mm on 9 wide will also work? Basically it would be tucked in +10mm or .38”
  12. Sep 6, 2018 at 11:28 AM
    Looking good!
    Heeler13[QUOTED][OP] likes this.
  13. Sep 6, 2018 at 11:31 AM
    Heeler13
    Heeler13 [OP] 21MGM
    Eastern NC
    2021 Sr5 XP
    I
    I would say it should. I know with factory wheels (which i think is +60) i know people were running into issues with inner tire rubbing the UCA, but +40 should clear everything. Maybe small fender liner bending is all u should have to do once tires are on.
    jewsNbrews and Big J[QUOTED] like this.
  14. Sep 6, 2018 at 11:35 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Thanks saw American Racing ATX series AX201 has a 18x9 at +40mm and shows a 110.5 bore with our bolt pattern. Figured high offset might be best bet for avoiding chopping. Lol.
  15. Sep 6, 2018 at 11:36 AM
    War Machine
    War Machine SSEM # 5 3MW
    Hoping to do the same with mine. I have 33’s now, and they look a little small. I honestly don’t know what my lift is though. It was on there when I bought it.
  16. Sep 6, 2018 at 11:48 AM
    ZPMAN
    Minnesota
    I have 9×20 35×12.5 +20 offset with flairs
  17. Sep 6, 2018 at 12:23 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    That’s my exact setup. Would love to see pics.
  18. Sep 6, 2018 at 12:53 PM
    ZPMAN
    Minnesota
  19. Sep 12, 2018 at 5:36 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    What did you do to heat up the fender liner to push it in?
  20. Sep 13, 2018 at 6:53 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    What suspension/lift you running? Truck looks GREAT btw!!
  21. Sep 13, 2018 at 11:04 AM
    ZPMAN
    Minnesota
    It's a tuff country 4" lift, pros are you won't break your piggy bank on it, only need a spring compressor and air or electric impact for install. Can be installed in a day I put 35s (34.8)in with no trimming just a little heat to move front wheel well plastic fwd 1/4 to 3/8" and a little bend to the eng.splash guard by the sway bar. Cons are this lift will shorten your CV life due to the angle. The ride is a little stiffer up front than stock (i like it and no need for front sway)due to the 1" aluminum spring spacer. The kit does not come with front stop block extensions. Rear brake line bracket has to be checked for proper clearance at full extension.
    https://www.suspensionconnection.co...MD30Izg0YE8SIn3xe-uy-76COuxFNOVhoCSOMQAvD_BwE
    r1-superstar[QUOTED] likes this.
  22. Sep 13, 2018 at 11:40 AM
    2015Crewmax
    2015Crewmax New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    I have a 3" rough country kit. I have the factory 20" split 5 spokes. i would like to put 35x12.50x20 on it. i'd probably need spacers?
  23. Feb 17, 2019 at 7:22 AM
    76on40s
    76on40s New Member
    Angelo
    2014 Tundra Xsp-x
    Wonder if this will work with just my Bilstein 5100s on the top notch?
  24. Feb 17, 2019 at 7:37 AM
    Looks good!
    Mine came lifted already, 6" running 35's 12.50x20, wheels 20x9 +20 have the mud flaps in front no rub
  25. Feb 17, 2019 at 3:29 PM
    Heeler13
    Heeler13 [OP] 21MGM
    Eastern NC
    2021 Sr5 XP
    I think Bilsteins on top notch is 2.5". I think it'll depend on wheel offset. You'll prob have to do a cab mount chop. I had 295/70/18 on my last Tundra with Bilsteins on top notch. Those tires are a little smaller than a 35/12.50. Had Procomp 7032 wheels. I had to trim ALOT.
  26. Feb 17, 2019 at 3:30 PM
    76on40s
    76on40s New Member
    Angelo
    2014 Tundra Xsp-x
    +30
  27. Feb 17, 2019 at 3:34 PM
    Heeler13
    Heeler13 [OP] 21MGM
    Eastern NC
    2021 Sr5 XP
    It'll be close. You'll prob rub. You could probably trim enough to make it work though. +30 isnt as extreme as some of the others out there.
  28. Feb 11, 2021 at 12:26 AM
    Calidude7
    Calidude7 New Member
    did you went that route? im trying to install 35 using the bilsteins 5100 too.
  29. Feb 11, 2021 at 2:20 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Might want to look into front bumper shims if still rubbing. Installed some Toytec on mine and I got my turn radius back with no rub on my 35s with negative offset. 20210122_161439.jpg 20210122_173617.jpg
  30. Feb 11, 2021 at 2:32 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
