3D Print - new fuse cover for fuse tap add-a-circuit
Discussion in '3rd Gen Tundras (2022+)' started by raylo, Feb 16, 2023.
  1. Feb 16, 2023 at 2:09 PM
    raylo
    raylo [OP] not so new member
    Frederick, MD
    I just installed a dash cam and I used two add-a-circuit fuse taps in the passenger side fuse box below the glove box for switched and constant +12V. The OEM fuse box cover won't go back on since it has zero clearance to the fuses. This new cover gives you room for the add-a-circuit taps. You really don't need a cover here but it does contain the fuse map and I have included a file to print to add that to the new cover. So, why not?
    2022+ Tundra Fuse Box Cover add a circuit fuse tap by raylo32 - Thingiverse
    BikeAR, ghunter321 and KClav like this.
  2. Feb 16, 2023 at 2:16 PM
    raylo
    Frederick, MD
    Must be a TV issue. Not the most reliable web site in the world. :-/ It has been published but it's not showing up on the "newest" list yet. You can try again later, or I can PM you the STL file if you want.
    ryanwgregg likes this.
  3. Feb 16, 2023 at 6:29 PM
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    Is this something you would consider selling? would be awesome, especially for people who dont have a printer...
  4. Feb 23, 2023 at 10:52 AM
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    Thanks so much for sharing this file! It looks like there are 2 parts on top that are floating a couple millimeters above the body. Does anyone better at computers than me have the technical know-how to fix this? It there a downloadable software where I can fix it myself before print? Thanks again, I don't want to sound like a choosy beggar!
  5. Feb 23, 2023 at 1:03 PM
    raylo
    Frederick, MD
    Not sure what you mean, I just downloaded the posted file and had a look at it and I am not seeing anything like that. Just print it. There are two 1mm "threads" attached to each side of the spring tab to keep it from falling over whislt printing before it gets joined the top. This to avoid needing supports to print. It is in the instructions... just cut those after you print it.
  6. Feb 23, 2023 at 1:31 PM
    ghunter321
    NC
    Ahh ok! I'm not well versed in these things so I was going to have a local 3d print shop print it out and that was their note. Thanks again for putting this together. It's exactly what I need!
    For reference: This is the angle the shop sent me:
  7. Feb 23, 2023 at 2:21 PM
    DFS
    DFS New Member
    2022 Capstone Tundra
    I'll PM you a STP file they should be able to use or whatever version you would like.
  8. Feb 23, 2023 at 2:21 PM
    raylo
    Frederick, MD
    OK, I added a little filler to those areas and reposted the file. It printed fine before so it should also print fine, or better, now.
  9. Feb 23, 2023 at 8:05 PM
    chance12
    chance12 New Member
    GA
