3in Rough country lift is done
Discussion in 'Wheels & Tires' started by 2013DC, Sep 4, 2017.
  1. Sep 4, 2017 at 12:41 PM
    2013DC
    2013DC [OP] New Member
    Wheels will be here tomorrow. Now to decide on the tires. Stock tires are 275/65r18, there looks to be room for 295/70 but not completely sure. Wheels are 18x9 with +12 offset. Is there anything or anyway to measure to see if the will fit without rubbing?
  2. Sep 4, 2017 at 5:51 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    You go with the spacers or the new struts? I just did the new struts on mine Saturday, getting aligned and mounted up tomorrow morn. Going with 305 70 18 on +18
  3. Sep 4, 2017 at 5:54 PM
    2013DC
    Spacers. Bought this truck for my son's 16th birthday. Not enough left in the bank for much else.
  4. Sep 4, 2017 at 5:57 PM
    Berdine
    Binghamton, NY
    On my 07 I ran same lift. 325 65 18s on +12. I had to remove both of the front mud flaps and had little rub at full lock. You should be fine. Might have to do the same.
  5. Sep 4, 2017 at 6:01 PM
    2013DC
    That's awesome. Found a tire 285/70 that is a 34". If 295 only had a minor rub, 285 should be good without rubbing?
  6. Sep 4, 2017 at 6:04 PM
    Berdine
    Binghamton, NY
    Should be, a lot of guys run 295s, you should be fine with the body mount, I never had to mess with mine
  7. Sep 4, 2017 at 6:06 PM
    2013DC
    That would be great. Don't mind a little plastic cutting, just really don't want to start cutting steel
  8. Sep 4, 2017 at 6:18 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    285/70 is safe to fit with your setup without cutting any steel. Im running 305/65/16 on same size/offset wheels. if you go 295/70 there is good chance you have to do the BMC due to your wheel offset.
