3rd Brake Light Leak
Discussion in '1st Gen Tundras (2000-2006)' started by NickB_01TRD, Jul 26, 2021.
  1. Jul 26, 2021 at 11:09 PM
    NickB_01TRD
    NickB_01TRD [OP] You don't need less cars, just more driveway.
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I searched around but never really found the perfect answer to my problem.
    Getting water in either rear cab corner when it rains. I see a lot of posts talking about the rear window drains but my issue seems higher up.
    My main question is, is the easiest way to deal with this just to remove the third brake light lens only and then caulk around the actual light assembly (truck metal to light housing)? Heard also it is best to only caulk from the 9 to 3 position and leave the bottom open (not sure where I saw that post).
    My truck sits at a slope in the driveway with the rear being the lowest so I'm sure that doesn't help. At the moment I also have the front cowl clip leak to deal with.
    (I work nights I'll respond when I'm able)
    Thanks to all!
    Toyoda Tundra likes this.
  2. Jul 27, 2021 at 5:36 AM
  3. Jul 27, 2021 at 5:40 AM
    NickB_01TRD
    Nick
    KY
    That may work well. Heard from others there was no new replacement parts. Might just be no more OEM seal. Guess I have to drop the headliner enough and remove the rear bolts from what I've been reading.
    Have you used this seal yourself?
  4. Jul 27, 2021 at 5:45 AM
    The seal is applied from the outside. No need to remove the headliner. Just remove the two screws that hold the third brake light in place, pull the light out (really just the lens I believe), remove the old seal and clean the surfaces up real good. Apply new seal and re-install. Great time to upgrade the light bulbs in there for higher output LED cargo lamps and brake lights.
  5. Jul 27, 2021 at 6:01 AM
    NickB_01TRD
    Nick
    KY
    This looks to be the one that seals the back side of the housing to the cab. Which I believe is where my leak is. Screenshot_20210727-085738_Samsung Internet.jpg
    Thought I saw somewhere about just sealing around the outside of the light after removing the lens. Have to see if I can find it. Don't want to break any part of the 3rd brake light housing by taking it apart if i can help it.
  6. Jul 27, 2021 at 6:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Personally, I would try just replacing the gasket before I busted out the caulk gun. I don't know about you, but my caulk beads never look that great and I feel like you'd just make it look like crap.
  7. Jul 27, 2021 at 6:35 AM
    NickB_01TRD
    Nick
    KY
    Very true. Probably would be better to just do it right and be done with it. Gonna do a bit more looking on here and find a good thread about it. If I don't find much I'll try and do a small write up about it.
    Just know I may need to pull the rear headliner out. Just have to try and see.
  8. Jul 27, 2021 at 8:53 PM
    NickB_01TRD
    Nick
    KY
    @Tundra2
    I see you've had your 3rd brake light out at least once. Any tips or tricks on doing so? Have to remove headliner to access anything?
    Tundra2 likes this.
  9. Jul 27, 2021 at 10:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I wouldn't say that the headliner has to come, but it does make things a lot easier.
    Voss and bmf4069 like this.
  10. Aug 2, 2021 at 10:51 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Pulled out 3rd brake light to replace gasket and these clips were sitting inside, does anyone know where they go/clip on to?
    Tundra2 likes this.
  11. Aug 2, 2021 at 10:56 PM
    NickB_01TRD
    Nick
    KY
    They don't look broken or anything either. Did you just remove the screws on the outside of the truck and pull?
  12. Aug 2, 2021 at 11:06 PM
    Toyoda Tundra
    Not quite, only the lens comes off when you remove the screws, the housing is glued onto the truck, I just used a plastic pry tool and carefully separated the old gasket all around from the housing, once you do that you can pull everything out.
  13. Aug 2, 2021 at 11:30 PM
    NickB_01TRD
    Nick
    KY
    I see. Gonna have to tackle this one day soon. Just hoping not to break anything.
    Toyoda Tundra[QUOTED] likes this.
  14. Aug 3, 2021 at 3:02 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Dug through old photos from when I replaced mine with OEM. Worth every penny in my opinion.
    Red clip things are wire holders on the light assembly.
    They just hold the wires close to the assembly is all.
    FWIW, the sheet metal up there is sharp.
    Voss, FrenchToasty, TTund16 and 2 others like this.
  15. Aug 3, 2021 at 3:09 AM
    NickB_01TRD
    Nick
    KY
    I'm gonna pull the cover off mine one day here soon and see how melted everything is and figure out how bad I may need a new one. When I got the truck both cargo lights were burned out so they may have been burned out for quite a few years and maybe it didn't melt too bad. I think the truck had a cap on it for quite a number of years as I have a paint match cap that I assume was purchased long ago. I really need to get some LED's for all this so I can keep it from melting any more. Gotta order some for the interior too.
    Tundra2[QUOTED] likes this.
  16. Aug 3, 2021 at 3:14 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    We already discussed my CD and JBWELD idea if you want to try to fix it. Lol
    Darkness likes this.
  17. Aug 3, 2021 at 3:16 AM
    NickB_01TRD
    Nick
    KY
    True true. Think I'll try and pull the lens when I get home from work to figure out what direction I need to go in.
  18. Aug 3, 2021 at 4:21 AM
    NickB_01TRD
    Nick
    KY
    Lens seal appears fine. Light to truck seal looks like garbage. Part of it doesn't even look like it's there at all anymore. Going to try and pull and replace seal this weekend.
    Only one small hole on the upper side of one of the light housings.
  19. Aug 3, 2021 at 8:02 AM
    Toyoda Tundra
    Thank you @Tundra2. Figured out where the clips go. Mine are quite bad, have burn holes on both side top and bottom
    Tundra2 likes this.
  20. Aug 3, 2021 at 10:10 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I replaced with OEM so I didn't have to worry about leaks. Back when I ordered my part, everything was about a $100 as a kit. I've brainstormed a cheap way, but I've never practiced it. Go to a local goodwill, and buy some Cds. Cut them into this shape below, or to fit over the holes in reflector. JBweld them into place for a water proof seal. Do top, ans bottom.
    I would almost bet money that @NickB_01TRD's red/white lens doesn't have a seal. Water is getting inside the reflector cups, and coming into the cab from the holes in the top, and bottom of the assembly.
  21. Aug 3, 2021 at 11:57 AM
    bmf4069 and Tundra2 like this.
  22. Aug 14, 2021 at 7:17 PM
    NickB_01TRD
    Nick
    KY
    Somehow I missed this post. Yes I looked through there a few times. That's how I found out about the front cowl clip leak. Got that one taken care of pretty quick.
    Here's my findings.
    Removed screws from housing and pulled and it came out pretty easy and it was obvious the seal was bad on the top section. I unhooked those red clips with the lens only removed by pushing the little tabs down and letting the clips fall back in the light. These actually seem to aid in keeping the light held in around the middle at least slightly. I found no need to pull the headliner to do this job either. 20210813_184321.jpg
    I used a plastic trim tool and some degreaser and some rags and just wiped this all away with a bit of time and effort. Didn't have the propane torch handy so just went for it. Turned out decent.
    I now realize I need to get better at taking pictures as these are the only two I got. I thought I took a picture of the light at some point but I didn't. It had a small hole over the top of one side but that was all. Not too bad really.
    New seal was the one recommended in this thread and it was pretty thick but seems like it will work fine. Time will tell. Put seal around light and reinstalled red clips and screwed light back in.
    shifty`[QUOTED] likes this.
  23. Aug 15, 2021 at 11:45 AM
    I dunno, I think what you posted was awesome. I'm going to update the 'definitive leak thread' with a link to this specific post, and people can scroll up to find the link to the aftermarket gasket also. Kinda wish the replacement gasket was rubber, myself, but beggars can't be choosers, I guess! I remember pulling the exploded parts diagram for this, just like with every other truck I've owned, I seem to recall they don't sell the damn gasket separately. Stuff like that really pisses me off.
  24. Aug 15, 2021 at 12:10 PM
    NickB_01TRD
    Nick
    KY
    I'm not sure that there ever really was a specific part for that in the first place. The stuff they use reminds me of what they use to attach and seal the moisture barrier inside of a door panel. Tacky and sticky. Almost like it was just a product that is dispensed from a tube.
    If I have issues with this at any point I'll probably pull the light out and use some type of caulk and see if it works. Hoping to not have any issues with this seal though.
  25. Dec 29, 2021 at 6:58 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Sorry to resurrect an old thread...did anyone ever figure out whether this gasket is for the light to cab seal (and not the lens to light).
    https://www.amazon.com/VIPMOTOZ-Gasket-Replacement-Weather-2000-2006/dp/B07S43QCZ6
    Toyota lists 81572-0C010 as "Center High Mount Stop Light Gasket", which is the lens to light gasket.
    As @Shifty states there is no OEM p/n for the seal between the light and the cab.
  26. Dec 29, 2021 at 8:02 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Is that light to body seal just goop? I got an oem light long ago, maybe I should check if it has a seal built in.
  27. Dec 29, 2021 at 8:45 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
  28. Dec 29, 2021 at 1:47 PM
    NickB_01TRD
    Nick
    KY
    That is also what I used housing to body.
    Yeah mine was just goop. It sucked to pull off. Seemed like the same kind of stuff they use to hold the moisture barrier on the inside of doors.
  29. Dec 29, 2021 at 2:07 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have some butyl strips from my headlight retrofit. Wonder if I can use that to replace the seal when I get around to replacing my housing. I need to stop being so lazy and get that done. I was waiting to buy LED bulbs, hoping they won't melt my new housing. Then I decided to wait until I can repaint my roof. I need to get that crap done.
    FrenchToasty likes this.
  30. Dec 29, 2021 at 2:14 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    If you got the assembly it should come with the proper seal
    Darkness[QUOTED] and Tundra2 like this.
