3rd Gen Tundra Locking Gas Cap Sourced
Discussion in '3rd Gen Tundras (2022+)' started by PNW Tundra Mike, Aug 15, 2023.
  1. Aug 15, 2023 at 12:22 PM
    PNW Tundra Mike
    PNW Tundra Mike [OP] Tired and ReTired
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Finally!! - I’ve just completed testing a high quality locking gas cap for the 3rd Generation Tundras, 2022+. It’s from Stant, a long time manufacturer of quality caps and the only aftermarket cap endorsed by Toyota. *Stant #10504* It’s the same cap recommended for my 3rd Gen Tacoma. I’ve run a tank on my ‘23 Limited after installing it and no emissions warnings were received. The O-ring seal is a perfect match. **IMPORTANT TIP- After you lock the cap, spin the cap so the knob handles are in the 9oclock/3oclock horizontal position. That allows the fuel door to close fully. Any other angle and the caps knobs will slightly hold the fuel door open***
    My Toyo dealer parts dept wants $36 for this cap. You can find it at O’Reilly Auto Parts for $16.99. You can reconnect the tether if you want it with a plastic body plug or a screw. Pop the old one loose to remove with a small screw driver.
    *Stant currently has no fitment entries for the Gen3 Tundra and failed to answer my emails.
    Stant cap on the left
  2. Aug 15, 2023 at 12:43 PM
    raylo
    raylo not so new member
    Frederick, MD
    How much clearance between the cap and door on your truck? I wonder if manufacturing and filler door and fuel tube neck installation tolerances might cause trouble for some of us even if placed in the correct orientation??
  3. Aug 15, 2023 at 12:53 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Thieves just punch a hole in the tank...I've yet to see someone pop a cap of and siphon it out. 3 coworkers have had holes punched in their trucks tanks
  4. Aug 15, 2023 at 12:54 PM
    raylo
    Frederick, MD
    We already had this discussion but this would help prevent sugar-in-the-tank vandalism from eco warriors or crazy ex-girlfriends.
    tesilential, ArcticEd, Oakman and 5 others like this.
  5. Aug 15, 2023 at 12:56 PM
    PNW Tundra Mike
    Southern Cal
    With the cap knobs at 9/3 my door is hitting its normal rubber stops. I found only when the bottom knob is at 6 or 7oclock does it lift the door from the rubber stops.
    raylo likes this.
  6. Aug 15, 2023 at 12:59 PM
    raylo
    Frederick, MD
    Sounds good, but if some of us have a filler tube that sits out even 1/4" more than yours it might still lift the door. IDK, I'd like to come try yours on my truck for fit... but you are 3000 miles away!
  7. Aug 15, 2023 at 1:00 PM
    PNW Tundra Mike
    Southern Cal
    Police just caught 2 guys in a BMW with a fuel pump mounted in the trunk with a long thin fuel hose. Thieves will be thieves. We can only stop some of them. I mainly dont want junk put in there.
  8. Aug 15, 2023 at 1:02 PM
    PNW Tundra Mike
    Southern Cal
    It's always returnable. I know NAPA used to sell Stant as well. I worked there. Im sure though it will be more than at O'Reilly.
  9. Aug 15, 2023 at 1:27 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    This is why I'd get one. My ex is malicious for absolutely no reason - to put it mildly.
  10. Aug 15, 2023 at 1:27 PM
    MedCityMoto
    An excuse to strap on a tank skidplate!
  11. Aug 15, 2023 at 1:31 PM
    raylo
    Frederick, MD
  12. Aug 15, 2023 at 2:40 PM
    PNW Tundra Mike
    Southern Cal
    Hope this happens to the guy who slides under my truck to drill the tank. YTVIDEO
  13. Sep 9, 2023 at 2:54 PM
    PNW Tundra Mike
    Southern Cal
    Heads-Up - A few days ago when I started the truck first time for the day I got a Check Engine Light and an error in the display reading “Parking Support Brake Malfunction. See your Dealer” Oh crap, here we go!! Hooked up my ECU scanner and it was an Evap leak. Checked my Locking cap and it wasn’t cranked down tight. Erased the code and all is fine. What a stupid code to show for a cap leak!! Not only a dumb code but it disables both cruise controls and the pre-collision system. Really? Come to find out this is the standard dash warning thrown for dozens of issues that have nothing to do with brakes. Beware!
    Onetrack97, itundra22 and Eurodriver like this.
  14. Sep 9, 2023 at 4:03 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    What country do you live in? Not in the USA in 2023. Theives can afford cars now and are highly mobile. And as coordinated as the Mafia.
    FrenchToasty likes this.
  15. Sep 9, 2023 at 4:11 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    The latest 2023 TRD Pro has a locking fuel door in case anyone want to leverage replacement parts from that vehicle. Just my two cents. :notsure:
  16. Sep 9, 2023 at 11:51 PM
    PNW Tundra Mike
    Southern Cal
    Thx - All 22/23 iForceMax Hybrid Tundras have a locking fuel door
  17. Sep 11, 2023 at 4:49 AM
    JeffC1
    JeffC1 1794 Army Green
    Jeffrey
    NC
    2023 1794 edition TRD option Army Green
    Do you have a link to the locking gas cap you found that works? Thx
  18. Sep 11, 2023 at 10:20 AM
    PNW Tundra Mike
    Southern Cal
    Cheapest I found it - O’Reilly Auto Parts
    JeffC1[QUOTED] likes this.
  19. Sep 11, 2023 at 10:28 AM
    itundra22
    itundra22 New Member
    2024 MGM Limited Hybrid 4x4
    I wonder if anyone with the non locking fuel door has installed the OEM locking fuel door and if it's possible to do so?
    Tundrastruck91 and Jack McCarthy like this.
  20. Sep 11, 2023 at 11:35 AM
    PNW Tundra Mike
    Southern Cal
    Haven't heard of anyone trying here. I highly doubt the harness is there from the door to the dash control panel where the switch is normally located.
    Sure would have been nice to have that option in yet another package ;-)
    Hecteasy likes this.
  21. Sep 11, 2023 at 11:47 AM
    itundra22
    Honestly this should have been a standard feature when consumers are paying well over $50k for a pickup truck - not sure what Toyota was thinking here.
  22. Sep 11, 2023 at 5:11 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    True, but if you look below/behind the side wall there is a pull cord to open the locking fuel door in case the switch/electronics quit working.
  23. Sep 11, 2023 at 5:17 PM
    Oakman
    Oakman New Member
    Michigan
    What's the difference between 10504 vs 10504KA ?
  24. Sep 11, 2023 at 9:38 PM
    PNW Tundra Mike
    Southern Cal
    KA is Keyed Alike - Two Caps
    Oakman[QUOTED] likes this.
  25. Sep 11, 2023 at 9:40 PM
    PNW Tundra Mike
    Southern Cal
    Hmmm. That’s interesting. So maybe there’s a chance for a simple manually operated locking door.
  26. Sep 13, 2023 at 5:29 AM
    Adventurer
    Adventurer New Member
    2023 1794 TRD 6.5 Celestial Siver
    Cheap!
    Woocawachie likes this.
  27. Sep 13, 2023 at 4:38 PM
    PNW Tundra Mike
    Southern Cal
    Let us know how that works out. I tried two of these No-Name caps and both threw codes on the Tacoma.
  28. Sep 13, 2023 at 6:10 PM
    Adventurer
    Aw crap, I got rooked lol. Didn't notice it wasn't a Stant. I'll just return it
  29. Sep 17, 2023 at 3:15 AM
    JeffC1
    Jeffrey
    NC
    Thanks Mike, so far so good!
  30. Jun 19, 2024 at 4:27 PM
    kt723
    kt723 New Member
    How has the locking gas cap been holding up? Just purchased a 2024 Tundra. Thanks
