3rd Gen Tundra TRD Off Road Max Tire Size Without Lift
Discussion in '3rd Gen Tundras (2022+)' started by alpinefd100, Apr 19, 2023.
  1. Apr 19, 2023 at 2:15 PM
    alpinefd100
    alpinefd100 [OP] New Member
    Hi guys,
    Just got my 23 Tundra Limited with TRD Offroad Package.
    Does the TRD Offroad package increases the rideheight compared to standard?
    *this is not the TRD Pro, not the TRD 3" Lift. Just the standard factory TRD Offroad Package.
    What's the largest tire size that can fit without rubbing, without additional lift.
    i hear 33" will work for sure, how about 34"?
  2. Apr 19, 2023 at 2:35 PM
    23LUNATRD
    23LUNATRD New Member
    23 Tundra SR5 TRD Off-road LunaRock
    I'm running Nitto Recon Grapplers 295/70/18 without any rubbing on my 23 TRD OR
  3. Apr 19, 2023 at 3:00 PM
    alpinefd100
    thanks ! great looking truck man
    front mudflaps still on?
  4. Apr 19, 2023 at 3:10 PM
    23LUNATRD
    They had to be removed
  5. Apr 19, 2023 at 3:39 PM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    What's your definition of "without rubbing"? Driving around on the road only, or flexing the suspension off the pavement? My 295/70 18s are capable of rubbing off road for sure and also contact the flares under near full compression up front. That is with about 1.5" over stock height in front. They never rub on road though. Just a thought to consider. I should also mention that is on aftermarket 18x9 wheels with +18 offset
  6. Apr 19, 2023 at 8:49 PM
    worksjo
    worksjo New Member
    2023 Tundra SR5 Off Road
    I did +25 offset wheels with 295/70/18 tires. Had to pull off the cheapo front mud flaps, tucked in the inner wheel well felt a bit just for good measure but not mandatory. Lots of room now, although I am about to do a leveling kit just for looks.
  7. Apr 23, 2023 at 9:20 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    Are those the SL recon grapplers, or the load range E?
  8. Apr 23, 2023 at 9:36 AM
    23LUNATRD
    E RATED
    DMackler likes this.
