3rd generation parking brake adjustment
Discussion in '2.5 Gen Tundras (2014-2021)' started by Philb, Mar 20, 2020.
  1. Mar 20, 2020 at 6:01 PM
    Philb
    Philb [OP] New Member
    Replaced all pads and rotors today. Found after work was completed the emergency brake was not holding properly. From looking at the shoes after removing the rotor appears that shoes are non adjusting. Any tips or procedure that anyone could recommend?
  2. Mar 20, 2020 at 7:15 PM
    Grandaddy
    Grandaddy New Member
    Roanoke Rapids NC
    2018 Tundra Limited CrewMax 4x4
    none
  3. Mar 20, 2020 at 7:25 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    You shouldn't need to adjust the cable since it was ok before the brakes were replaced. You just need to adjust the starwheel adjuster for the parking brake shoes. After the wheel has been removed you access it from the cut out holes in the face of the rotor. You just have to line up the hole with the adjuster wheel (at the bottem)and use a small flat blade screwdriver to rotate it upwards. I usually tighten till it locks the rotor from spinning then rotate the wheel down till its free again.
