4/2 BDS lift
Discussion in 'Suspension' started by iceburg, Jan 20, 2022.
  1. Jan 20, 2022 at 9:29 AM
    iceburg
    iceburg [OP] New Member
    2018 CM 5.7
    none yet
    I have a 2018 SR5 with a 4/2 BDS lift. She sits and looks level , slightly higher in the front. What are my options for a slight rake.? BDS doesn't have a 2.5 rear block.? I don't tow , might use for minor hauling . What options do I have ? Anyone have pictures of yours with slight rake ? Bigger tires coming at a later date. 20220119_102223.jpg
  2. Jan 20, 2022 at 9:33 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    shackles are probably the best option as far as reliability, ease of install and price. Are you on blocks now? Do you have factory rear shocks? Be careful with too much travel on the shocks, they should be rated for the lift that you have.
    AJGallo41 likes this.
  3. Jan 20, 2022 at 9:50 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    rear shackle or add a leaf, or all new lifted leaf springs. Shackle is often best for most, rides better, can lift from an inch to 1.5 depending on what you get, and install is easier than the others, cost effective too.
    If you do a lot of hauling and towing, you may want to look at RAS (activesuspension.com). Will lift about an inch but more importantly, stops squat when towing or loaded so you dont run around nose high in a lifted or leveled truck.
  4. Jan 20, 2022 at 9:57 AM
    iceburg
    2018 CM 5.7
    none yet
    Shocks in the rear are fox 2.0 . 2inch block is the rear lift. Not gonna be towing. Hauling might be a few hundred pounds at most. Thank you fellas, appreciate those options.
  5. Jan 20, 2022 at 10:38 AM
    2mchfun
    Shackles and extended bump stop height to compensate for the longer shackles. You don't want the long shackles to force the springs beyond their intended limits.
  6. Jan 20, 2022 at 10:45 AM
    AJGallo41
    AJGallo41 New Member
    Aj
    MN
    2016 Tundra Crewmax 5.7
    Level Kit 275/70r18 BFG KO2's
    Second this
  7. Jan 20, 2022 at 11:22 AM
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    toytec shackles at the 1.5 inch setting, got rid of my squatting on my 7 inch bds lift
