4 WHEEL DRIVE NOVICE
Discussion in '3rd Gen Tundras (2022+)' started by JRC, Nov 15, 2023.
  1. Nov 15, 2023 at 10:22 AM
    JRC
    JRC [OP] JRC
    James
    2022 LIMITED 4WD TRD OFFROAD -(NH)
    STOCK
    The manual (P 374) for the Tundra (2022) recommends the truck be driven at least 10 miles per/month in 4H- changing the transfer at speeds not exceeding 62 mph.
    I began my 10 miles for the month this morning and noticed when maneuvering into a parking space the truck made odd noises.
    I found out from my mechanic and for those who may not know- the front axles don't turn easily at 90 deg in 4 H- is this the case?
    This would have been good info for a 4W drive novice such as myself to know. Unless I missed it from the manual.
  2. Nov 15, 2023 at 10:25 AM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    You want to keep the 4wd in straight line only on non-slippery surfaces. Gears tend to bind when turning on pavement. In snow or on dirt roads it is a different story since it allows the tires to effective slip when turning.
    Even on dirt and snow you still want to be careful turning
    DFS, JRC[OP] and Jack McCarthy like this.
  3. Nov 15, 2023 at 10:26 AM
    You missed it in the manual. First line, “when driving on normal hard dry surfaces, use 2wd”
  4. Nov 15, 2023 at 10:28 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Dont drive in any 4wd mode on dry/hard surfaces....do it on a dirt road.
    Tripleconpanna and AZBoatHauler like this.
  5. Nov 15, 2023 at 10:45 AM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    Can dirt not be hard and dry?
    We can't all be offroad kings like you.
  6. Nov 15, 2023 at 11:06 AM
    JRC
    JRC [OP] JRC
    James
    STOCK
    Fair enough... thank you for all the feed back!
    FrenchToasty likes this.
  7. Nov 15, 2023 at 3:49 PM
    iforceAZ
    iforceAZ New Member
    It's perfectly fine on dry hard pavement in a straight line. I do it on a straight stretch of highway every now and then.
  8. Nov 15, 2023 at 3:54 PM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I have honestly only remembered to do this a handful of times in 20 years driving 4wd trucks and never had a problem with a 4wd system. Including my 09 Crewmax purchased new and trade at 113k and 13 years. For the most part my trucks have stayed in 2wd between late February and November.
    I also do transfer case and diff fluid changes by 60k at the latest as a habit though. Usually more like 40-50 for first one.
    JRC[OP] likes this.
  9. Nov 15, 2023 at 6:52 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I start doing this every week or so, for about 2 mile drive in a straight line.. Speed under 40 mph.
    I then start getting whining noise when driving above 76mph on highway... In 2wd of course.
    Coincidence or something didn't like me driving in straight line in 4wd on asphalt?
  10. Nov 15, 2023 at 7:17 PM
    It is in the book, but you're probably didn't hurt anything from only doing it once. Just pop it into 4WD on a straight road for a mile or two every so often and you'll be good. It doesn't have to be 10 miles all at once. When in 4WD you don't want to turn much, especially sharp turns, unless you are on a surface that will allow the wheels/tires to slip a bit to prevent the binding that you experienced on the dry pavement.
    I have about a mile of straight 55 MPH highway and another mile of straight 35 MPH dirt/gravel road in my commute. If you've got a mile or two of straight roads on your drives you can do the same thing I do. I'll pop it into 4WD once I'm turned onto the dirt road from my driveway, cruise the mile to the intersection with the highway and disengage 4WD as I am coming to a stop. Turn out onto the highway, and pop it back into 4WD once I'm traveling straight again. Then I just pop it out of 4WD before I turn off the highway to prevent any binding. The 4x4 system gets it's work out, and I don't have to worry about hurting anything so long as I am cognizant of the engaging and disengaging before making any major turns. A gradual turn in a road isn't going to hurt anything, but making a 90° turn off the street or into a parking spot is a no no.
  11. Nov 15, 2023 at 9:05 PM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    Dirt roads, in general and no matter how hard, have a loose top layer allowing tires to slip. This is very important for four-wheel drive systems that lock the driveshafts, like Tundras/Tacomas and the like. Not an issue for AWD systems. BTW, it is ok on paved road if it is icey/snowy. Somewhat ok on wet roads in an emergency.
  12. Nov 15, 2023 at 9:09 PM
    100% bullshit. I live on one, and after they douse it with mag water it hardens up and is not soft enough to allow slipping wheels. The only time it is soft enough is shortly after a repair run when they leave the layer of gravel on top, but that only lasts a few days before it's down to the hard packed dirt that is not soft.
    All the dirt roads in your area or your experience may have a soft upper layer, but that is not the case everywhere.
  13. Nov 15, 2023 at 9:14 PM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    @GODZILLA Ouch, 100%, really?! I did say, “in general”.
  14. Nov 15, 2023 at 9:24 PM
    You said "in general" and immediately followed it with "no matter how hard" so that's not being clear enough for someone who is admitting to being a novice. It gives the impression that all dirt roads are going to be fine for 4WD turning, and this just simply is not the case. I could have said it in a more PC way of "that's not true" or "that's not always the case", but being PC in everything muddies the waters. As my grandfather used to say, "don't drag your feelings out behind you and they won't get stepped on."
    I'm just trying to make sure the OP has all the correct info, because he openly states he doesn't know what is and is not ok for his 4x4 system.
  15. Nov 16, 2023 at 7:07 AM
    iforceAZ
    iforceAZ New Member
    So this occurs only after having driven it in 4wd first?
  16. Nov 16, 2023 at 7:52 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    This whining noise happens now all the time above 76mph. Or if I Rev engine at neutral above 2k rpm. I don't use 4wd anymore at all.
    This may or may not be related to me trying the 4wd on the road in a straight line, but I don't think this whine happened before I start doing this preventative maintenance once in a while
  17. Nov 16, 2023 at 8:14 AM
    iforceAZ
    iforceAZ New Member
    If it's making it in neutral that would seem to rule out the transmission.
    You think it would be the turbos kicking in?
  18. Nov 16, 2023 at 8:23 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    It doesn't sound like turbos, turbos are whoosh sound, very distinct and I like it.
    This sound is just whining sound and only happens when I press gas pedal, when rpms above 2k or when pressing gas pedal above 76mph.
  19. Nov 16, 2023 at 8:32 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Something to do with the devil's lettuce, I'll wager.
  20. Nov 16, 2023 at 5:14 PM
    Turbos don't whoosh. Wastegates do. Turbos 100% whine.
    This has nothing to do with you using 4WD.
  21. Nov 16, 2023 at 5:26 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    4x4 HI on these Tundras can be super annoying to get in and out of. Toyota must have a very conservative engagement/disengagement sequence. It can result in binding around corners like OP when you’ve selected back to 2wd a minute ago. (Or like on TFLtruck has demonstrated, you can be stuck in 2wd then flip on 4HI and watch it blink and never engage haha).
  22. Nov 16, 2023 at 8:36 PM
    JRC
    JRC [OP] JRC
    James
    STOCK
    I accidentally drove my Tundra in 4H on pavement to the post office thinking I was getting my "10 miles for the month in"- before I read this tread. My speed reached up to 40 mph with slow acceleration more like 37, I drove total about 2.5 miles, I made wide turns and didn't hear anything. I did park however, but it was a wide maneuver. I drove back to the office and before I parked- I had a feeling that I should put it back in 2H... and I did. I did hear a little noise from the front end while parking. I read the thread shortly after.
    After reading the thread of "do"s and don'ts" - I took it for a test drive and it performed great... no noises... strong acceleration... the transmission's smooth...parks well... the front-end handles great! I've only driven this truck 6 days and my previous truck was a 2007 SR5 V6 272K miles. As no surprise, I'm really enjoying the overall performance of this truck. This truck was a personal gift to myself.
    How concerned should I be that I broke something?
    GODZILLA likes this.
  23. Nov 16, 2023 at 8:50 PM
    Unlikely that you broke anything. Take the truck to a dirt lot, with loose dirt, and put it into 4WD and see if you get any binding, grinding, or popping. If it drives in 4WD fine, then you should be fine. Still, don't do tight turns in 4WD if it's avoidable.
    If you want the whys, try this video.
    https://youtu.be/4-Wy5ENm_lM
  24. Nov 16, 2023 at 9:04 PM
    JRC
    JRC [OP] JRC
    James
    STOCK
    Thank you for the advice. I have watched countless videos since the 3rd Gen came out demonstrating these trucks in 4WD drive on obstacle courses going over rock and holes and not once did I hear a warning about "you don't turn the front wheels at hard turning angles." I'm watching the wrong videos.
  25. Nov 16, 2023 at 9:13 PM
    We all learn somewhere. That guy's yootoob channel is a fairly good resource if you want to get into the engineering and reasons why for lots of mechanical stuff. Understanding what the 4WD system is doing will help you know what is and isn't ok for it, but Tacoma's aren't made out of fine china. I'm pretty sure you didn't hurt anything with your learning. :thumbsup:
    JRC[QUOTED][OP] likes this.
  26. Nov 16, 2023 at 9:24 PM
    Here is where some common sense comes into play. When off-road turning your front wheels in 4wd is fine. Just remember when the CV is at more of an angle, the weaker it is under power. Sometimes finesse goes a long way.
    To answer your original question, I would just engage the 4wd on straight roads on your daily commute once in a while. The 10 miles per month is a little much if you ask me. I can guarantee my wife never put her Toyota Tacoma's (2), 4Runner in 4wd once a month in her 10+ year ownership of her vehicles. Never had an issue engaging into 4wd.
  27. Nov 16, 2023 at 9:37 PM
    JRC
    JRC [OP] JRC
    James
    STOCK
    Thank you for the video.
  28. Nov 16, 2023 at 10:52 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    So you think that it's turbos that do the whining sound when I accelerate slowly above 76mph or Rev engine in neutral above 2k?
    Doesn't sound normal
  29. Nov 16, 2023 at 11:10 PM
    I have no idea what is whining in your particular truck. I'm just saying that turbos do whine. Also, if you are in neutral and can replicate it then I can't see any possible way it is related to your 4wd system.
    Kap1[QUOTED] likes this.
  30. Nov 16, 2023 at 11:17 PM
    Now, I can't speak for these trucks, but I did find these when searching for turbo whine. I drove diesels/semis for several years, and different engines had different amounts of turbo whine, and my WRX had a much quieter whine, so I don't know that I'd think it's a failing turbo if it's always been there. With yours just starting up, you may want to get the turbos checked while you are still under warranty.
    Turbos do spool up with a whistle/whine though.
