4Runner leveling kit question
Discussion in 'General Tundra Discussion' started by realtorblake, Mar 17, 2019.
  1. Mar 17, 2019 at 8:29 PM
    realtorblake
    realtorblake [OP] Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Have any of you folks put a leveling kit on a 5th Gen 4Runner 4x4? Looking at the ToyTec 2" front spacer kit. The wifes 4 Runner needed new rubber, so I bought her new 20" rims so she could use the takeoff Bridgestone Dueler tires that were on my new Tundra. It was going to cost me roughly the same to buy her new 18" tires for her existing rims. There is a slight rubbing problem on the stock fender flares at near full turn in reverse. I can either take off the fender flares and cut about 1/2" of the inside lip off them... or buy a leveling kit. Just don't know which brand is best for her needs. It's her daily commute vehicle, and may spend a few days in the beach sand... other than that, nothing worse than a WalMart parking lot I would think. :cheers:
  2. Mar 18, 2019 at 11:08 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Check out 4runners.com there are a number of threads on leveling kits. I would go with bilstein 5100s. They are fairly inexpensive and adjustable so you don’t have any bro lean going on. In my opinion the 5th gen needs a little rake to look right.
    realtorblake[OP] and Berdine like this.
  3. Mar 18, 2019 at 1:21 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I would skip the spacers if you can afford Bilstein 5100s. Have them on my wife’s 4Runner, I believe the 2nd setting, and leveled it perfectly.
    JH5370 and Berdine like this.
  4. Mar 18, 2019 at 1:26 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    JH5370 likes this.
  5. Mar 18, 2019 at 1:35 PM
    Quebec
    Quebec New Member
    Just do this and check it off the list.
    5100s on a grocery getter, yah ok.
