4Runner rims on 05 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Canatct, Dec 2, 2022.
  1. Dec 2, 2022 at 10:27 AM
    Canatct
    Canatct [OP] New Member
    2005 tundra
    I know this topic has probably been covered many times but are 2017 6 lug 17” 4Runner rims a direct fit for my 05 Tundra? My original rims look pretty rough.
  2. Dec 2, 2022 at 10:32 AM
  3. Dec 2, 2022 at 2:56 PM
    Lextech
    Lextech New Member
    05 Double Cab
    Yes
    FrenchToasty likes this.
  4. Dec 2, 2022 at 3:44 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  5. Dec 3, 2022 at 6:37 PM
    Phantom381
    Phantom381 New Member
    Nick
    05 Tundra AC, 2wd, Phantom Grey
    Eibach Leveling kit, Mbrp exhaust
    Yes sir, have them on my 05
  6. Dec 3, 2022 at 6:38 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Should be able to get a set for 100$ too since they are so common. Try Offerup, where I got mine for my 4R.
  7. Dec 4, 2022 at 5:18 AM
    Canatct
    2005 tundra
    My original 17s have a 30mm offset whereas the Tacoma has 1/2 that. Will that cause any problems with my stock 265/65/17 tires? I really don’t want to run a spacer.
  8. Dec 4, 2022 at 6:41 AM
    Phantom381
    Nick
    I doubt it, I have spacers up front because the 285/70/17s would rub my frame and a good quality spidertrax space fixed that but I doubt you'll have an issue.
  9. Dec 4, 2022 at 8:56 AM
    Canatct
    2005 tundra
    I got that wrong. Offset on mine is 15 and same on the 4Runner wheels are yr same.
    Would I be able to use my lug nuts?
  10. Dec 4, 2022 at 8:58 AM
    Phantom381
    Nick
    You should be able to, I used my stock ones so as long as they are the regular Toyota ones I believe they should be fine
