4wd actuator questions
Discussion in 'Sequoia 1st Gen (2001-2007)' started by KadeA, Nov 10, 2024.
  1. Nov 10, 2024 at 12:44 PM
    KadeA
    KadeA [OP] New Member
    2005 Sequoia Limited
    Hey everyone, I’ve of course had problems with my 4wd for a while. I have a 2005 sequoia with the center locker. I bought my sequoia with the 4wd not working. The lights on the dash for 4hi, 4low, and the center locker continually flash. I tried to replace the actuator myself and got in way over my head so I bought a used transfer case and put it in. Now it partially works. Just the 4hi and center locker light still flash continuously but I’m able to go in 4hi. I can’t get into 4low and getting out of 4hi back into 2hi is a real challenge. Before I rule out that I got another bad actuator I’m asking for help on any tests I can do. I’ve checked the vent hose on the actuator and it’s in good condition. I took the cover of the actuator and took a peek inside and there is no corrosion or rust inside (although I did see some finger prints on the gears so someone has been inside before). Could this be an electrical issue with the 4wd computer? Thanks.
  2. Nov 10, 2024 at 1:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Most likely water intrusion and corrosion on the actuator. There is a thread in the sticky section. Search is your friend on this forum.
