4wd not engaging on 2005 tundra double cab
Discussion in '1st Gen Tundras (2000-2006)' started by Mike Smith, Dec 17, 2023.
  1. Dec 17, 2023 at 3:23 PM
    Mike Smith
    Mike Smith [OP] New Member
    2005 tundra crew cab limited 4wd
    Eliminated secondary air system
    I have the continuous blinking light when pushing the 4wd button I have replaced the front actuator, the 4wd switch, the 4wd control module, checked continuity on harness that goes to the front actuator and the 4wd fuse in the engine compartment. I do have an abs code P1241. Anyone have any suggestions on what the problem might be. The transfer case actuator does work and engages the front driveline but the front axles do not lock.
  2. Dec 17, 2023 at 3:36 PM
    1BLUEsky
    1BLUEsky New Member
    BRETT
    2007 SR5 CREW MAX 4X4
    Hammerhead bumper, Fuel Shok wheels(18X9), Toytec 3/1.5 lift
    I have a second gen, but on mine there is a vacume line that runs to the front actuator that might be off or broken. You might also try tapping on the transfer case actuator with a rubber mallet as these can get gummed up. Check the condition of the harness and plug near that location as well. Once you get it figured out, put 'er in 4WD every now and then.
    shifty` likes this.
  3. Dec 17, 2023 at 7:05 PM
    Mike Smith
    Thanks for the info. I tried tapping on the actuator while wife pushed 4wd button . Removed front actuator, removed cover and all was good. Connected power to terminals 2 and 6 and motor works great in both directions. I manually engaged the front axles and installed actuator in 4wd position but when I started the truck it was in 2wd and the front actuator moved the axles from 4wd to 2wd. It would then not go back to 4wd.
  4. Dec 17, 2023 at 7:17 PM
    P1241 Or C1241?
  5. Dec 19, 2023 at 3:06 PM
    1BLUEsky
    1BLUEsky New Member
    BRETT
    I have never messed with a front actuator, but I did take apart the one on the transfer case as it seemed to be sticking. If its the same type, it likely looks like a flat clock spring. It is imperative that it is wound back tight and the toothed rack/plunger matches the gears properly . I had to watch a foreign speaking guy on YouTube and on the third attempt I got it right. Not hard, just not fun. Hope you get it going!
