4x4 making noises..
Discussion in 'General Tundra Discussion' started by Hvactech01, Nov 29, 2018.
  1. Nov 29, 2018 at 6:27 PM
    Hvactech01
    Hvactech01 [OP] New Member
    13 TRD OFF road
    Stock..... for now
    I have a 2013 crew max 4x4. We got alot of snow tonite. Had to use 4x4. Clicked it in, while driving I hear a clicking/taping noise that comes and goes depending on speed and how much I'm accelerating. So clicked it out and noise kinda fades out like something was slowing down from spinning. And their is also a kind of.... humming/really slight grinding noise. When I'm accelerating. Volume of noise depends on how much I'm accelerating. Is their a known issue in the 4x4. Or am I'm i F'ed.
    Going to be taking it to my father in law shop next week to sr5 what we could find out. Just wanted to see if their was anything you guys knew about already. Thanks
  2. Nov 30, 2018 at 2:13 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    Sounds like your traction control kicking in and out.
    rodm1 and ColoradoTJ like this.
  3. Nov 30, 2018 at 2:44 AM
    Traction control. I turn it off in snow when in 4 wheel mode. It's very annoying.
    rodm1, speckmon and ColoradoTJ like this.
  4. Nov 30, 2018 at 5:09 AM
    I agree with these guys ^^
    Now if you were hearing a grinding noise and wheel spin was not happening, there are a few TSB’s that can be addressed.
    http://www.toyotaproblems.com/models/tundra/tsbs/2012/
    Backing plates
    Front differential needle bearing (drivers side)
    Black Wolf and T-Rex266 like this.
  5. Nov 30, 2018 at 5:19 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    x4
    does the gas peddle push back at you when this is happening, kind of like a vibration/pulsing? if so then it's definitely TC. turn TC off when you're in 4x4 and see what happens, the truck will respond better.
    i drive like a madman in the snow compared to other, more conservative folk, but these trucks turn into a TANK when 4x4 is engaged and i trust it fully
    ColoradoTJ and Black Wolf like this.
  6. Nov 30, 2018 at 6:08 AM
  7. Nov 30, 2018 at 11:30 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    How do you do this once you are in 4x4?
  8. Nov 30, 2018 at 12:21 PM
    speckmon
    Thornton, CO
    I've got an '07 but just hold the TC button for 5ish seconds
    Black Wolf and Ronin73[QUOTED] like this.
  9. Nov 30, 2018 at 12:48 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m thinking u-joint failure on the front driveshaft since it fades out when you shift back to 2wd.
    Traction control would get way more active in that situation IMHO.
    Have the u-joints been greased regularly?
    NjPro likes this.
  10. Nov 30, 2018 at 6:20 PM
    Hvactech01
    13 TRD OFF road
    Stock..... for now
    I tried the traction control thing didn't work. And I'm not sure cause the truck is new to me about a month ago.
    landphil[QUOTED] likes this.
  11. Nov 30, 2018 at 6:21 PM
    Hvactech01
    13 TRD OFF road
    Stock..... for now
    I tried it and it didn't work still makes the noises
  12. Nov 30, 2018 at 6:23 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    "THERE" may be your answer...
  13. Dec 1, 2018 at 3:30 PM
    speckmon
    Thornton, CO
    Sounds like you should just go to the dealer
  14. Dec 3, 2018 at 12:08 AM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Is it normal for a a clunk sound to happen when engaging 4hi or 4lo? Only when initially engaged
  15. Dec 3, 2018 at 3:56 AM
    Yes
  16. Jan 23, 2024 at 8:17 AM
    TDOGa
    TDOGa New Member
    Trent
    2011 sequoia, 2014 camry
    Did you ever find out what the issue was? My wife’s 2011 sequoia is having a similar issue. I think it is because she has not been putting it into neutral before going into 4wd. It started making noises at freeway speeds when not in 4wd and it started to get worse. I am thinking it is an issue with the 4wd actuator (perhaps the alignment of the teeth). Last night I tried to put it into 4 hi then 4 low to see it would reset itself, but it just beeped and the 4 low light flashed and the car wouldn’t go into gear. After trying for a minute it turned the car off for about 5 minutes, started it against and this time when I cycled through 4hi and 4 low it wend back into gear. After taking it back out of 4wd I got onto the freeway again and the noise was still there and maybe even louder.
