5.7 headers on a 4.6?
Discussion in '2.5 Gen Tundras (2014-2021)' started by KLLVMDCL, Jul 8, 2019.
  1. Jul 8, 2019 at 2:21 AM
    KLLVMDCL
    KLLVMDCL [OP] New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    The design of the 5.7 headers seems superior to the 4.6 log style.
    Will they bolt up?
    Will the front pipe from the 4.6 fit?
    I know aftermarket headers are available but if I can fine a cheap set from a wrecked 5.7 it might be a mild upgrade on the cheap
    SiberianTundra likes this.
  2. Jul 8, 2019 at 9:18 AM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    subscribed. curious my self since I am 4.6
  3. Jul 8, 2019 at 9:25 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Do the engines share the same exhaust manifold gaskets?
  4. Jul 8, 2019 at 11:44 AM
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    That would be the easiest way to check if they are different or the same. order a gasket of each engine size.
  5. Jul 9, 2019 at 12:16 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    yes it looks like the manifold gaskets are the same part for both 1UZ and 3UZ
  6. Jul 9, 2019 at 5:38 AM
    jdmek998
    jdmek998 New Member
    That would lead me to believe they should fit. Just check to see they are about the same length to the exhaust.
  7. Jul 9, 2019 at 8:38 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    me too, but the problem is that the front pipe(technically mid pipe) for the 4.6 and 5.7 are different part numbers and i cant find specs to compare the two
  8. Jul 9, 2019 at 9:06 AM
    619Tundra and 15whtrd like this.
  9. Jul 9, 2019 at 9:10 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I would assume there is a reason for the difference.
  10. Jul 10, 2019 at 1:16 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    it just seems to me that since the 5.7 headers are similar to most aftermarket designs they would be an upgrade
  11. Jul 10, 2019 at 5:09 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Roger that.
    I'm no exhaust expert, never even saw the 4.6 headers, just generally doubting Toyota would skimp on the 4.6 headers. It seems like it is pretty hard for aftermarket companies to make a more efficient exhaust for a stock setup, like Toyota made the system near perfect.
    Then again our trucks don't have an auto headlight feature, haha.
    Following to learn more... Good luck getting the scoop.
    Rex Kramer likes this.
  12. Jul 10, 2019 at 6:14 AM
    jdmek998
    jdmek998 New Member
    Your best bet would be to find a cheap set of stock 5.7 headers and take them to a good exhaust shop or tuning shop. They should be able to fab up the rest of the piping to make it work. Pretty much the same thing as custom exhaust. Just all depends how much money you want to sink in it. I would probably leave it alone. Unless you are slapping a snail on it...
  13. Jul 17, 2019 at 2:29 PM
    SiberianTundra
    Greg
    War Machine
    What would you expect to gain with a different header setup ? Sound or power ?
  14. Jul 21, 2019 at 7:51 PM
    KLLVMDCL
    Brandon
    Austin, Texas
    I would assume both, better flow would increase power and sound. I think im gonna go with a custom set of long tubes from DD
  15. Jul 21, 2019 at 8:03 PM
    SiberianTundra
    Greg
    War Machine
    I highly recommend short tube headers over long tube headers. Specially with an engine that has less power. You would gain proper low end power.
