5.7 liter ticking noise
Discussion in 'General Tundra Discussion' started by Tommyjoe, Nov 27, 2022.
  1. Nov 27, 2022 at 10:48 AM
    Tommyjoe
    Tommyjoe [OP] New Member
    2017 Tundra
    Hello Everybody , We are new to Tundras.com so hopefully we don't make any mistakes here .
    Has anyone had any experience with an intermittent ticking sound from a 5.7 liter 2017 Tundra ? We only hear it while at idle . We use 0-20 Mobile 1 and recently read a post on YouTube where switching to genuine Toyota 0-20 solved this issue . Have any of you run into this occasional ticking sound ?
    Thank you for your time and any advise you can share with us .
    Respectfully ,
    Tom
  2. Nov 27, 2022 at 11:12 AM
    PermaFrostTRD
    Northern NY
    The 5.7’s make a ticking noise. Almost diesel-like. If that’s what you’re hearing, don’t be alarmed.
    Where do you live Tom? Regarding oil “genuine Toyota” is just Mobil 1. If you’re in a warm enough climate, you can run 5w-30 and be fine.
    many guys and gals on here do that and say it resolves the ticking issue and they feel the “truck runs better”
  3. Nov 27, 2022 at 11:28 AM
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    It has a bit of a diesel sound when idling (4.6l does it too).
    Metro14536 likes this.
  4. Nov 27, 2022 at 11:49 AM
    Tommyjoe
    2017 Tundra
    Thank you for answering our question . We live in the High Desert of Southern CA. so it seems like your suggestion to switch to 5-30 may be the right path .
    We plan on picking up the new filter and oil next week and hopefully that will clean up this annoying tick-tick . (we'll let you know how it turns out)
    Thank you again !
    Best Regards ,
    Tom
    2mchfun, Black Wolf and PermaFrostTRD like this.
  5. Nov 27, 2022 at 12:20 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Don’t be worried about the “tick” noise OP. Between many family members, friends, and myself, we have collectively owned and leased an absurd amount of Toyota’s since the late 1980’s. Simply put they ALL have had that tick especially the trucks. Some models worse than others. The new Highlander being the quietest (least pronounced) vs the 3.4 V6 being the worst. Personally it doesn’t bother me it the least…it’s in their DNA at this point, why? I have no idea…
    Mr Badwrench and Metro14536 like this.
  6. Nov 27, 2022 at 12:47 PM
    RedGreen
    RedGreen New Member
    2018 SR5 4x4 DC LB
    What kind of tick? Is it worse on startup, then goes away after a minute or two? Or happens all the time?
  7. Nov 27, 2022 at 3:46 PM
    PermaFrostTRD
    Northern NY
    Desert to me means colder winters. Definitely run the motor to operating temp or a couple of minutes before you drive off when temps drop on those colder winter nights. I’d keep it full synthetic. Mobil 1 5w30 should keep you in good shape.
    welcome to the forum from Northern NY
    2mchfun and Metro14536 like this.
  8. Nov 27, 2022 at 4:19 PM
    Tommyjoe
    2017 Tundra
    A Big Thank You to 'All' that have answered our question about the 5.7 liter tick-tick noise . We are going to try changing the oil next week using 5-30W synthetic and hopefully that will do the trick .
    We really enjoy our Tundra and having a Forum like this for advise only makes it All the better ! Thanks Again !! Tom
    PermaFrostTRD, Oey12 and 2mchfun like this.
  9. Nov 27, 2022 at 4:32 PM
    2mchfun
    Welcome to the forum! 0w-20 is the oil used for gas mileage benefits not motor longevity. I run 5w-30 without any hesitation whatsoever. However, I would never regularly use 0w-20.
    AZBoatHauler likes this.
  10. Nov 28, 2022 at 8:03 AM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    Sorry to hijack this thread...but, I am curious about this ticking noise at idle as well. And, for me it seems to be quite loud at idle for the first few minutes or so, on my truck. I have changed from 0W-20 to 5W-30 oil (Mobil 1 Full Synthetic) and have seen an improvement, but only for a short while after oil change (2 months or so). I only drive around 10k miles/year and do oil changes every 6 months. I have read on this site from quite a few others that this is normal and not to worry about it, but what is the actual source of this ticking for most of y'all? Cam tensioner? I have roughly 1 year left on an Extended Warranty, that covers nearly the entire vehicle, and I'd like to have it permanently repaired before my warranty expires, rather than just dealing with it for as long as I own the truck, which I plan on keeping for at least another 8-9 years. FYI, besides this issue, I've only had a bad fuel pump in the last 80K miles. Truck is well maintained and has been super reliable. Thanks everyone for any feedback!
  11. Nov 28, 2022 at 8:15 AM
    RedGreen
    RedGreen New Member
    2018 SR5 4x4 DC LB
    I'd just start feeling/listening around your engine bay to start. Lifters can tick a little bit after a while, but usually that is a very clear tick when cold that clears up or gets quieter as oil pressure builds. Injectors can tick too. Doubt your timing chains or tensioners are worn after 80K miles, they're usually good for waaaay longer than that. Could be an exhaust leak too. A smoke test would reveal whether an exhaust leak is present anywhere.
  12. Nov 28, 2022 at 8:19 AM
    2mchfun
    You might want to try warming the engine, pour in a quart of automatic transmission fluid, let it idle for 20 minutes, then change the oil. If nothing else, you will have tried to a great way to clean it up and free up sticky lifters. You don't really have anything to lose.
    16CMTXED[QUOTED] likes this.
  13. Nov 28, 2022 at 8:25 AM
    RedGreen
    RedGreen New Member
    2018 SR5 4x4 DC LB
    I know ATF is a cleaner of sorts, but wouldn't a dedicated oil cleaner be better, like that ATS stuff? Scotty Kilmer seems to like it a lot
  14. Nov 28, 2022 at 8:35 AM
    2mchfun
    There's almost always more than one way to skin a cat. Doesn't matter what method, it matters that it gets skinned. Will some methods be "better" than others, I guess that depends on the interpretation of "better". I have had great results with ATF, that's all.
  15. Nov 28, 2022 at 9:24 AM
    2mchfun
    Drove a couple million miles in my life and only had one engine issue. Sort of took a chance and submerged a Ford 4.0 pushrod version in a river. Oops! Dragged it out, pulled the plugs, drained and refilled the crankcase, spun it a few times, installed the plugs, she fired right up. The bent rod knocked a bit, drove the dog piss out of it beyond redline for 'bout a week hoping to get a good laugh, damn thing wouldn't come undone! So, yes I have learned two extra things about internal combustion engines. 1. Periodic ATF flushing doesn't harm anything. 2. Keep the intake above the waterline!
    FlyingWolfe and C.I.[QUOTED] like this.
  16. Nov 28, 2022 at 10:26 AM
    RedGreen
    RedGreen New Member
    2018 SR5 4x4 DC LB
    I totally agree, I am just a bit hesitant to put chemicals not meant for engines or engine oil, within them. If it works, it works. May try that on my escape, see if I can free up the ticking lifter there.
  17. Dec 5, 2022 at 7:23 AM
    Tommyjoe
    2017 Tundra
    We are happy to report that our 5.7 engine ticking noise is now gone ! The suggestion to change our oil from 0-20 to 5-30 was the correct solution ! Thanks to All that took the time to respond to our noise issue and share their knowledge and experience !
    Merry Christmas !
    Tom
    k0diak8o8, BUGEATER, ToolCat and 3 others like this.
  18. Dec 5, 2022 at 7:57 AM
    PermaFrostTRD
    Northern NY
    2mchfun likes this.
