5.7 oil capacity!?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DMB4x4, Mar 14, 2019.
  1. Mar 14, 2019 at 5:48 PM
    DMB4x4
    DMB4x4 [OP] New Member
    2014 Tundra SR5 CM 4x4
    I have a 14’ CM 4x4. Just changed my oil and to get it in the correct specs (per manual) is 7.9 with oil filter change, I just put in 9.5 QUARTS to get it show correct on the dip stick? Is this correct? Too much? How much do y’all put in your tundras?
    Ps I’ve read some threads on here regarding oil but can’t seem to find a clear cut answer. Don’t we all have the same engine? Why is everyone’s (including the manuals) numbers different?
    Oil: mobile 1 0w20
    Filter: K&N
    Jud2 likes this.
  2. Mar 14, 2019 at 6:02 PM
    marlin39a
    marlin39a I’m a dumbass.
    Looks like 8.5 quarts with filter is correct.
    619Tundra likes this.
  3. Mar 14, 2019 at 6:04 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Whhooooooooaaaaaaaaaa Nellie. 9.5 is too much where I come from. Sure you're reading it correct? New 0W20 is reeeeeeally hard to read on the dipstick.
    Schmidt_l and FirstGenTundra like this.
  4. Mar 14, 2019 at 6:07 PM
    Mnorris1206
    08 tundra
    I have always done 7.9 then check after a drive or 2
  5. Mar 14, 2019 at 6:08 PM
    Mine always takes 8.5
    TXBrit and OR18TRD like this.
  6. Mar 14, 2019 at 6:21 PM
    SYRTundra315
    SYRTundra315 New Member
    Andrew
    2019 Super White Tundra CrewMax Platinum
    OEM nerf bars, BakFlip MX4, BedRug, VLED interior lights and license plate bulbs, JDM Astar turn signal and reverse bulbs.
    Just did mine yesterday. Took a solid 8.5qts to hit the full line. I ran it and checked it after it say for 2 hours and it was right on. I started with 7.5 and it was clearly low then added 0.5qts at a time till it showed full. 2019 5.7L Platinum.
    TXBrit, Mnorris1206 and Prostar 190 like this.
  7. Mar 14, 2019 at 7:18 PM
    pitts101
    pitts101 New Member
    2016 TRD Pro
    let it sit for a half hour with 8 quarts, or take it for a drive. it comes in correctly on the dipstick but not immediatly. 9.5 is tooooo much.
  8. Mar 14, 2019 at 7:35 PM
  9. Mar 14, 2019 at 7:37 PM
    7.4ish everytime..
  10. Mar 14, 2019 at 7:38 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Usually 8 for mine
    AZBoatHauler and 15whtrd like this.
  11. Mar 14, 2019 at 7:41 PM
    white_sherpa
    white_sherpa New Member
    Phoenix, AZ
    2014 Tundra SR5-Magnuson Supercharged- Custom Tune by DynoComp
    Yours showing at full dot? Most likely 1/2
  12. Mar 14, 2019 at 7:44 PM
    Pretty much 7.4 everytime.
  13. Mar 14, 2019 at 7:46 PM
    white_sherpa
    Phoenix, AZ
    :thumbsup:
  14. Mar 14, 2019 at 7:53 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    For 2014+, 7.9 Brotha!
    The "filter/no filter" language, typically means if you've already added oil to the filter before putting it back in. Given the design of the filter housing, it would be damn hard to get 4/10 a qt. of oil in the filter/housing before reinstalling.
    If memory serves, there was a slight change in the oil filter housing or pan design from the 2nd gen to the 3rd gen...hence the difference in some capacity's being 7.4 and 7.9.
    Like @TundraMcGov. said, the 0W-20 is super thin...and is typically harder to see, especially right after changing.
  15. Mar 14, 2019 at 7:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You can pour a good amount of oil into the filter housing. Good idea since it presoaks the element
    15whtrd and GAknight like this.
  16. Mar 14, 2019 at 8:04 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    True. I know you can soak the filter and fill the bottom of the housing. I usually put some in it. I've just never added .4 a qt.
    I do wish we had a standard filter connection.
    Hbjeff[QUOTED] likes this.
  17. Mar 14, 2019 at 8:10 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yeah, the standard filter works for big rigs. Why some nerd at toyota wanted a PITA version is beyond me
    Rob's Inferno, GAknight and TWJLee like this.
  18. Mar 14, 2019 at 11:02 PM
    DMB4x4
    Idk, I’m thinking it could be a human error ( I took it to a shop) I drive my truck aroun and let it sit for about a hour and check the oil. It is reading just under the the MAX dot. What do you guys think maybe the tech Mis counted the quarts he put in and it’s actually 8.5 not 9.5!!!??
  19. Mar 14, 2019 at 11:48 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    If it was just changed recently, I'd say get a new or really clean drain pan...drain the oil and the filter (don't remove the filter housing)...then measure out and replace the 7.9 qts.
  20. Mar 15, 2019 at 9:44 AM
    DMB4x4
    My confusion is that , 9.5 quarts that the tech supposedly put in it show dead center on the dash gauge and even with the top dot on the dip stick!?!?
  21. Mar 15, 2019 at 9:46 AM
    15whtrd
    15whtrd Mr. Blonde
    Did they charge you for the extra quart and a half? Maybe they just wanted to make a few extra bucks. Whenever I change my oil, 7.9 quarts is perfect. Right at the top of the full mark. Actually I just dump in eight.
    OR18TRD and Mnorris1206 like this.
  22. Mar 15, 2019 at 10:13 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Hope you have a Fumoto to make draining that extra qt easy.
    Tundra18overland and Prostar 190 like this.
  23. Mar 15, 2019 at 10:45 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Just taking this moment to emphasize to those who may not be aware of this ^^^. Again: the gauge is oil PRESSURE. Not oil level. In all fairness the little "picture" with the gauge can certainly lead a person to think it's level. But, again: it is pressure. Oil pressure. It's also a good idea to understand what oil pressures you have under different conditions (idle, highway on ramp acceleration, etc) that way you can identify any abnormalities in oil pressure. Though, you bought a Toyota to not have to worry about oil pressure. If you swap around engine oil brands you can see if there's any change in behavior.
    O.K. Time for recess. Class dismissed.
    TreeCat and (deleted member) like this.
  24. Mar 15, 2019 at 10:51 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Owners Manual says:
    With Filter: 8.5, not 8
    Without filter: 7.9
    That is what I would go with.
  25. Mar 15, 2019 at 10:54 AM
    sundance
    sundance New Member
    2014 5.7 here. I vacuum pull mine out through the dipstick. I vacuum it out till the point there is not a drop that will come out of the drain plug on level ground. I then change the oil filter with new Toyota filter. I have NEVER had to add more than 8.5 quarts. I assume a different filter size or mass could change the volume of oil but not the tune of 1 quart....
  26. Mar 15, 2019 at 11:06 AM
    15whtrd
    15whtrd Mr. Blonde
    Has something changed that I don’t know about?
  27. Mar 15, 2019 at 11:06 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I put in 8.2 and it's always just below the full dot. 9.5 is definitely too much. Also make sure you're checking the level correctly. Don't let it sit for an hour. Get the truck up to operating temp, park on level ground, shut it off and let it sit for 5 minutes, pull the stick and wipe it off, reinsert for a couple of seconds, pull it and check the level.
    Markman likes this.
  28. Mar 15, 2019 at 11:35 AM
    Ronin73
    Ronin73 New Member
    You tell me? This is from the Tundra 2019 owners manual.
    TXBrit and SYRTundra315 like this.
  29. Mar 15, 2019 at 11:45 AM
    15whtrd
    15whtrd Mr. Blonde
    Interesting. I wonder what changed
  30. Mar 15, 2019 at 11:46 AM
    sundance
    sundance New Member
    Probably just finally got it right. :)
    2014 says 7.9 but I've always put in about 8.5 quarts.
    Hbjeff and (deleted member) like this.
