5.7l Tundra trassmission solenoids?
Discussion in '2nd Gen Tundras (2007-2013)' started by 559WeekendWarrior, Feb 6, 2020.
  1. Feb 6, 2020 at 11:18 PM
    559WeekendWarrior
    559WeekendWarrior [OP] New Member
    Menger
    2010 SR5 5.7L PreFlex Warrior
    Custom Build Tubing 3.5 with 3.7 Trd Intake 2014-2019 with Turbo Head Shield Air Filter, Jet Performance MAF, Throttle Body Spacer With Econoaid Throttle Body Booster Gasket. Exhaust 2.5 Cherry Bomb 7841 single with dual Side frame exit or in front of the rear passenger tire. Pedal Commander plug in play for the gas pedal. Last is leveling kit 3-1 front and rear with 32-33 MT tires.
    Hi I need to know if anyone knows what solenoids are which and my main one I'm looking for is the reverse solenoid. I been trying to search and get the names for each individual solenoid but I can't seem to find it. I really need this one time help. Thanks everyone. Hear is a photo of the inside trassmission for our tundra 5.7l
    AZBoatHauler likes this.
  2. Feb 6, 2020 at 11:43 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    No reverse solenoid Reverse is Hydraulically applied
    Theirs a MLPS/TRS That’s a Manual lever position switch or Transmission Range Switch different manufacturers call the same part different names that’s the switch that turns on your reverse lights tells the computer what Range your in
    JohnLakeman, P-Factor and Jpneely like this.
  3. Feb 7, 2020 at 1:25 AM
    559WeekendWarrior
    Menger
    The reason I've ask is I can't go into reverse and having difficulty with the tranny. I can only go forward but it's a bit laggie. Anyhow drain out the tranny fluid and it looks like old Mobil Oil. It does have mirco aluminum wear and tear from driving. This happened a few days ago and it was never like this be4. This happens right off the freeway and it was acting up. Had it park about 20min and came out to go back home and switch to R and no go. This cause me to think that my one of the solenoid had went bad. This is why I had asked
  4. Feb 7, 2020 at 5:44 AM
    Dr_Al
    Dr_Al New Member
    Al
    One of the problems with the tranny is that the insides of the solenoids wear and fluid leaks around the internal parts. That reduces pressure and as a result it doesn't operate correctly. If it was just one problem it could be an electrical issue but if you are having more than one and your fluid looked bad I would suspect that the valve body is worn. I could replace just it or replace the whole thing. If you do replace the tranny I would replace the torque converter too.
  5. Feb 7, 2020 at 7:14 AM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Weekendwarrior I was a transmision mechanic for 25 years now I’m a heavy equipment engineer Unfortunately what you described sounds like a transmision that has failed Reverse has no solenoid Reverse is applied mechanically and hydraulically by the selector shaft what happens when you go into reverse in the transmission is that the reverse drum is applied the forward sprag free spins Solenoids are their to help the transmission shift into gears it’s a bit more complicated than that but it’s the easiest way to understand it. The reason why it might have felt sluggish in forward is cause the transmission could have been in failsafe where it takes off in high gear and won’t shift it does that to protect itself from more damage unfortunately partner reverse is a mechanical gear when you loose it 99% of the time you will need to Rebuild that trans sorry
  6. Oct 15, 2024 at 1:58 PM
    TRIXOOS
    TRIXOOS New Member
    i saw this and now im really stumped
    i have reverses but it shudders, skips and slips
    really hoping a solenoid or valve body
    really dont wanna bite the bullet on a transmission just yet
  7. Oct 15, 2024 at 3:55 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check your fluid level 1st. If service hasn't been done, then start now. No need to jump to replacing parts until you adress basics.
