5 reason why I picked 275/70/15 tire.
Discussion in 'Wheels & Tires' started by bomber, Sep 1, 2019.
  1. Sep 1, 2019 at 9:47 PM
    bomber
    bomber [OP] New Member
    2017 tundra cm 4x4
    1. I could get by with a small level lift.(1.3 inch) This in it self is not an advantage and in hindsight I probably would have changed it to 1.9 inch but the advantage is not extreme CV angles.
    2. The weight of the 275 70 18 tire is a lot less.
    3. I can retain the factory mud flap which keeps rocks from hitting the paint when they get stuck in the tire and fly out when you are back on the pavement.
    4. Less effect on braking and acceleration.
    5. I GPS the speed and at 65 mph the speedometer is the same or maybe 1/2 mph slower. I read from the factory the speedometer was 1/2 mph fast.
  2. Sep 2, 2019 at 6:00 AM
    Tmank87
    Tmank87 New Member
    Can you snap pics from another angle?
    How much do they stick out from side?
    I'm probably after something similar. Gets a better look but is suited for everyday use.
    bomber[OP] likes this.
  3. Sep 2, 2019 at 7:14 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    All of the same reasons that I went with 275 70 18's. I'm on 5100's, middle setting and Cooper XLT's and couldn't be happier with the look and ride. Reason #6, if I went much higher than it sits now I'd have to raise the header on the garage. Stupid 7' garage doors lol.
    bomber[OP] and 15whtrd like this.
  4. Sep 2, 2019 at 7:55 AM
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    I did the same. I am running 275/70/18 Falkens with stock wheels and 1.25” spidertrax. I have Toytec coilovers up front with adjustable shackles and icon shocks in the rear. The tires don’t look small imo.
    bomber[OP], TrooperDC4x4 and 15whtrd like this.
  5. Sep 2, 2019 at 8:56 AM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    I'm at 2.5", 1.5" with 275/70/18 and Spidertrax spacers. This is a good tire size if you don't want to deal with any rubbing or speedo issues. Huge improvement over stock tires.
    InkedIMG_20190824_071032615_LI.jpg IMG_20190823_130603190_HDR.jpg InkedIMG_20190824_071154895_LI.jpg
  6. Sep 2, 2019 at 9:09 AM
    Tmank87
    Tmank87 New Member
    Anyone run these with 20" wheels?
    Was wondering if I could repurpose my Platinum wheels at this size.
  7. Sep 2, 2019 at 9:24 AM
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    Do you need the spacers? What purpose do they serve? I'm tire shopping now and this is the size I want
  8. Sep 2, 2019 at 9:24 AM
    TrooperDC4x4
    Nor Cal
    Are you lifted at all?
    I would consider a 285/60/20. 33.5" tall which is about a 1/4" taller and 10 MM wider than my Cooper AT3 XLT's. The 275/60/20's are 33" tall.
    You can compare sizes here:
  9. Sep 2, 2019 at 9:26 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    I may sell my 18" TRD wheels after I get them back from powder coating gloss black.
  10. Sep 2, 2019 at 9:26 AM
    TrooperDC4x4
    Nor Cal
    No need for spacers other than stance. The factory wheels have a 60MM offset. Spacers put them close to a 25MM offset which works well on these trucks if you go aftermarket.
  11. Sep 2, 2019 at 9:37 AM
    Tmank87
    Tmank87 New Member
    Believe I'm going to pull the trigger on 6112 (1.9) and the 5160 in rear. Still undecided on a rear shackle to keep a slight rake.
    Thanks for that link.
  12. Sep 2, 2019 at 10:11 AM
    roy2015
    roy2015 Waterproof
    Houston
    What made you decide on the billstein?
  13. Sep 2, 2019 at 10:12 AM
    bomber
    2017 tundra cm 4x4
    I would have gone with a 1.9 in hindsight.
  14. Sep 2, 2019 at 10:12 AM
    roy2015
    roy2015 Waterproof
    Houston
    I'm sure this has been answered a thousand times . . . . Can 275/70/18s fit with no lift on TRD sport wheels? I'm not afraid to chop
  15. Sep 2, 2019 at 10:14 AM
    bomber
    2017 tundra cm 4x4
    I get a slight rub on the driver side backing up. I think the alignment shop can move the tire back a 1/4 inch as the driver side is 1/4 inch foward.
    TrooperDC4x4 and roy2015 like this.
  16. Sep 2, 2019 at 10:15 AM
    Tmank87
    Tmank87 New Member
    They seem to get very good feedback, provide a great ride on the pavement (where I am 99.5%), gets the truck up to level, relatively inexpensive.
  17. Sep 2, 2019 at 10:16 AM
    bomber
    2017 tundra cm 4x4
    It would not rib if the rims were stock, but the scs rims have a negative 25 offset. Stock is negative 60.
    fundra_goes_west likes this.
  18. Sep 2, 2019 at 10:17 AM
    roy2015
    roy2015 Waterproof
    Houston
    Billsteins have great reviews for sure. I'm between the 6112 and the Fat Bobs
  19. Sep 2, 2019 at 10:18 AM
    roy2015
    roy2015 Waterproof
    Houston
    What size spacers are you using?
  20. Sep 2, 2019 at 10:28 AM
    TrooperDC4x4
    Nor Cal
    Factory wheels have a positive 60 offset, SCS have a positive 25 offset. Yes this does increase the chance for rubbing, shouldn't be an issue with this size tire and small lift. Might have to remove the spat in front of the tire.
    Casper3 likes this.
  21. Sep 2, 2019 at 10:30 AM
    bomber
    2017 tundra cm 4x4
    Here's how much they stick out with scs negative 25 mm offset.
    Migraine likes this.
  22. Sep 2, 2019 at 10:30 AM
    TrooperDC4x4
    Nor Cal
    1.25" spacers for now, I have plans for aftermarket wheels in the future.
    bomber[OP] and roy2015[QUOTED] like this.
  23. Sep 2, 2019 at 10:31 AM
    roy2015
    roy2015 Waterproof
    Houston
    looks great
    TrooperDC4x4 and bomber[OP] like this.
  24. Sep 2, 2019 at 10:41 AM
    TrooperDC4x4
    Nor Cal
    I am running FBG with the Bilstein 5100's. I have no complaints, ride is great. The reason I went with them was the ease of adjust-ability without having to remove the coil over. I really like the 6112's but the cost and adjustment without removal on the FBG sold me. I am on the street most of the time so they work for me.
  25. Sep 2, 2019 at 10:46 AM
    roy2015
    roy2015 Waterproof
    Houston
    Ditto what you said. Adjustability and price are why I'm digging the FBG. I spend a bit of time off-road, but its the beach. Beaches are flat, I don't care about articulation! I care about catching waves and fish!
    TrooperDC4x4[QUOTED] likes this.
  26. Sep 2, 2019 at 10:53 AM
    TrooperDC4x4
    Nor Cal
    This is where the FBG shine. If you want to adjust after your initial setup you can, just need to get alignment checked which would also be required if making adjustments on 6112. Now when will someone make this setup for the 6112's? Maybe to costly.
    bomber[QUOTED][OP] and roy2015 like this.
  27. Sep 2, 2019 at 11:32 AM
    Michael Quinn
    Michael Quinn New Member
    Tundra
    Off subject:
    I like you're solid black grill in the first photo - I'm looking to order one because my 2019 Limited has a chrome grill ( I hate it - I hate chrome) . Any reasonable after market companies you could suggest ?
    Thanks !
    I'm also going to have the adjacent grill area painted and the two front CHROME bumpers as well . (Our trucks are similar if not identical in color - I really like the look of your front - that's what I'm going for.
  28. Sep 2, 2019 at 11:54 AM
    Tmank87
    Tmank87 New Member
    Thanks. Do you have plans to go with bigger tires?
  29. Sep 2, 2019 at 12:12 PM
    bomber
    2017 tundra cm 4x4
  30. Sep 2, 2019 at 12:19 PM
    bomber
    2017 tundra cm 4x4
    My truck is a 2017 and this grill doesn't have a mount for the sensor that come on 2018+
